I want to add a battery level characteristics to a custom service. Here is my approach:
In main.c, I add a timer to update battery level periodically
void data_update_timer_timeout_handler(void * p_context) { battery_level_update(&m_sss); } static void timers_init(void) { // Initialize timer module, making it use the scheduler APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, true); uint32_t err_code = app_timer_create(&m_data_update_timer, APP_TIMER_MODE_REPEATED, data_update_timer_timeout_handler); APP_ERROR_CHECK(err_code); }
The function "battery_level_update" is
uint32_t battery_level_update(ble_sss_t * p_sss) { uint8_t battery_level = battery_level_get(); uint32_t err_code = NRF_SUCCESS; ble_gatts_value_t gatts_value; if (battery_level != p_sss->battery_level_last) { // Initialize value struct. memset(&gatts_value, 0, sizeof(gatts_value)); gatts_value.len = sizeof(uint8_t); gatts_value.offset = 0; gatts_value.p_value = (uint8_t *)(&battery_level); // Save new battery value. p_sss->battery_level_last = battery_level; // Update database. err_code = sd_ble_gatts_value_set(p_sss->conn_handle, p_sss->battery_level_char_handles.value_handle, &gatts_value); if (err_code != NRF_SUCCESS) { return err_code; } }
which further depends on "battery_level_get" as follows:
uint8_t battery_level_get(void)
// Configure ADC
NRF_ADC->CONFIG = (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos) |
(ADC_CONFIG_INPSEL_SupplyOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) |
(ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) |
(ADC_CONFIG_PSEL_Disabled << ADC_CONFIG_PSEL_Pos) |
(ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos);
NRF_ADC->EVENTS_END = 0;
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
NRF_ADC->EVENTS_END = 0; // Stop any running conversions.
NRF_ADC->TASKS_START = 1;
while (!NRF_ADC->EVENTS_END)
uint16_t vbg_in_mv = 1200;
uint8_t adc_max = 255;
uint16_t vbat_current_in_mv = (NRF_ADC->RESULT * 3 * vbg_in_mv) / adc_max;
NRF_ADC->TASKS_STOP = 1;
return (uint8_t) ((vbat_current_in_mv * 100) / VBAT_MAX_IN_MV);
Here is how I add battery level characteristic:
static uint32_t battery_level_char_add(ble_sss_t * p_sss, const ble_sss_init_t * p_sss_init) {
ble_gatts_char_md_t char_md; // characteristic metadata
ble_gatts_attr_t attr_char_value; // the value of characteristics (GATT attribute type)
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md; // attribute metadata
uint8_t battery_level = p_sss_init->battery_level;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 0;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = NULL;
char_md.p_sccd_md = NULL;
ble_uuid.type = p_sss->uuid_type;
ble_uuid.uuid = SSS_UUID_CHAR_BATTERY_LEVEL;
// Setting the 2nd attribute (the value of characteristics)
// First set up the attribute metadata, and then add it to attribute
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
attr_char_value.p_value = (uint8_t *)(&battery_level);
return sd_ble_gatts_characteristic_add(p_sss->service_handle, &char_md,
&attr_char_value,
&p_sss->battery_level_char_handles);
I initially pass value 50 to the battery_level variable in "battery_level_char_add" (via p_sss_init) so the initial value is 50 (or whatever the initial value I set). I expect it to be updated when the timer times out in main.c. However, it doesn't happen --- the value just stays 50 when I read the characteristic with Master Control Panel app.
I also test "battery_level_get" by calling it in BLE advertising initialization and send it out in advertising packet. The value is 87 which is very reasonable. So "battery_level_get" works.
