I am using raspberry pi to communicate with nrf52840
My rpi is used as msater, nrf52840 is used as slave
My nrf52840 is implemented as SPI slave under zephyr OS
At present, I found that when rpi uses spi to transfer data to nrf52840, there will be a problem that the transfer is not successful
I wonder if the frequency of my nrf52840 SPI and rpi SPI is not the same
I want to ask what is the SPI default frequency of nrf52840?
I can't find how much it is.
I only see the initialization function, but there is no place to set the frequency
nrfx_spis_init(&spis_t,&spis_config_t,spis_event_handler_t,NULL);
So I want to change the frequency of my RPi SPI
The current settings of my rpi are as follows
spi=spidev.SpiDev() spi.open() spi.max_speed_hz=976000
Or how can I set the SPI slave frequency of my nrf52840 to 976000?
My nrf52840 SPI slave on Zephyr OS is set as follows
#include <zephyr.h>
#include <sys/printk.h>
#include "nrfx_spis.h"
#define PIN_SCK 29
#define PIN_MOSI 31
#define PIN_MISO 30
#define PIN_CSN 28
#define SPIS_NR 0
#include <devicetree.h>
#include <drivers/gpio.h>
#define LED0_NODE DT_ALIAS(led2)
#define LED0 DT_GPIO_LABEL(LED0_NODE, gpios)
#define PIN 3
#define FLAGS DT_GPIO_FLAGS(LED0_NODE, gpios)
const struct device *led;
nrfx_spis_t spis_t = NRFX_SPIS_INSTANCE(SPIS_NR);
nrfx_spis_config_t spis_config_t = NRFX_SPIS_DEFAULT_CONFIG(PIN_SCK,PIN_MOSI,PIN_MISO,PIN_CSN);
uint8_t readend=0;
uint8_t rx_buffer[8];
uint8_t tx_buffer[8];
uint8_t tmpbuffer[8] = {0};
void spis_event_handler_t(nrfx_spis_evt_t const *p_event, void *p_context){
//printk("received\n");
int err;
switch(p_event->evt_type){
case NRFX_SPIS_XFER_DONE:
if(rx_buffer[0] && rx_buffer[0]!= 255)
printk("read");
for(int i=0;i<8;i++){
printk("%d ",rx_buffer[i]);
printk("\r\n");
err = nrfx_spis_buffers_set(&spis_t, tx_buffer, sizeof(tx_buffer), rx_buffer, sizeof(rx_buffer));
if(err != NRFX_SUCCESS){
printk("Error with setting.\n");
readend=1;
static void manual_isr_setup()
IRQ_DIRECT_CONNECT(SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn, 0, nrfx_spis_0_irq_handler, 0);
irq_enable(SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn);
void init_spis(){
int err;
err = nrfx_spis_init(&spis_t,&spis_config_t,spis_event_handler_t,NULL);
printk("Error with init.\n");
} else {
printk("SPIS started.\n");
void main(void)
int err,k=0,ret;
init_spis();
bool low = true;
bool high =! low;
led = device_get_binding(LED0);
if (led == NULL) {
return;
ret = gpio_pin_configure(led, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
if (ret < 0) {
return;
gpio_pin_set(led, PIN, (int)low);
manual_isr_setup();
while(true){
if(readend==1){
tx_buffer[0] = 5;
tx_buffer[1] = 24;//message from
printk("write ");
for(int i = 0 ; i< 8 ; i++)
tx_buffer[i] = k+i;
k++;
printk("%d ",tx_buffer[i]);
printk("\r\n");
gpio_pin_set(led, PIN, (int)high);
readend=0;
Thank,
Po-I
