SPIM3配置,MOSI--P0.2,MISO--P0.28,SCK--P1.6,SS--P1.4,时钟频率125K,MODE0模式
如图,绿色为时钟,黄色为MOSI,在一个字节数据传输结束后,MOSI引脚引脚电平缓慢下降的状态,是否正常?期间更换其他引脚测试,均如此。
Yes, perfectly normal:
那请问为什么会这样?
I believe it is the small amount of pin capacitance coupled with the very high impedance you see at both ends of the connection. You could probably put a very weak (100k?) pull down if it bothers you or you need it to drop faster, but the push-pull will pull it do it for you when it comes time to load up the next bit.
For reference: 5pF pin/line capacitance (low estimate since pad capacitance is already ~4pF) with 100MOhm impedance (also probably low estimate) would mean ~= 0.5ms time constant. So this is about in line with what we see.
非常感谢!!!
