NRF52840 DK - Connecting to Windows with x2 different dev boards results in the same COM port being assigned
The issue:
1) Program x2 NRF52840 dev boards
2) comment board A to windows, windows reports COM n
3) unplug board A and connect board B
4) windows reports the same COM port as board A
5) I have to have x2 boards connected to the same PC in order to test an NRF52840 based product, each board is switched on/off independently so
Is there any way of programming a unique serial number into the NRF52840 Dev board for the USB serial device so windows assign a different Com Port for each device?
Please note I am using the correct port (the one on the side), Serial comms is working OK its just that all boards appear as the same number when connected.
  • No problem, I appreciate your help.  We are on V16.0.0 of the SDK. I have got as far as:
    1) Call app_usbd_serial_num_generate().  This generates a serial number and copies it to  g_extern_serial_number
    2) This works OK,  g_extern_serial_number is referenced by several #defines, eventually ends up being mapped to #define APP_USBD_STRING_ID_SERIAL
    3) #define APP_USBD_STRING_ID_SERIAL is referenced inside app_usbd_core.c, this library being enabled with #define APP_USBD_ENABLED (which I have done)
    3) Inside app_usbd_core.c #define APP_USBD_CORE_DEVICE_DESCRIPTION references define APP_USBD_STRING_ID_SERIAL along with many other USB configuration parameters.
    So, having created a unique serial number in step 1) how do I use the library functions in app_usbd_core.c to update the USB serial number on the driver?
  • I agree that it is a bit difficult to see how/where it is used, but I believe it is something like:
    app_usbd_core_event_handler()
    case APP_USBD_EVT_DRV_SETUP:
    app_usbd_core_setup_req_handler()
    setup_device_req_std_handler()
    setup_device_req_get_descriptor()
    app_usbd_string_desc_get()
    app_usbd_prepare_string()
    m_string_dsc[], which uses
    APP_USBD_STRING_SERIAL
    which is defined as g_extern_serial_number,
    which is set by app_usbd_serial_num_generate().
    Have you checked that this behavior is replicateable on several computers? As mentioned, I do not see the same behavior on my Windows 10 machine. Each nRF has different COM ports, which stay the same accross power cycles.
    BR,
    Edvin
  • That's what I have, though to get it to build I had to declare "extern int g_extern_serial_number[]" in app_usbd_string_desc,c to avoid a compiler error.  g_extern_serial_number is not defined as extern in any header file.
    I'm looking at speading the tests which use the Dongle accross several PC's to avoid the port conflict issue.
