NRF52840 DK - Connecting to Windows with x2 different dev boards results in the same COM port being assigned
The issue:
1) Program x2 NRF52840 dev boards
2) comment board A to windows, windows reports COM n
3) unplug board A and connect board B
4) windows reports the same COM port as board A
5) I have to have x2 boards connected to the same PC in order to test an NRF52840 based product, each board is switched on/off independently so
Is there any way of programming a unique serial number into the NRF52840 Dev board for the USB serial device so windows assign a different Com Port for each device?
Please note I am using the correct port (the one on the side), Serial comms is working OK its just that all boards appear as the same number when connected.
  • DaveC said:
    @Edvin Have you seen my replies?
     Yes. Your ticket is put back in the queue when you reply in an existing ticket.
    This has nothing to do with the SDK. The serial COM port doesn't belong to the nRF. It belongs to the programming chip (the large one with the white sticker and a serial number on it. At least that was what I thought. Which USB port on the DK do you use? Do you use the one on the short left hand side, or the one on the long side on the bottom?
    The one on the left hand side is the one belonging to the programmer, while the bottom one is the nRF's USB port.
    If you use the one on the bottom, which actually belongs to the nRF, what did you program into the nRF before doing so?
    Edvin
  • We use the USB port on the long side of the NRF52840 dev board:
    The settings for this port are done programmatically within the application using the API
    static const app_usbd_config_t usbd_config = {
    .ev_isr_handler = usb_new_event_isr_handler,
    .ev_state_proc = usbd_user_ev_handler
    ret = app_usbd_init(&usbd_config);
    We also Call app_usbd_serial_num_generate(void)
    If this Comm Port belongs to the programming chip why are there API's in the SDK to control the Com Port?
    Our intention was to eventually use application on the smaller Dongle without the Debugger, The Com port appearing when the dongle (below) is connected.
     No, sorry. I assumed you meant the other USB port. This is the nRF's USB peripheral COM port.
    I am not sure exactly what you mean is missing in the COM settings. If you program an unmodified version of the SDK17.0.2\examples\peripheral\usbd_cdc_acm to two different DKs, do they not appear as two different COM ports?
    The reason I brought up the windows links in the first reply was that at one point my home computer also got the same COM port on two different programmer chip USB ports (two different DKs), but I changed one of them, and then it was fine.
     The COM port will also change depending on the USB descriptor in the application. You have maybe noticed that the Dongle will have a different COM port when it is in bootloader mode and when it is running an application.
    Edvin
  • The issue seems to be with function void app_usbd_serial_num_generate(void), this sets a global variable uint8_t g_extern_serial_number[SERIAL_NUMBER_STRING_SIZE + 1];
    This Variable is Not referenced anywhere in the sdk_config.h file, though some example code does show it referenced in
    sdk_config.h (6,400)
    // <i> Note: This value is not editable in Configuration Wizard.
    // <i> Serial number that is defined the same way like in @ref APP_USBD_STRINGS_MANUFACTURER.
    #ifndef APP_USBD_STRING_SERIAL
    #define APP_USBD_STRING_SERIAL g_extern_serial_number
  • What example do you refer to?
    The usbd_cdc_acm example doesn't have this define on that line number, but I'll use that example as reference for now.
    sdk_config.h line 1304:
    // <s> APP_USBD_STRING_SERIAL - String descriptor for the serial number.
    g_extern_serial-number is defined in app_usbd_serial_num.c, line 54:
    SERIAL_NUMBER_STRING_SIZE is defined in the same file, line 48:
    The function app_usbd_serial_num_generate() generates the serial number based on the FICR->DEVICEADDR[0] and [1]:
        char serial_number_string[SERIAL_NUMBER_STRING_SIZE + 1];
        const uint16_t serial_num_high_bytes = (uint16_t)NRF_FICR->DEVICEADDR[1] | 0xC000; // The masking makes the address match the Random Static BLE address.
        const uint32_t serial_num_low_bytes  = NRF_FICR->DEVICEADDR[0];
        (void)snprintf(serial_number_string,
                       SERIAL_NUMBER_STRING_SIZE + 1,
                       "%04"PRIX16"%08"PRIX32,
                       serial_num_high_bytes,
                       serial_num_low_bytes);
        string_create(serial_number_string);
    And the last function call in app_usbd_serial_num_generate(), string_create() copies this string to the g_extern_serial_number:
    static void string_create(char * p_serial_number_string)
        for (uint32_t i = 0; i < strlen(p_serial_number_string); i++)
            g_extern_serial_number[i] = (uint8_t)p_serial_number_string[i];
    Does it not do that in your case? If so, what SDK version are you using? As mentioned, I am using SDK17.0.2.
    I am sorry if this is already obvious for you, but in that case, I failed to understand your question. I am sorry.
    Edvin
