Zigbee switch
I'm trying to modify the light bulb example and turn it into a light switch (not a light switch that controls another bulb in the network), but I'm quite new on the Zigbee API and on the nRF52 development.
My main goal is to toggle a relay (in this example emulated by LED2_G).
The code right now looks like this:
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup zigbee_examples_light_bulb main.c
 * @ingroup zigbee_examples
 * @brief Dimmable light sample (HA profile)
#include "sdk_config.h"
#include "zboss_api.h"
#include "zboss_api_addons.h"
#include "zb_error_handler.h"
#include "zb_nrf52_internal.h"
#include "zigbee_helpers.h"
#include "bsp.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_gpiote.h"
#define MAX_CHILDREN                      10                                    /**< The maximum amount of connected devices. Setting this value to 0 disables association to this device.  */
#define IEEE_CHANNEL_MASK                 (1l << ZIGBEE_CHANNEL)                /**< Scan only one, predefined channel to find the coordinator. */
#define HA_SWITCH_ENDPOINT                10                                    /**< Device endpoint, used to receive light controlling commands. */
#define ERASE_PERSISTENT_CONFIG           ZB_FALSE                              /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
/* Basic cluster attributes initial values. */
#define BULB_INIT_BASIC_APP_VERSION       01                                    /**< Version of the application software (1 byte). */
#define BULB_INIT_BASIC_STACK_VERSION     10                                    /**< Version of the implementation of the Zigbee stack (1 byte). */
#define BULB_INIT_BASIC_HW_VERSION        11                                    /**< Version of the hardware of the device (1 byte). */
#define BULB_INIT_BASIC_MANUF_NAME        "Test"                                /**< Manufacturer name (32 bytes). */
#define BULB_INIT_BASIC_MODEL_ID          "Switchv0"                            /**< Model number assigned by manufacturer (32-bytes long string). */
#define BULB_INIT_BASIC_DATE_CODE         "20180416"                            /**< First 8 bytes specify the date of manufacturer of the device in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific. */
#define BULB_INIT_BASIC_POWER_SOURCE      ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE   /**< Type of power sources available for the device. For possible values see section 3.2.2.2.8 of ZCL specification. */
#define BULB_INIT_BASIC_LOCATION_DESC     "Office desk"                         /**< Describes the physical location of the device (16 bytes). May be modified during commisioning process. */
#define BULB_INIT_BASIC_PH_ENV            ZB_ZCL_BASIC_ENV_UNSPECIFIED          /**< Describes the type of physical environment. For possible values see section 3.2.2.2.10 of ZCL specification. */
#ifdef  BOARD_PCA10059                                                          /**< If it is Dongle */
#define IDENTIFY_MODE_BSP_EVT             BSP_EVENT_KEY_0                       /**< Button event used to enter the Bulb into the Identify mode. */
#define ZIGBEE_NETWORK_STATE_LED          BSP_BOARD_LED_0                       /**< LED indicating that light switch successfully joind Zigbee network. */
#else
#define IDENTIFY_MODE_BSP_EVT             BSP_EVENT_KEY_3                       /**< Button event used to enter the Bulb into the Identify mode. */
#define ZIGBEE_NETWORK_STATE_LED          BSP_BOARD_LED_2                       /**< LED indicating that light switch successfully joind Zigbee network. */
#if !defined ZB_ROUTER_ROLE
#error Define ZB_ROUTER_ROLE to compile light bulb (Router) source code.
