I'm totally new to programming nRF DK's.
What am I using?
- Segger Embbedded Studio for ARM (Nordic Edition)
- Toolchain: nRF Connect SDK v1.4.99-dev1
- The "mqtt-simple" example
The goal is to receive data via mqtt and send it by using UART to a external device. The mqtt-simple example has been tested, it works. But I can't figure out how to send even a hard coded string via UART to my PC (Putty and a FT23R USB UART)
I hoped adding these two lines to the main.c would do the trick, but they don't.
* Copyright (c) 2018 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <drivers/uart.h>
#include <string.h>
#include <random/rand32.h>
#include <net/mqtt.h>
#include <net/socket.h>
#include <modem/lte_lc.h>
#include <logging/log.h>
#if defined(CONFIG_MODEM_KEY_MGMT)
#include <modem/modem_key_mgmt.h>
#if defined(CONFIG_LWM2M_CARRIER)
#include <lwm2m_carrier.h>
#include <dk_buttons_and_leds.h>
#include "certificates.h"
LOG_MODULE_REGISTER(mqtt_simple, CONFIG_MQTT_SIMPLE_LOG_LEVEL);
/* Buffers for MQTT client. */
static uint8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* File descriptor */
static struct pollfd fds;
#if defined(CONFIG_MQTT_LIB_TLS)
static int certificates_provision(void)
int err = 0;
LOG_INF("Provisioning certificates");
#if defined(CONFIG_BSD_LIBRARY) && defined(CONFIG_MODEM_KEY_MGMT)
err = modem_key_mgmt_write(CONFIG_MQTT_TLS_SEC_TAG,
MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
CA_CERTIFICATE,
strlen(CA_CERTIFICATE));
if (err) {
LOG_ERR("Failed to provision CA certificate: %d", err);
return err;
#elif defined(CONFIG_BOARD_QEMU_X86) && defined(CONFIG_NET_SOCKETS_SOCKOPT_TLS)
err = tls_credential_add(CONFIG_MQTT_TLS_SEC_TAG,
TLS_CREDENTIAL_CA_CERTIFICATE,
CA_CERTIFICATE,
sizeof(CA_CERTIFICATE));
if (err) {
LOG_ERR("Failed to register CA certificate: %d", err);
return err;
return err;
#endif /* defined(CONFIG_MQTT_LIB_TLS) */
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
LOG_ERR("bsdlib recoverable error: %u", (unsigned int)err);
#endif /* defined(CONFIG_BSD_LIBRARY) */
K_SEM_DEFINE(carrier_registered, 0, 1);
int lwm2m_carrier_event_handler(const lwm2m_carrier_event_t *event)
switch (event->type) {
case LWM2M_CARRIER_EVENT_BSDLIB_INIT:
LOG_INF("LWM2M_CARRIER_EVENT_BSDLIB_INIT");
case LWM2M_CARRIER_EVENT_CONNECTING:
LOG_INF("LWM2M_CARRIER_EVENT_CONNECTING");
case LWM2M_CARRIER_EVENT_CONNECTED:
LOG_INF("LWM2M_CARRIER_EVENT_CONNECTED");
case LWM2M_CARRIER_EVENT_DISCONNECTING:
LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTING");
case LWM2M_CARRIER_EVENT_DISCONNECTED:
LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTED");
case LWM2M_CARRIER_EVENT_BOOTSTRAPPED:
LOG_INF("LWM2M_CARRIER_EVENT_BOOTSTRAPPED");
case LWM2M_CARRIER_EVENT_REGISTERED:
LOG_INF("LWM2M_CARRIER_EVENT_REGISTERED");
k_sem_give(&carrier_registered);
case LWM2M_CARRIER_EVENT_DEFERRED:
LOG_INF("LWM2M_CARRIER_EVENT_DEFERRED");
case LWM2M_CARRIER_EVENT_FOTA_START:
LOG_INF("LWM2M_CARRIER_EVENT_FOTA_START");
case LWM2M_CARRIER_EVENT_REBOOT:
LOG_INF("LWM2M_CARRIER_EVENT_REBOOT");
case LWM2M_CARRIER_EVENT_LTE_READY:
LOG_INF("LWM2M_CARRIER_EVENT_LTE_READY");
case LWM2M_CARRIER_EVENT_ERROR:
LOG_ERR("LWM2M_CARRIER_EVENT_ERROR: code %d, value %d",
((lwm2m_carrier_event_error_t *)event->data)->code,
((lwm2m_carrier_event_error_t *)event->data)->value);
LOG_WRN("Unhandled LWM2M_CARRIER_EVENT: %d", event->type);
return 0;
#endif /* defined(CONFIG_LWM2M_CARRIER) */
/**@brief Function to print strings without null-termination
static void data_print(uint8_t *prefix, uint8_t *data, size_t len)
char buf[len + 1];
memcpy(buf, data, len);
buf[len] = 0;
LOG_INF("%s%s", log_strdup(prefix), log_strdup(buf));
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
struct mqtt_publish_param param;
param.message.topic.qos = qos;
param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
param.message.payload.data = data;
param.message.payload.len = len;
