Pairing without entering the PIN
H,
I have a problem, that I can connect to my BT device without entering the PIN upon first paring.
The device is based on nRF52832 and I followed peripheral_sc_only sample, which I found sets the correct security level for required pairing.
I am using: Zephyr OS build v2.4.0-ncs1
Here is also my prj.conf (there are also other settings, but I believe those are important for mandatory pairing):
# Enable settings
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable explicit pairing
CONFIG_BT_SMP=y
CONFIG_BT_SMP_SC_ONLY=y
CONFIG_BT_TINYCRYPT_ECC=y
CONFIG_BT_FIXED_PASSKEY=y
#CONFIG_BT_SMP_ENFORCE_MITM=y
CONFIG_BT_BONDING_REQUIRED=y
When I use nRF Connect on my phone, I can see the device on the Scan tab and if I click connect, the dialog for pairing appears, but also the services discovered.
If I click Cancel and quickly on one of the services discovered, I can then click on all of them and can send data to my device.
Is there any other option I need to turn on, so I can make paring "really" mandatory?
Matej
  • I have removed all not necessary stuff from the project and just left two source files in it.
    I have uploaded it here.
    If you can have a look and tell us what we need to change so one cannot discover (or send anything) to device if paring is not completed successfully we'd appreciate it.
    Thnaks,
    Matej
    Thank you for attaching that. I will try to modify the project so that the pairing happens before discovery.
  • Matej,
    I have missed to see this basic point about service declaration
    A service declaration is an Attribute with the Attribute Type set to the UUID for
    «Primary Service» or «Secondary Service». The Attribute Value shall be the
    16-bit Bluetooth UUID or 128-bit UUID for the service, known as the service
    UUID. A client shall support the use of both 16-bit and 128-bit UUIDs. A client
    may ignore any service definition with an unknown service UUID. An unknown
    service UUID is a UUID for an unsupported service. The Attribute Permissions
    shall be read-only and shall not require authentication or authorization.
    The service will always have read permission only and the IOS can discover them even before encryption. It is the central/phone that initiates the service discovery and your product being a slave cannot control this. It need to respond to the service discovery by showing the services but not the contents of it.
    I have changed the declaration of the attributes so that the values can be read only after encryption.
    /* UART Service Declaration */
    BT_GATT_SERVICE_DEFINE(nus_svc,
    BT_GATT_PRIMARY_SERVICE(BT_UUID_NUS_SERVICE),
    	BT_GATT_CHARACTERISTIC(BT_UUID_NUS_TX,
    			       BT_GATT_CHRC_NOTIFY,
    			       BT_GATT_PERM_READ_ENCRYPT,
    			       NULL, NULL, NULL),
    	BT_GATT_CCC(NULL, BT_GATT_PERM_READ_ENCRYPT | BT_GATT_PERM_READ_AUTHEN | BT_GATT_PERM_WRITE_AUTHEN),
    	BT_GATT_CHARACTERISTIC(BT_UUID_NUS_RX,
    			       BT_GATT_CHRC_WRITE |
    			       BT_GATT_CHRC_WRITE_WITHOUT_RESP,
    			       BT_GATT_PERM_READ_ENCRYPT | BT_GATT_PERM_WRITE_ENCRYPT,
    			       NULL, on_receive, NULL),
    Also if the connection fails, disconnect as below in ae_bt_conn.c
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
      LOG_INF("Pairing failed and hence disconnecting conn: %s, reason %d", log_strdup(addr),
          reason);
      bt_conn_disconnect(conn, BT_HCI_ERR_AUTH_FAIL);
  • Hi Susheel,
    thank you for this.
    I tried what you suggested (modified the code for NUS in ncs/nrf/subsys/bluetooth/services/nus.c) and added disconnect call if failing fails.
    Now, even if I manage to click on NUS service in the APP, I cannot send any data to it.
    It is working as expected now.
    Thanks again and BR,
    Matej
  • Hi Susheel,
    I'm having a similar problem using an nRF52840-DK (with Zephyr).  I'd like to operate the board as a peripheral which requires a passkey for pairing.  Using two different scanner apps on Android, I'm able to see all the characteristics in the services offered before entering the pin.  I've tried following the modifications in this thread, but I still can't get hidden characteristics.    Would you be able to help me?
    Best,
    PJ
