Potential DFU process bug
I'm currently implementing a DFU "controller" in C on the nRF9160 for performing serial DFU with the nRF52840 and believe I have discovered a bug.
My firmware image was transferred for all but the final block, which was of size less than a code page. This went wrong, and the DFU process was repeated.
In this repeat, the DFU controller attempts to "recover" where it left off by selecting the object and continuing from the position the target responds with - all good so far.
However, if there is now a mismatch in CRCs, the DFU controller wishes to step back a whole object (I can't show my C but the Python equivalent line for nrfutil is here: https://github.com/NordicSemiconductor/pc-nrfutil/blob/afe788d4fd839ed707a1dd870bbd8288e0402949/nordicsemi/dfu/dfu_transport_serial.py#L271)
Now, the next command sent is to create an object, and this is done with max size (a whole object size). But the bootloader is only expecting a less than full object size and rejects the command with code 0x08 as this would go beyond the end of the firmware image it was told about.
I can't quite get my head straight around it but the main problem seems to be the controller wants to step back an object but the target only ever moves forward. There is nothing in the protocol for the controller to specify the offset, it simply hands the target an object. Therefore, the controller shouldn't be modifying its own offset into the part of the image to be sent, no?