param.message_id = sys_rand32_get();
param.dup_flag = 0;
param.retain_flag = 0;
data_print("Publishing: ", data, len);
LOG_INF("to topic: %s len: %u",
CONFIG_MQTT_PUB_TOPIC,
(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
return mqtt_publish(c, ¶m);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
struct mqtt_topic subscribe_topic = {
.topic = {
.utf8 = CONFIG_MQTT_SUB_TOPIC,
.size = strlen(CONFIG_MQTT_SUB_TOPIC)
.qos = MQTT_QOS_1_AT_LEAST_ONCE
const struct mqtt_subscription_list subscription_list = {
.list = &subscribe_topic,
.list_count = 1,
.message_id = 1234
LOG_INF("Subscribing to: %s len %u", CONFIG_MQTT_SUB_TOPIC,
(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
if (length > sizeof(payload_buf)) {
return -EMSGSIZE;
return mqtt_readall_publish_payload(c, payload_buf, length);
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
const struct mqtt_evt *evt)
int err;
switch (evt->type) {
case MQTT_EVT_CONNACK:
if (evt->result != 0) {
LOG_ERR("MQTT connect failed: %d", evt->result);
LOG_INF("MQTT client connected");
subscribe();
case MQTT_EVT_DISCONNECT:
LOG_INF("MQTT client disconnected: %d", evt->result);
case MQTT_EVT_PUBLISH: {
const struct mqtt_publish_param *p = &evt->param.publish;
LOG_INF("MQTT PUBLISH result=%d len=%d",
evt->result, p->message.payload.len);
err = publish_get_payload(c, p->message.payload.len);
if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE) {
const struct mqtt_puback_param ack = {
.message_id = p->message_id
/* Send acknowledgment. */
mqtt_publish_qos1_ack(&client, &ack);
if (err >= 0) {
data_print("Received: ", payload_buf,
/* Echo back received data */
data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
payload_buf, p->message.payload.len);
} else {
LOG_ERR("publish_get_payload failed: %d", err);
LOG_INF("Disconnecting MQTT client...");
err = mqtt_disconnect(c);
if (err) {
LOG_ERR("Could not disconnect: %d", err);
} break;
case MQTT_EVT_PUBACK:
LOG_ERR("MQTT PUBACK error: %d", evt->result);
LOG_INF("PUBACK packet id: %u", evt->param.puback.message_id);
case MQTT_EVT_SUBACK:
LOG_ERR("MQTT SUBACK error: %d", evt->result);
LOG_INF("SUBACK packet id: %u", evt->param.suback.message_id);
case MQTT_EVT_PINGRESP:
LOG_ERR("MQTT PINGRESP error: %d", evt->result);
LOG_INF("Unhandled MQTT event type: %d", evt->type);
/**@brief Resolves the configured hostname and
* initializes the MQTT broker structure
static int broker_init(void)
int err;
struct addrinfo *result;
struct addrinfo *addr;
struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM
err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
if (err) {
LOG_ERR("getaddrinfo failed: %d", err);
return -ECHILD;
addr = result;
/* Look for address of the broker. */
while (addr != NULL) {
/* IPv4 Address. */
if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
struct sockaddr_in *broker4 =
((struct sockaddr_in *)&broker);
char ipv4_addr[NET_IPV4_ADDR_LEN];
broker4->sin_addr.s_addr =
((struct sockaddr_in *)addr->ai_addr)
->sin_addr.s_addr;
broker4->sin_family = AF_INET;
broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
ipv4_addr, sizeof(ipv4_addr));
LOG_INF("IPv4 Address found %s", log_strdup(ipv4_addr));
} else {
LOG_ERR("ai_addrlen = %u should be %u or %u",
(unsigned int)addr->ai_addrlen,
(unsigned int)sizeof(struct sockaddr_in),
(unsigned int)sizeof(struct sockaddr_in6));
addr = addr->ai_next;
/* Free the address. */
freeaddrinfo(result);
return err;
/**@brief Initialize the MQTT client structure
static int client_init(struct mqtt_client *client)
int err;
mqtt_client_init(client);
err = broker_init();
if (err) {
LOG_ERR("Failed to initialize broker connection");
return err;
/* MQTT client configuration */
client->broker = &broker;
client->evt_cb = mqtt_evt_handler;
client->client_id.utf8 = (uint8_t *)CONFIG_MQTT_CLIENT_ID;
client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
client->password = NULL;
client->user_name = NULL;