#define LED2_G         NRF_GPIO_PIN_MAP(1,9)
/* Main application customizable context. Stores all settings and static values. */
typedef struct
    zb_zcl_basic_attrs_ext_t         basic_attr;
    zb_zcl_identify_attrs_t          identify_attr;
    zb_zcl_on_off_attrs_ext_t        on_off_attr;
} switch_device_ctx_t;
static switch_device_ctx_t m_dev_ctx;
/******************* Declare attributes ************************/
/* Switch config cluster attributes data */
zb_uint8_t attr_switch_type = ZB_ZCL_ON_OFF_SWITCH_CONFIGURATION_SWITCH_TYPE_TOGGLE;
zb_uint8_t attr_switch_actions = ZB_ZCL_ON_OFF_SWITCH_CONFIGURATION_SWITCH_ACTIONS_DEFAULT_VALUE;
ZB_ZCL_DECLARE_ON_OFF_SWITCH_CONFIGURATION_ATTRIB_LIST(switch_cfg_attr_list, &attr_switch_type, &attr_switch_actions);
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
                                     &m_dev_ctx.basic_attr.zcl_version,
                                     &m_dev_ctx.basic_attr.app_version,
                                     &m_dev_ctx.basic_attr.stack_version,
                                     &m_dev_ctx.basic_attr.hw_version,
                                     m_dev_ctx.basic_attr.mf_name,
                                     m_dev_ctx.basic_attr.model_id,
                                     m_dev_ctx.basic_attr.date_code,
                                     &m_dev_ctx.basic_attr.power_source,
                                     m_dev_ctx.basic_attr.location_id,
                                     &m_dev_ctx.basic_attr.ph_env,
                                     m_dev_ctx.basic_attr.sw_ver);
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &m_dev_ctx.identify_attr.identify_time);
/********************* Declare device **************************/
ZB_HA_DECLARE_ON_OFF_SWITCH_CLUSTER_LIST(on_off_switch_clusters, switch_cfg_attr_list, basic_attr_list, identify_attr_list);
ZB_HA_DECLARE_ON_OFF_SWITCH_EP(on_off_switch_ep, HA_SWITCH_ENDPOINT, on_off_switch_clusters);
ZB_HA_DECLARE_ON_OFF_SWITCH_CTX(on_off_switch_ctx, on_off_switch_ep);
static void log_init(void)
static void gpio_init(void)
    ret_code_t err_code;
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(LED2_G, &out_config);
/**@brief Function for turning ON/OFF the light bulb.
 * @param[in]   on   Boolean light bulb state.
static void on_off_set_value(zb_bool_t on)
    NRF_LOG_INFO("Set ON/OFF value: %i", on);
    ZB_ZCL_SET_ATTRIBUTE(HA_SWITCH_ENDPOINT,
                         ZB_ZCL_CLUSTER_ID_ON_OFF,
                         ZB_ZCL_CLUSTER_SERVER_ROLE,
                         ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID,
                         (zb_uint8_t *)&on,
                         ZB_FALSE);
    if (on)
        nrf_drv_gpiote_out_set(LED2_G);
       nrf_drv_gpiote_out_clear(LED2_G);
/**@brief Callback for button events.
 * @param[in]   evt      Incoming event from the BSP subsystem.
static void buttons_handler(bsp_event_t evt)
    zb_ret_t zb_err_code;
    switch(evt)
        case IDENTIFY_MODE_BSP_EVT:
            /* Check if endpoint is in identifying mode, if not put desired endpoint in identifying mode. */
            if (m_dev_ctx.identify_attr.identify_time == ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE)
                NRF_LOG_INFO("Bulb put in identifying mode");
                zb_err_code = zb_bdb_finding_binding_target(HA_SWITCH_ENDPOINT);
                ZB_ERROR_CHECK(zb_err_code);
                NRF_LOG_INFO("Cancel F&B target procedure");
                zb_bdb_finding_binding_target_cancel();
            NRF_LOG_INFO("Unhandled BSP Event received: %d", evt);
/**@brief Function for initializing LEDs and a single PWM channel.
static void buttons_init(void)
    /* Initialize all and buttons. */
    err_code = bsp_init(BSP_INIT_BUTTONS, buttons_handler);
    /* By default the bsp_init attaches BSP_KEY_EVENTS_{0-4} to the PUSH events of the corresponding buttons. */
/**@brief Function for initializing all clusters attributes.
static void switch_clusters_attr_init(void)
    /* Basic cluster attributes data */
    m_dev_ctx.basic_attr.zcl_version   = ZB_ZCL_VERSION;
    m_dev_ctx.basic_attr.app_version   = BULB_INIT_BASIC_APP_VERSION;
    m_dev_ctx.basic_attr.stack_version = BULB_INIT_BASIC_STACK_VERSION;
    m_dev_ctx.basic_attr.hw_version    = BULB_INIT_BASIC_HW_VERSION;
    /* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
     * contain string length without trailing zero.
