SES NCS seem to build ok but throws "Error starting process echo"
Hi
When I try to build NCS sample using SES (v5.40, also v5.30a nordic edition) it seems to build the project correctly (.elf, hex are generated)
But it throws error at the very end (screenshot attached) "Error starting process echo".
What's the significance of this and how to resolve this issue? Please advise.
  • This is what I did, that helped me build successfully (no "Error starting process echo" thrown)
    From SES (*launched via nRF Connect > Toolchain Manager > Open IDE
    open any OpenThread example solution of your choice
    Build > Clean Solution
    close SES, Toolchain Manager and nRF Connect
    copy CMakeLists.txt (attached here) from openthread Github repo shared by Torsten earlier
    to following path ...\ncs\v1.4.2\modules\lib\openthread
    #  Copyright (c) 2019, The OpenThread Authors.
    #  All rights reserved.
    #  Redistribution and use in source and binary forms, with or without
    #  modification, are permitted provided that the following conditions are met:
    #  1. Redistributions of source code must retain the above copyright
    #     notice, this list of conditions and the following disclaimer.
    #  2. Redistributions in binary form must reproduce the above copyright
    #     notice, this list of conditions and the following disclaimer in the
    #     documentation and/or other materials provided with the distribution.
    #  3. Neither the name of the copyright holder nor the
    #     names of its contributors may be used to endorse or promote products
    #     derived from this software without specific prior written permission.
    #  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    #  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
    #  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
    #  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
    #  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
    #  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
    #  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
    #  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
    #  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
    #  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
    #  POSSIBILITY OF SUCH DAMAGE.
    cmake_policy(SET CMP0048 NEW)
    cmake_minimum_required(VERSION 3.10.2)
    file(READ .default-version OT_DEFAULT_VERSION)
    string(STRIP ${OT_DEFAULT_VERSION} OT_DEFAULT_VERSION)
    project(openthread VERSION ${OT_DEFAULT_VERSION})
    option(OT_BUILD_EXECUTABLES "Build executables" ON)
    option(OT_COVERAGE "enable coverage" OFF)
    set(OT_EXTERNAL_MBEDTLS "" CACHE STRING "Specify external mbedtls library")
    add_library(ot-config INTERFACE)
    target_include_directories(ot-config INTERFACE
        ${PROJECT_SOURCE_DIR}/include
        ${PROJECT_SOURCE_DIR}/src
        ${PROJECT_SOURCE_DIR}/src/core
    include(TestBigEndian)
    TEST_BIG_ENDIAN(OT_BIG_ENDIAN)
    if(OT_BIG_ENDIAN)
        target_compile_definitions(ot-config INTERFACE "BYTE_ORDER_BIG_ENDIAN=1")
    endif()
    include("${PROJECT_SOURCE_DIR}/etc/cmake/checks.cmake")
    include("${PROJECT_SOURCE_DIR}/etc/cmake/options.cmake")
    include("${PROJECT_SOURCE_DIR}/etc/cmake/functions.cmake")
    if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_C_COMPILER_ID MATCHES "(Apple)?[Cc]lang")
        option(OT_COMPILE_WARNING_AS_ERROR "whether to include -Werror -pedantic-errors with gcc-compatible compilers")
        if (OT_COMPILE_WARNING_AS_ERROR)
            set(OT_CFLAGS -Werror -pedantic-errors)
        endif()
        if(OT_COVERAGE)
            target_compile_definitions(ot-config INTERFACE "OPENTHREAD_ENABLE_COVERAGE=1")
            target_compile_options(ot-config INTERFACE -g -O0 --coverage)
            target_link_libraries(ot-config INTERFACE --coverage)
        endif()
        set(OT_CFLAGS
            $<$<COMPILE_LANGUAGE:C>:${OT_CFLAGS} -Wall -Wextra -Wshadow>
            $<$<COMPILE_LANGUAGE:CXX>:${OT_CFLAGS} -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions>
    endif()
    execute_process(
        COMMAND bash "-c" "third_party/nlbuild-autotools/repo/scripts/mkversion -b ${OT_DEFAULT_VERSION}"
        WORKING_DIRECTORY ${PROJECT_SOURCE_DIR}
        OUTPUT_VARIABLE OT_VERSION OUTPUT_STRIP_TRAILING_WHITESPACE
    message(STATUS "Version: ${OT_VERSION}")
        "PACKAGE_NAME=\"OPENTHREAD\""
        "PACKAGE_VERSION=\"${OT_VERSION}\""
    set(OT_THREAD_VERSION "1.1" CACHE STRING "Thread version chosen by the user at configure time")
    set_property(CACHE OT_THREAD_VERSION PROPERTY STRINGS "1.1" "1.2")
    if(${OT_THREAD_VERSION} EQUAL "1.1")
