[PWM-DRIVER] Pull up/pull down pins use for PWM driver
Hi everyone,
I am making a project to dim a led strip following PWM driver example, everything works pretty well but i only have one problem that I need to set a state for the pins before doing any dimming so that it will not turn on/off suddenly during reset or start up in float state. But i can not find any way to set that value in the example or document.
So i have a question that: Is there any way I can set the PWM pins to be pull up or pull down before doing and PWM dimming?
Thank you and please reply soon
    You can select the initial pin state by using NRF_DRV_PWM_PIN_INVERTED, before you start any dimming(with nrf_drv_pwm_simple_playback/nrf_drv_pwm_complex_playback  ). The pin state will be set when you call nrf_drv_pwm_init().
    Snippet:
     nrf_drv_pwm_config_t const config0 =
            .output_pins =
                BSP_LED_0 | NRF_DRV_PWM_PIN_INVERTED, // channel 0
                BSP_LED_1 ,                           // channel 1
                BSP_LED_3 | NRF_DRV_PWM_PIN_INVERTED, // channel 2
                BSP_LED_2 | NRF_DRV_PWM_PIN_INVERTED  // channel 3
            .irq_priority = APP_IRQ_PRIORITY_LOWEST,
            .base_clock   = NRF_PWM_CLK_1MHz,
            .count_mode   = NRF_PWM_MODE_UP,
            .top_value    = m_demo1_top,
            .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
            .step_mode    = NRF_PWM_STEP_AUTO
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, demo1_handler));
        m_used |= USED_PWM(0);
