nrf52820 power control not working from samples
We use nrf connect sdk under linux.
I need to control tx power to be able to adjust working range.
I take example from zephyr/samples/bluetooth/hci_pwr_ctrl
Add segger_rtt
CONFIG_LOG_MINIMAL=n
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=512
CONFIG_LOG_BUFFER_SIZE=512
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_DEBUG_OPTIMIZATIONS=n
CONFIG_LOG_PRINTK=y
CONFIG_PRINTK=y
CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=512
Slightly increase stack size to prevent stack overflow errors
Run it on the board and get errors
00> Set Tx power level to 4
00>
00> Actual Tx Power: 4
00>
00> Get Tx power level -> [00:00:15.010,467] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
00> Read Tx power err: -5 reason 0x00
00>
00> TXP = -1
00>
00> Set Tx power level to 0
00>
00> Actual Tx Power: 0
00>
00> Get Tx power level -> [00:00:20.011,260] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
00>
00> TXP = -1
00>
00> Set Tx power level to -3
00>
00> [00:00:20.011,657] <wrn> bt_hci_core: opcode 0xfc0e status 0x12
00> Set Tx power err: -5 reason 0x00
00>
00> Get Tx power level -> [00:00:25.012,084] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
00>
00> TXP = -1
00>
00> Set Tx power level to -8
00>
00> Actual Tx Power: -8
00>
00> Get Tx power level -> [00:00:30.013,000] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
00>
00> TXP = -1
00>
00> Set Tx power level to -15
00>
00> [00:00:30.013,427] <wrn> bt_hci_core: opcode 0xfc0e status 0x12
00>
Where is my mistake? May be there are other ways to control tx power?