client->protocol_version = MQTT_VERSION_3_1_1;
/* MQTT buffers configuration */
client->rx_buf = rx_buffer;
client->rx_buf_size = sizeof(rx_buffer);
client->tx_buf = tx_buffer;
client->tx_buf_size = sizeof(tx_buffer);
/* MQTT transport configuration */
struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
LOG_INF("TLS enabled");
client->transport.type = MQTT_TRANSPORT_SECURE;
tls_cfg->peer_verify = CONFIG_MQTT_TLS_PEER_VERIFY;
tls_cfg->cipher_count = 0;
tls_cfg->cipher_list = NULL;
tls_cfg->sec_tag_count = ARRAY_SIZE(sec_tag_list);
tls_cfg->sec_tag_list = sec_tag_list;
tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
TLS_SESSION_CACHE_ENABLED :
TLS_SESSION_CACHE_DISABLED;
#else
/* TLS session caching is not supported by the Zephyr network stack */
tls_cfg->session_cache = TLS_SESSION_CACHE_DISABLED;
#else
client->transport.type = MQTT_TRANSPORT_NON_SECURE;
return err;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
fds.fd = c->transport.tcp.sock;
} else {
fds.fd = c->transport.tls.sock;
#else
return -ENOTSUP;
fds.events = POLLIN;
return 0;
static void button_handler(uint32_t button_states, uint32_t has_changed)
if (has_changed & button_states &
BIT(CONFIG_BUTTON_EVENT_BTN_NUM - 1)) {
int ret;
ret = data_publish(&client,
CONFIG_BUTTON_EVENT_PUBLISH_MSG,
sizeof(CONFIG_BUTTON_EVENT_PUBLISH_MSG)-1);
if (ret) {
LOG_ERR("Publish failed: %d", ret);
/**@brief Configures modem to provide LTE link. Blocks until link is
* successfully established.
static int modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
/* Do nothing, modem is already turned on
* and connected.
} else {
/* Wait for the LWM2M_CARRIER to configure the modem and
* start the connection.
LOG_INF("Waitng for carrier registration...");
k_sem_take(&carrier_registered, K_FOREVER);
LOG_INF("Registered!");
#else /* defined(CONFIG_LWM2M_CARRIER) */
int err;
LOG_INF("LTE Link Connecting...");
err = lte_lc_init_and_connect();
if (err) {
LOG_INF("Failed to establish LTE connection: %d", err);
return err;
LOG_INF("LTE Link Connected!");
#endif /* defined(CONFIG_LTE_LINK_CONTROL) */
/* Turn off power saving modes for a more responsive demo */
LOG_INF("Disabling PSM and eDRX");
lte_lc_psm_req(false);
lte_lc_edrx_req(false);
return 0;
void main(void)
int err;
uint32_t connect_attempt = 0;
LOG_INF("The MQTT simple sample started");
/* Configuring printer UART */
const struct device *printer_uart = device_get_binding("UART_2");
int uart_tx(printer_uart, "Printer\r\n", 9, SYS_FOREVER_MS);
err = certificates_provision();
if (err != 0) {
LOG_ERR("Failed to provision certificates");
return;
do {
err = modem_configure();
if (err) {
LOG_INF("Retrying in %d seconds",
CONFIG_LTE_CONNECT_RETRY_DELAY_S);
k_sleep(K_SECONDS(CONFIG_LTE_CONNECT_RETRY_DELAY_S));
} while (err);
err = client_init(&client);
if (err != 0) {
LOG_ERR("client_init: %d", err);
return;
dk_buttons_init(button_handler);
do_connect:
if (connect_attempt++ > 0) {
LOG_INF("Reconnecting in %d seconds...",
CONFIG_MQTT_RECONNECT_DELAY_S);
k_sleep(K_SECONDS(CONFIG_MQTT_RECONNECT_DELAY_S));
err = mqtt_connect(&client);
if (err != 0) {
LOG_ERR("mqtt_connect %d", err);
goto do_connect;
err = fds_init(&client);
if (err != 0) {
LOG_ERR("fds_init: %d", err);
return;
while (1) {
err = poll(&fds, 1, mqtt_keepalive_time_left(&client));
if (err < 0) {
LOG_ERR("poll: %d", errno);
err = mqtt_live(&client);
if ((err != 0) && (err != -EAGAIN)) {
LOG_ERR("ERROR: mqtt_live: %d", err);
if ((fds.revents & POLLIN) == POLLIN) {
err = mqtt_input(&client);
if (err != 0) {
LOG_ERR("mqtt_input: %d", err);
if ((fds.revents & POLLERR) == POLLERR) {
LOG_ERR("POLLERR");
if ((fds.revents & POLLNVAL) == POLLNVAL) {
LOG_ERR("POLLNVAL");
err = mqtt_disconnect(&client);
if (err) {
LOG_ERR("Could not disconnect MQTT client: %d", err);
goto do_connect;
Can someone guide my step by step on how to configure UART en send data?
Thanks in advance!
Kind Regards,
Lowie Lameire
