Pairing without entering the PIN
H,
I have a problem, that I can connect to my BT device without entering the PIN upon first paring.
The device is based on nRF52832 and I followed peripheral_sc_only sample, which I found sets the correct security level for required pairing.
I am using: Zephyr OS build v2.4.0-ncs1
Here is also my prj.conf (there are also other settings, but I believe those are important for mandatory pairing):
# Enable settings
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable explicit pairing
CONFIG_BT_SMP=y
CONFIG_BT_SMP_SC_ONLY=y
CONFIG_BT_TINYCRYPT_ECC=y
CONFIG_BT_FIXED_PASSKEY=y
#CONFIG_BT_SMP_ENFORCE_MITM=y
CONFIG_BT_BONDING_REQUIRED=y
When I use nRF Connect on my phone, I can see the device on the Scan tab and if I click connect, the dialog for pairing appears, but also the services discovered.
If I click Cancel and quickly on one of the services discovered, I can then click on all of them and can send data to my device.
Is there any other option I need to turn on, so I can make paring "really" mandatory?
Matej
  • I have build our application for nrf52833dk (using Segger Embedded Studio and selected nrf52833dk_nrf528333 under board name) and I uploaded the elf and hex file here.
    Please let us know if this is O.K. with you and you can reproduce the test.
    Thanks;
    Matej
  • sorry about the late reply, we were very thinly staffed here during Easter and now recovering from it. I will test you elf and hex today
  • I am able to reproduce this. I think the issue here are two things
    1) The connection is not disconnected even after pairing failure. Must a simple configurable thing, i should look what configuration needs to be changed here.
    2) Pairing is started after discovery is initiated, so even when pairing is failed, the phone has the connection ongoing and you can see the discovered services (which happened on unencrypted link)
    You can change the code a bit to start pairing before discovery procedure is started, so that discovery will only be done on the encrypted link and also to disconnect if pairing failed.
    If you can attach your project you ported for nRF52833 (the project you used to make those elf and hex file) I can try to make the changes for you and upload here.
    thank you, glad that you were able to reproduce this.
    So for you suggestions mentioned above:
    1) If you find a configuration option, that would be great
    2) If there is an example how to achieve this already in some sample code, than I can check this and fix it. Otherwise, I'll try to make a simple project as possible that will expose this behavior (need to remove some custom files) and will send it to you. But, if there is already available example, I'd prefer that.
    Probably we need to advertise only dive name in the beginning and only after the paring is done, we should advertise all the services?
    Thanks and BR,
    Matej
     Yes, This is normally the case when you do not want anyone to view or discover your services on an unencrypted link. The change for this is trivial, that you just need to move the pairing initiate process just after the connection is established.