        target_compile_definitions(ot-config INTERFACE "OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1")
    elseif(${OT_THREAD_VERSION} EQUAL "1.2")
        target_compile_definitions(ot-config INTERFACE "OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_2")
    else()
        message(FATAL_ERROR "Thread version unknown: ${OT_THREAD_VERSION}")
    endif()
    set(OT_PLATFORM "NO" CACHE STRING "Target platform chosen by the user at configure time")
    ot_get_platforms(OT_PLATFORMS)
    set_property(CACHE OT_PLATFORM PROPERTY STRINGS ${OT_PLATFORMS})
    if(NOT OT_PLATFORM IN_LIST OT_PLATFORMS)
        message(FATAL_ERROR "Platform unknown: ${OT_PLATFORM}")
    endif()
    set(OT_LOG_OUTPUT_VALUES
        "APP"
        "DEBUG_UART"
        "NONE"
        "PLATFORM_DEFINED"
    if(OT_REFERENCE_DEVICE AND NOT OT_PLATFORM STREQUAL "posix")
        set(OT_LOG_OUTPUT "APP" CACHE STRING "Set log output to application for reference device")
    else()
        set(OT_LOG_OUTPUT "" CACHE STRING "Where log output goes to")
    endif()
    set_property(CACHE OT_LOG_OUTPUT PROPERTY STRINGS ${OT_LOG_OUTPUT_VALUES})
    if(OT_LOG_OUTPUT)
        if(NOT OT_LOG_OUTPUT IN_LIST OT_LOG_OUTPUT_VALUES)
            message(FATAL_ERROR "Log output unknown: ${OT_LOG_OUTPUT}")
        endif()
        target_compile_definitions(ot-config INTERFACE "OPENTHREAD_CONFIG_LOG_OUTPUT=OPENTHREAD_CONFIG_LOG_OUTPUT_${OT_LOG_OUTPUT}")
        message(STATUS "Log output: ${OT_LOG_OUTPUT}")
    endif()
    # OT_CONFIG allows users to specify the path to OpenThread project core
    # config header file. The default value of this parameter is empty string.
    # When not specified by user (value is ""), a platform cmake file may
    # choose to change this variable to provide its own core config header
    # file instead.
    set(OT_CONFIG "" CACHE STRING "OpenThread project-specific config header file chosen by user at configure time")
    list(APPEND OT_PUBLIC_INCLUDES ${PROJECT_BINARY_DIR}/etc/cmake)
    list(APPEND OT_PUBLIC_INCLUDES ${PROJECT_SOURCE_DIR}/etc/cmake)
    list(APPEND OT_PUBLIC_INCLUDES ${PROJECT_SOURCE_DIR}/include)
    if(OT_PLATFORM STREQUAL "posix")
        target_include_directories(ot-config INTERFACE ${PROJECT_SOURCE_DIR}/src/posix/platform)
        add_subdirectory("${PROJECT_SOURCE_DIR}/src/posix/platform")
    elseif(OT_PLATFORM)
        target_include_directories(ot-config INTERFACE ${PROJECT_SOURCE_DIR}/examples/platforms/${OT_PLATFORM})
        add_subdirectory("${PROJECT_SOURCE_DIR}/examples/platforms/${OT_PLATFORM}")
    endif()
    if(OT_CONFIG)
        target_compile_definitions(ot-config INTERFACE "OPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"${OT_CONFIG}\"")
        message(STATUS "Project core config: \"${OT_CONFIG}\"")
    endif()
    target_compile_definitions(ot-config INTERFACE ${OT_PLATFORM_DEFINES})
        if(OT_BUILD_EXECUTABLES)
            add_subdirectory(src/posix)
        else()
            add_subdirectory(src/posix EXCLUDE_FROM_ALL)
        endif()
    elseif(OT_PLATFORM)
        add_subdirectory(examples)
    endif()
    add_subdirectory(src)
    add_subdirectory(third_party EXCLUDE_FROM_ALL)
    if(OT_PLATFORM STREQUAL "simulation")
        enable_testing()
        add_subdirectory(tests)
    endif()
    #add_custom_target(print-ot-config ALL COMMAND echo -e "$<JOIN:$<TARGET_PROPERTY:ot-config,INTERFACE_COMPILE_DEFINITIONS>,\"\\n\">")
    add_custom_target(print-ot-config ALL cmake -E echo "$<JOIN:$<TARGET_PROPERTY:ot-config,INTERFACE_COMPILE_DEFINITIONS>,\"\\n\">")
    relaunch* SES
    From SES
    Project > Run CMake...
    Build > Build Solution
    That's it - no "Error starting process echo" for me now:) Hope this helps you too
  • The patch correctly avoids the issue with failing echo, but it also change the print of the message.
    OpenThread intends to print the text with each setting on a new line, like this:
    OPENTHREAD_CONFIG_ASSERT_ENABLE=1
    OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0
    OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0
    OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1
    OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1
    OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0
    OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0
    OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1
    OPENTHREAD_CONFIG_COAP_API_ENABLE=1
    Whereas the attached patch will print `\n` instead of a new line, like this:
    OPENTHREAD_CONFIG_ASSERT_ENABLE=1\nOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0\nOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0\n...
    when running CMake / ninja in a shell.
