Pairing passkey , cancel pairing on android side still give access to characteristic
Hi ,
I'm working on nrf52833, s113.
I have trouble to secure my system. It has no kayboard or screen, and with 6digit fixd pathkey( no other choice).
That's mean it advertise once wake up with accelerometre.
I want to protect access to my 4 characteristics. So i enable bounding and  MITM. to have the passkey popup on android. Without MITM, i don't have passkey pop up. But then the strange stuff appar:
My program is based on hrs example + dfu merging.
I was thinking that, by using pairing protection with 6 digit fixed pathkey( no other choice cause no IO), i would not be able to read/write my characteriqtics. But with nrfConnect, if you are fast enough, when bounding window pops up , and you click cancel and really fast after, you are able to click on the row to read a characteristics, the connexion is maintained and you have access to all , without been securly paired !!! Note that here, my charac are in OPEN. I juste relly on the fact that the passkey will avoid to go next step...
I know i can protect each caracteristic by using : BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM , what i did.
But a side effect appears: after first pairing on the phone by writing the 6 digit passkey, the same windows pops up FOR EACH characteristic you read ( only the first time) ... so it s a bit anoying because you have the feeling to have paired at connexion step , but in fact it has absolutely no impact on security.
If you click cancel you are still connected and if fast enough you can even have access to all. If you paired successfully, you will have to enter this same path key for each characteristic you have protected, what give a strange effect to the final user, he has the feeling that first pairing didn't worked.
What i need is :First, ask pairng after connect. If yes 6digit ok , no more asked user to enter pathkey. If no or cancel, close connexion or retry but doesn't give access. Only paired device should have access.
Hope to have been clear :)
  • Here is a capture on android of the problem. I first connect, and click cancel on 6digit input windows, then i clicke fast to read characteristic. Once read, i'm still connecting, passkey has been totaly by passed... Second try i input the correct pas kay, and i get same result than without ( what i want in fact ):
  • I have added code in main to print all ble GAP event that occurs.
    uint32_t err_code = NRF_SUCCESS;
    case BLE_GAP_EVT_CONN_PARAM_UPDATE : NRF_LOG_INFO ( " BLE_GAP_EVT_CONN_PARAM_UPDATE " ) ; break ;
    case BLE_GAP_EVT_SEC_PARAMS_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_SEC_PARAMS_REQUEST " ) ; break ;
    case BLE_GAP_EVT_SEC_INFO_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_SEC_INFO_REQUEST " ) ; break ;
    case BLE_GAP_EVT_PASSKEY_DISPLAY : NRF_LOG_INFO ( " BLE_GAP_EVT_PASSKEY_DISPLAY " ) ; break ;
    case BLE_GAP_EVT_KEY_PRESSED : NRF_LOG_INFO ( " BLE_GAP_EVT_KEY_PRESSED " ) ; break ;
    case BLE_GAP_EVT_AUTH_KEY_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_AUTH_KEY_REQUEST " ) ; break ;
    case BLE_GAP_EVT_LESC_DHKEY_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_LESC_DHKEY_REQUEST " ) ; break ;
    case BLE_GAP_EVT_AUTH_STATUS : NRF_LOG_INFO ( " BLE_GAP_EVT_AUTH_STATUS " ) ; break ;
    case BLE_GAP_EVT_CONN_SEC_UPDATE : NRF_LOG_INFO ( " BLE_GAP_EVT_CONN_SEC_UPDATE " ) ; break ;
    case BLE_GAP_EVT_RSSI_CHANGED : NRF_LOG_INFO ( " BLE_GAP_EVT_RSSI_CHANGED " ) ; break ;
    case BLE_GAP_EVT_SEC_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_SEC_REQUEST " ) ; break ;
    case BLE_GAP_EVT_SCAN_REQ_REPORT : NRF_LOG_INFO ( " BLE_GAP_EVT_SCAN_REQ_REPORT " ) ; break ;
    case BLE_GAP_EVT_PHY_UPDATE : NRF_LOG_INFO ( " BLE_GAP_EVT_PHY_UPDATE " ) ; break ;
    case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST : NRF_LOG_INFO ( " BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST " ) ; break ;
    case BLE_GAP_EVT_DATA_LENGTH_UPDATE : NRF_LOG_INFO ( " BLE_GAP_EVT_DATA_LENGTH_UPDATE " ) ; break ;
    When i click in pop up windows on Cancel, i catch BLE_GAP_EVT_AUTH_STATUS. This flag is treated by this piece of code in security_dispatcher.c :
    /**@brief Function for processing the @ref BLE_GAP_EVT_AUTH_STATUS event from the SoftDevice.