     * For example "test" string wil be encoded as:
     *   [(0x4), 't', 'e', 's', 't']
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.mf_name,
                          BULB_INIT_BASIC_MANUF_NAME,
                          ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MANUF_NAME));
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.model_id,
                          BULB_INIT_BASIC_MODEL_ID,
                          ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MODEL_ID));
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.date_code,
                          BULB_INIT_BASIC_DATE_CODE,
                          ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_DATE_CODE));
    m_dev_ctx.basic_attr.power_source = BULB_INIT_BASIC_POWER_SOURCE;
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.location_id,
                          BULB_INIT_BASIC_LOCATION_DESC,
                          ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_LOCATION_DESC));
    m_dev_ctx.basic_attr.ph_env = BULB_INIT_BASIC_PH_ENV;
    /* Identify cluster attributes data */
    m_dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
    /* On/Off cluster attributes data */
    m_dev_ctx.on_off_attr.on_off = (zb_bool_t)ZB_ZCL_ON_OFF_IS_ON;
                         (zb_uint8_t *)&m_dev_ctx.on_off_attr.on_off,
                         ZB_FALSE);
/**@brief Function which tries to sleep down the MCU
 * Function which sleeps the MCU on the non-sleepy End Devices to optimize the power saving.
 * The weak definition inside the OSIF layer provides some minimal working template
zb_void_t zb_osif_go_idle(zb_void_t)
    //TODO: implement your own logic if needed
    zb_osif_wait_for_event();
/**@brief Callback function for handling ZCL commands.
 * @param[in]   bufid   Reference to Zigbee stack buffer used to pass received data.
static zb_void_t zcl_device_cb(zb_bufid_t bufid)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_zcl_device_callback_param_t * p_device_cb_param = ZB_BUF_GET_PARAM(bufid, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_LEVEL_CONTROL_SET_VALUE_CB_ID:
            NRF_LOG_INFO("Level control setting to %d", p_device_cb_param->cb_param.level_control_set_value_param.new_value);
            //level_control_set_value(p_device_cb_param->cb_param.level_control_set_value_param.new_value);
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_ON_OFF)
                uint8_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data8;
                NRF_LOG_INFO("on/off attribute setting to %hd", value);
                if (attr_id == ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID)
                    on_off_set_value((zb_bool_t) value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
/**@brief Zigbee stack event handler.
 * @param[in]   bufid   Reference to the Zigbee stack buffer used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
    /* Update network status LED */
    zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
    /* No application-specific behavior is required. Call default signal handler. */
    ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
    if (bufid)
        zb_buf_free(bufid);
/**@brief Function for application main entry.
    zb_ieee_addr_t ieee_addr;
    /* Initialize timer, logging system and GPIOs. */
    log_init();
    buttons_init();
    gpio_init();
    /* Set Zigbee stack logging level and traffic dump subsystem. */
    ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
    ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
    ZB_SET_TRAF_DUMP_OFF();
    /* Initialize Zigbee stack. */
    ZB_INIT("led_bulb");
    /* Set device address to the value read from FICR registers. */
    zb_osif_get_ieee_eui64(ieee_addr);
    zb_set_long_address(ieee_addr);
    /* Set static long IEEE address. */
    zb_set_network_router_role(IEEE_CHANNEL_MASK);
    zb_set_max_children(MAX_CHILDREN);
    zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
    zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
    /* Initialize application context structure. */
    UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
    /* Register callback for handling ZCL commands. */
    ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
    /* Register dimmer switch device context (endpoints). */
    ZB_AF_REGISTER_DEVICE_CTX(&on_off_switch_ctx);
    switch_clusters_attr_init();
    /** Start Zigbee Stack. */
    zb_err_code = zboss_start_no_autostart();
    while(1)
        zboss_main_loop_iteration();
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
Any idea on why this isn't working? Did I miss something on the endpoint declaration?
Thanks!
