How to set some parameters for opus codec? Is there a demo for it?
I am using opus to compress and decompress audio data, but I don't know how to port it to the SDK. specific process.
    You can check out the example found in the SDK for the Smart Remote, which is a custom SDK tailored for smart remote applications.If I remember correctly, it is using the opus codec by default. Perhaps you can look into this to see how to port it to the SDK.
    Edvin
  • hi!
    I can now use opus for audio codec, but I found a problem, is its coding efficiency is a bit low, I am a frame data volume for 480 byte of the audio data encoding, I measured it takes 17 ms encoding time, this time is very long, for me when I was a shorter time frame, he completely the coding time can't keep up with the speed of my data.How do I solve it?
    Ellison
  • That is all we have really. Audio over BLE is not really supported at this point in time. It is currently in the process of happening, but I am not sure of the details, and how this codec is handled. Perhaps you need a more powerful processor.
    In the smart remote SDK this is only used to send voice commands, and not a continuous stream. If that is what you are trying to acheive, I am not sure whether that is possible. Also note that there is currently no way to discard packets in BLE, so if the connection is poor (large distance or a lot of noise), there is no way to discard packets that are not Acked, even though they are getting old.
    BR,
    Edvin
  • Opus Codec needs to be compiled in Release mode to run properly.
