Use nrfx QSPI with Zephyr filesystem
I'm using Zephyr on a nRF52840 and I'd like to use the QSPI with the Fat Filesystem.   I added the following Config statements to prj.conf:
# Filesystem
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_NRFX_QSPI=y
CONFIG_DISK_ACCESS=y
CONFIG_DISK_ACCESS_SDHC=y
CONFIG_DISK_ACCESS_SPI_SDHC=y
The nrfx QSPI driver and file system code is then included in the build, but I'm unsure how to associate the QSPI with the filesystem.    I don't see a "CONFIG_DISK_ACCESS_QSPI_SDHC" to replace the "CONFIG_DISK_ACCESS_SPI_SDHC".    Or is there a different way to do this that I'm missing?
Thanks!
  • I looked into this, and it does not seem like there is added any support for QSPI with FAT Fs. To give you a better overview I'll provide you the call stack:
    • main()-->disk_access_init()  |  zephyr\samples\subsys\fs\fat_fs\src\main.c
      • disk->ops->init(disk) | zephyr\subsys\disk\disk_access.c
        • disk_spi_sdhc_access_init()-->  | if CONFIG_DISK_ACCESS_SPI_SDHC=y it will use functions from zephyr\subsys\disk\disk_access_spi_sdhc.c
          • spi_release() | zephyr\include\drivers\spi.h
    At the blue layer, there are different choices for hardware interface, as you can see in zephyr/subsys/disk, but there is none for QSPI.
    One option would be to create a driver yourself, in zephyr/subsys/disk/disk_access_spi_sdhc.c.
    You could also use the API \zephyr\include\drivers\flash.h and set these in prj.conf:
    CONFIG_FLASH=y
    CONFIG_SPI=y
    CONFIG_NORDIC_QSPI_NOR=y
    You may also get some good answers if you ask in any of these Zephyr resources:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.4.0/zephyr/introduction/index.html#community-support
    Simon
  • OK...     I'll look into it further.   Thanks for the pointers!
  • Be aware that I don't have the best knowledge about this, and I may have overlooked/misunderstood something. You may get better answers if you ask in any of the mentioned Zephyr resources.
  • OK, thanks.
    I did find this link:   https://medium.com/home-wireless/implement-littlefs-for-qspi-flash-in-zephyr-37e591f86b48
    It appears to show how to use the QSPI with "littlefs" in Zephyr.    I have to admit that I haven't yet mastered the "device-tree" technology of Zephyr, so I'm not sure what is really happening here.  (I'm from the "old school" and am moving to Zephyr from FreeRTOS.   It seems like a lot of "stuff" happens in some hidden space and I find it hard to trace where this code is "generated" and when it executes!).   But I'm going to have to figure it out since, although I'm testing with nRF52480-DK, my application will be on a custom board...
    So perhaps this "littlefs" example can be used to make things work in FatFs.
    Thanks!
  • Simon,
    I've been looking into this and thought I'd try to get the SPI mode working, then see if I can modify disk_access_spi_sdhc.c to handle QSPI.
    Using one of the examples, I found that I needed to set:
    CONFIG_SPI=y
    CONFIG_SPI_2=y
    to get the appropriate drivers to load.   Since I'm already using TWIM1 (via CONFIG_NRFX_TWIM1=y) and needed to write my own handler so multiple threads can share the I2C, I use the statement:
    IRQ_CONNECT(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn,6,nrfx_isr,nrfx_twim_1_irq_handler,0);
    to catch the signal from the TWIM.    The TWIM handler seems to be working correctly...
    However, this seems to cause a conflict in the isr table.   When I compile with the SPI configs, I get the error:
    1> Combining ‘zephyr/isr_tables.c’
    1> gen_isr_tables.py: error: multiple registrations at table_index 4 for irq 4 (0x4)
    1> Existing handler 0x2ef09, new handler 0x2ef09
    1> Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
    Commenting out my IRQ_CONNECT call removes the error, but also removes my ability to catch the signal from TWIM1 for my handler.
    I seem to remember reading (somewhere) that nRF52840 serial peripherals share index numbers leading me to think that I should be using SPI2 for the SDcard access.    Do you know if the disk_access code hard codes using SPI1?  Or is there some other conflict causing the problem with the isr table?
    Thanks...
