nRF9160 GPIO pin leakage/pull-down problem
We use our own board with both nRF52840 and nRF9160. We run into a problem trying to implement a circuit that enables the nRF9160 to reset the nRF52840. Things work fine if we disable the pinreset in nRF52840.
Background:
  • We start the nRF52840 first. It is powered with 1.8V.
  • The nRF9160 has VDD (3.0V - 4.2V in this case) supplied. The ENABLE pin of the nRF9160 is pulled down at the start (nRF52840 enables it when needed). VDD_GPIO is not supplied when ENABLE is down.
  • The device tested uses an NRF9160-SICA-B1A sample - but it seemed that the same behaviour exists in NRF9160-SICA-B0A
Problem: The P0.25 pin of the nRF9160 is connected to the nRESET of the nRF52840. If we enable the pinreset configuration in UICR, the internal pull-up of the nRF52840 fails to pull the pin high, the voltage raises to 0.93V - 1.05V only. It seems like the nRF9160 pulls the pin down. If the ENABLE pin of the nRF9160 is raised and VDD_GPIO supplied, the nRF9160 P0.25 goes to high-Z state and the nRF52840 pinreset pullup pulls the pin to 1.8V. It seemed that pulling ENABLE down after this leaves the reset line at 1.8V. Our system does not boot if the pinreset is enabled as the nRESET voltage is too low and the nRF52840 remains in the reset state.
I did not find this nRF9160 behavior documented anywhere. Is this the correct interpretation? Is there any difference if we switched to another pin in nRF9160? (The P0.25 has also TRACE3 function - seems unlikely but possible that it could interfere). Is there some workaround for this that would allow the nRF9160 GPIO pin to be connected to the nRESET of the nRF52840 - when nRF9160 ENABLE is kept low at boot?
Adding a pullup resistor would help to raise the voltage but it raises the current consumption way too much.
Pertti
  • This at least answers the original question.
    This additional information is interesting. The figure suggests that the leakage from P0.25 would go to the VDD_GPIO. As far as I remember in our design it should not leak to VDD_GPIO (more than what goes to about 5uF of capacitance to GND). But we will check that.
  • Pertti Kasanen said:
    We were wondering should we use ENABLE, nRESET or maybe SYSTEMOFF for what we wanted but did not find enough information for getting the first experiment right.
    We do have some improvements to do on the usability of the documentation but it is hard to get things right since there are so many different uncases and variables that will change the configuration. SYSTEMOFF is often a safe bet and will reduce consumption allot, but I don't know how often you need to be connected to LTE so there will always be a tradeoff to what is best. keeping the system on an potentially have some leakage or power down and up again and paying the cost of startup.
    Jonathan
  • Just an additional comment. We had the VDD_GPIO disconnected (with a FET).
    We made a new test for selectively connecting the VDD_GPIO to GND while ENABLE is down (and 2-3 of the nRF9160 GPIO pins are pulled-up). It increased the current consumption by about 2uA.
