TWI Scanner no device was found
Hi, I'm using nRF52 DK (nRF52832) to detect my sensor. The sensor I2C address is 0x21 (verified by Arduino UNO).
My nRF52 DK (master) could detect the slave sensor before. But after I changed code somewhere (I forgot), the nRF52 DK cannot detect the slave sensor anymore. Any idea, pls? Thank you!
 * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_scanner main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
 #define TWI_ADDRESSES      127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
     * @brief Function for initializing the TWI driver instance.
     * @param[in] p_instance      Pointer to the driver instance structure.
     * @param[in] p_config        Initial configuration.
     * @param[in] event_handler   Event handler provided by the user. If NULL, blocking mode is enabled.
     * @param[in] p_context       Context passed to event handler.
     * @retval NRF_SUCCESS             If initialization was successful.
     * @retval NRF_ERROR_INVALID_STATE If the driver is in invalid state.
     * @retval NRF_ERROR_BUSY          If some other peripheral with the same
     *                                 instance ID is already in use. This is
     *                                 possible only if PERIPHERAL_RESOURCE_SHARING_ENABLED
     *                                 is set to a value other than zero.
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    NRF_LOG_INFO("TWI enabled");
    uint8_t address;
    uint8_t sample_data[9];
    bool detected_device = false;
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
    /* Configure board. */
    for (address = 0; address < TWI_ADDRESSES; address++)
       * @brief Function for reading data from a TWI slave.
       * The transmission will be stopped when an error occurs. If a transfer is ongoing,
       * the function returns the error code @ref NRF_ERROR_BUSY.
       * @param[in] address    Address of a specific slave device (only 7 LSB).
       * @param[in] p_data     Pointer to a receive buffer.
       * @param[in] length     Number of bytes to be received.
       * @retval NRF_SUCCESS                    If the procedure was successful.
       * @retval NRF_ERROR_BUSY                 If the driver is not ready for a new transfer.
       * @retval NRF_ERROR_INTERNAL             If an error was detected by hardware.
       * @retval NRF_ERROR_DRV_TWI_ERR_OVERRUN  If the unread data was replaced by new data
       * @retval NRF_ERROR_DRV_TWI_ERR_ANACK    If NACK received after sending the address in polling mode.
       * @retval NRF_ERROR_DRV_TWI_ERR_DNACK    If NACK received after sending a data byte in polling mode.
        err_code = nrf_drv_twi_rx(&m_twi, address, sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address decimal %d = hex 0x%x.",address ,address);
            NRF_LOG_FLUSH();
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    while (true)
        /* Empty loop. */