     * @param[in]  p_gap_evt  The event from the SoftDevice.
    static void auth_status_process(ble_gap_evt_t const * p_gap_evt)
        switch (p_gap_evt->params.auth_status.auth_status)
            case BLE_GAP_SEC_STATUS_SUCCESS:
                auth_status_success_process(p_gap_evt);
                auth_status_failure_process(p_gap_evt);
    #if PM_RA_PROTECTION_ENABLED
                ast_auth_error_notify(p_gap_evt->conn_handle);
    #endif // PM_RA_PROTECTION_ENABLED
    I note that a piece of code is disabled because PM_RA_PROTECTION_ENABLED is cleared to 0 in my sdk_config.h , what avoid re pairing.
    So it could be the source of my issue ? because i already paired this phone once, it is in my autorized list in the nrf52833 and then even if i cancel it works ?
    I have enabled this flag but same behavior of the app.
    So is it to me to manage via BLE_GAP_EVT_AUTH_STATUS, and try to ask for a new pairing code, or close connextion may be ? How it done usually. I find this strange that by default this case is not cover, it is a basic security fault in this state, i hope it comes from my code.
  • Hi Florian,
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM will set sec_mode pointed to by ptr to require encryption, but no MITM protection.
    I think you can try to set BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM for your requirement, and this example LE Secure Connections Multirole Example is similar to your case.
    -Amanda H.
  • Here is my console trace when i click on cancel and wait ( no fast click on characteristic):
    <info> app: ADVERTISING ! Wait connexion or TIMEOUT...
    <debug> nrf_sdh_ble: BLE event: 0x10.
    <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
    <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
    <info> app: CONNECTED
    <debug> nrf_sdh_ble: BLE event: 0x3A.
    <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
    <debug> nrf_sdh_ble: BLE event: 0x12.
    <info> app: 	  BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_sdh_ble: BLE event: 0x23.
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
    <info> app: 	  BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST
    <debug> nrf_sdh_ble: BLE event: 0x24.
    <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
    <debug> nrf_ble_gatt: max_rx_octets: 27
    <debug> nrf_ble_gatt: max_tx_octets: 27
    <debug> nrf_ble_gatt: max_rx_time: 2120
    <debug> nrf_sdh_ble: BLE event: 0x19.
    <info> app: 	  BLE_GAP_EVT_AUTH_STATUS
    <debug> nrf_sdh_ble: BLE event: 0x11.
    <info> app: DISCONNECTED
    <info> app: try to advertise...
    Here the trace if i do nothing when pop up 6 digit happens:
    <debug> nrf_ble_gatt: max_tx_time: 2120
    <debug> nrf_sdh_ble: BLE event: 0x26.
    <debug> app: ADVERTISING TIMEOUT, ADV_SET_TERMINATED :(
    <info> app: ACCEL IN LOW POWER
  • Thanks Amanda,
    1.does it means 6 digit cancel behavior is normal and that we can't use that to avoid to read characeteristics ?
    2.If yes , what is the purpose of this pairing method ?
    3. with BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM , is it normal to hav the pop up windows and that we need to re enter each time the 6 digit ?
    Thank you !
