Project builds in Release mode, but not in Debug mode.
My project builds when set to Release, but fails when set to Debug. Here are the last few lines of the transcript output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.34/bin/mkld" -memory-map-segments "FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000" -section-placement-file flash_placement.xml -check-segment-overflow -symbols __STACKSIZE__=8192;__STACKSIZE_PROCESS__=0;__HEAPSIZE__=98304 -section-placement-macros FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x27000;FLASH_SIZE=0xd9000;RAM_START=0x20001d28;RAM_SIZE=0x3e2d8 C:/nRF52840/nRF5_SDK_17.0.2_d674dde/projects/ble_central/ble_scanner/pca10056/s140/ses/Output/Debug/Obj/ble_scanner/ble_scanner.ld
1> Linking ble_scanner.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.34/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__do_debug_operation=__do_debug_operation_mempoll -EL --defsym=__vfprintf=__vfprintf_float_long --defsym=__vfscanf=__vfscanf_long --gc-sections -TC:/nRF52840/nRF5_SDK_17.0.2_d674dde/projects/ble_central/ble_scanner/pca10056/s140/ses/Output/Debug/Obj/ble_scanner/ble_scanner.ld -Map Output/Debug/Exe/ble_scanner.map -u_vectors -o Output/Debug/Exe/ble_scanner.elf --emit-relocs --start-group @C:/nRF52840/nRF5_SDK_17.0.2_d674dde/projects/ble_central/ble_scanner/pca10056/s140/ses/Output/Debug/Obj/ble_scanner/ble_scanner.ind --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.34/gcc/arm-none-eabi/bin/ld: Output/Debug/Obj/ble_scanner/thumb_crt0.o: in function `memory_set':
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.34/source/thumb_crt0.s:287: undefined reference to `main'
Build failed
