custom nrf9160 board unable to connect : SIP version pb ?
We developped a custom NRF9160 board and it works fine, it connects to LTE-M. We then designed a new version of the same board by adding few things (like NRF52833 MCU) and it does not connect anymore.
  • On the new boards, the schematics related to NRF9160 are essentially the same as on the older version
  • On the new boards, the firmware running the NRF9160 modem part looked rather old (somthing like mfw_nrf9160_0.6.x-xx.alpha or mfw_nrf9160_0.5.x-xx.alpha)
  • The AT%XSIM? command always returned 0 and we add to update the firmware to newer version nrf9160_1.2.3 before the SIM card activation successfully returned 1
  • But still, the NRF9160 refuse to connect.
  • Directement measurements on the antenna PIN show nothings go out
  • The SIM card  is the same
  • The results of AT commands are similar to those from earlier board (see below)
The SIP on the former board was: nRF9160 SICA B0 2025BC
The SIP on newer board is: nRF9160 SICA B0 191102
AT+CFUN?
+CFUN: 4
OK
AT+CFUN=1
OK
AT+CFUN?
+CFUN: 1
OK
AT+CGSN=1
+CGSN: "352656100163024"
OK
AT+CEMODE?
+CEMODE: 2
OK
AT%XCBAND=?
%XCBAND: (1,2,3,4,5,8,12,13,14,17,20,25,26,28,66)
OK
AT+CMEE?
+CMEE: 0
OK
AT+CMEE=1
OK
AT+CNEC?
+CNEC: 0
OK
AT+CNEC=24
OK
AT+CGEREP?
+CGEREP: 0,0
OK
AT+CGDCONT?
OK
AT+CGACT?
OK
AT+CGEREP=1
OK
AT+CIND=1,1,1
OK
AT+CEREG=5
OK
AT+CEREG?
+CEREG: 5,4,"FFFE","FFFFFFFF",7,0,0,"00000000","00000000"
OK
AT%CESQ=1
OK
AT+CESQ
+CESQ: 99,99,255,255,255,255
OK
AT%XSIM=1
OK
AT%XSIM?
%XSIM: 1
OK
AT+CPIN?
+CPIN: READY
OK
AT+CPINR="SIM PIN"
+CPINR: "SIM PIN",3
OK
AT+CIMI
901405101055803
OK
    Have you measured on both the working and not working HW ?
    Is the RF part the same ? have there ben any changes in the PCB layout?
    Can you possibly share the schematic and the PCB files ?
    Might solve this without having top share schematic and HW files
    You have used the same SIM and know it works.
    What does AT%XMONITOR return ?
    Jonathan
    Thanks for your answer Jonathan.
    The RF part on the new board is fine; we were able to connect to LTE-M from the older board using the RF part (antenna and matching circuit) of the newer board.
    I will check the result of  AT%XMONITOR on monday morning (I'm teleworking today and have no access to our lab currently), and if we cannot figure anything from it, I will share schematic and HW files with you.
    Franck
  • Ok, sounds good. If you dont want to share the files publicly we can make this case private or you can create a new one, whatever you prefer.
    Jonathan
  • Hi Jonathan,
    I tried again the AT commands including AT%XMONITOR.
    The first response of AT%XMONITOR is 4 and the second is 0
    Do you have an Idea ?
    The complete results are below
    AT%XSYSTEMMODE=1,0,0,1
    OK
    AT%XSYSTEMMODE?
    %XSYSTEMMODE: 1,0,0,1
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    +CGSN: "352656100353088"
    OK
    AT+CGMI
    Nordic Semiconductor ASA
    OK
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    mfw_nrf9160_1.2.3
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=5
    OK
    AT+CEREG?
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    901405101055802
    OK
    AT+CGDCONT?
    OK
    AT%XMONITOR
    %XMONITOR: 4
    OK
    AT%XMONITOR
    %XMONITOR: 0
    AT%XMONITOR returning the values 4 and 0
    indicated that it is not recognized by the network.
    - 4 – Unknown (e.g. out of E-UTRAN coverage)
    - 0 – Not registered. User Equipment (UE) is not currently searching for an operator to register to.
    For +CEREG  4 is the same as %XMONITOR command, 4 – Unknown (e.g. out of E-UTRAN coverage).
    Does the SIM work on other HW ? And you are testing with AT_Client  ?
    Jonathan
