Keep USB enabled while in bootloader
I am using SDK_15.2.0 and softdevice S140_v6_1_1.
Host communicate with 52840 via USB (CDC UART). Doing firmware update with proprietary message format.
Stored new image in flash (Bank_1) and change bootloader setting and reset device to update new image through bootloader code.
Problem is USB disable when we jump to bootloader code to update new image as I used only BLE supported bootloader but I want to keep USB active while in bootloader code.
I have added USB support in bootloader and but not able to keep USB enabled when bootloader copying new firmware from BANK_1 --> BANK_0.
Getting issue as host system disconnect power to nRF52840 when USB get disabled.
Just want to keep USB enabled in bootloader code.
Nirav Patel
    The USB would need to re-enumerate when you reset or jump to from/to application/bootloader. If you are having issues with re-enumerating, then maybe you could try to call nrf_drv_usbd_disable() before you reset/jump.
  • Thanks Sigurd,
    Does not facing issue what you suggest to do. Let me explain in detail.
    I am using application with BLE+USB support and Bootloader with BLE only. So what happen when I update application via BLE bootloader (Jump to bootloader using NRF_BL_DFU_ENTER_METHOD_GPREGRET = 1), USB getting disabled when bootloader start running. To keep USB active I have added USB driver in BLE supported bootloader so I able to keep USB active while advertising in bootloader.
    Problem is after receiving image of new firmware, bootloader reset the device to copy new image from BANK1 --> Bank_0 at that time bootloader will not activate any transport layer just copying new image and reset device again to boot new image from BANK_0.
    I want to make USB enabled for whole the time like while in application and bootloader.
    Step_1: In application (USB is active)
    Step_2: Bootloader with BLE+USB (USB is active (As I added USB driver in BL)
    Step_3: After receiving image via BLE bootloader device reset to apply new image (USB is active till reset)
    Step_4: Bootloader copying image (USB is disabled)
    If I will mange to enabled USB in step_4 my issue will be resolved.
    Nirav Patel
  • Since the bootloader resets the device, the USB will also be reset. I don't think it's possible to change this.
