Current draw when SYSTEM OFF with GPIO input LOW
Hi, my BLE application on nRF52832 is designed to select two mode to operate with 3 position slide switch when power on like ON(Mode 1) - OFF - ON(Mode 2).
At Mode 1 position, it power up and also connected to ground (LOW) as GPIO input using different contact to detect the mode position and at Mode 2 position, it power up and GPIO input is disconnected from ground (HIGH).
This issue I came across is when it sleep system off with mode 1, it draws around 0.22mA. but mode 2 is no current as expected. I thought when system off it cuts off the current draw but it seems not. Is it expected behavior? Could you please advise how to avoid it?
#define BUTTON_START   17
#define BUTTON_1       17
#define BUTTON_2       18
#define BUTTON_3       12         //Factory reset button
#define BUTTON_4       11         //SLIDE SW for POWER and MODE Selection
#define BUTTON_STOP    11
#define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
#define BUTTONS_ACTIVE_STATE 0
#define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4 }
#define BSP_BUTTON_0   BUTTON_1
#define BSP_BUTTON_1   BUTTON_2
#define BSP_BUTTON_2   BUTTON_3
#define BSP_BUTTON_3   BUTTON_4
static void ble_buttons_leds_init(bool * p_erase_bonds)
    bsp_event_t startup_event;
    uint32_t err_code;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    //turn off Pressure Sensor
    nrf_gpio_pin_set(SENSOR_GND); //set high
    // Prepare wakeup buttons.
