nrf52832 bootloader upgrade issue
The chip we use is nrf52832 and the SDK is nrf5_ SDK_ 15.3.0_ 59ac345,
Can we use nrf Toolbox (version: 2.7.2) to upgrade bootloader?
1. How to make bootloader upgrade package? Is there any SOP for bootloader upgrade
2. Does the application or bootloader need to be changed in the code
    Yes, you should be able to upgrade the bootloader. Are you seeing any errors?
    1. You can generate a bootloader upgrade package with nrfutil similiar do how you would to it for other type of updates. The difference is that you must provide the --bootloader and --bootloader-version argument:
    nrfutil pkg generate --hw-version 52 --app-boot-validation VALIDATE_GENERATED_CRC ^
    --bootloader-version VERSION ^
    --bootloader BOOTLOADER.hex ^
    --sd-req 0xB7 ^
    --key-file PRIVATE.pem dfu_bootloader.zip
    2. The new bootloader image will not be swapped with the existing bootloader if they are 100 % identical. So the new bootloader must have some changes to get updated. And the bootloader can usually be updated separately without requiring an update of the application.
  • Hello:
    OK,Got it.and also we want to know how to make BL + SD + APP package?
    Tks!
    You can create a complete SD+BL+APP DFU package by adding the nrfutil arguments shown in the example snippet below. You may also run "nrfutil pkg generate --help" to get a help description for all of the command options.
    --softdevice SOFTDEVICE.hex ^
    --application APPLICATION.hex ^
    --application-version-string "1.0.0" ^
    --sd-req <insert SD FWID required for the SD+BL part of the update> ^
    --sd-id  <insert the new SD FWID required for the application update> ^
    --key-file PRIVATE.pem dfu_complete.zip
