Issue in requiring notifications of the Nordic Thingy:52
I'm trying to connect to a few sensors on the Nordic Thingy:52, and it fails with the following message: characteristic is not defined. The connection to the Thingy is established, but I can't get the notifications. I'm using the NRF52832 to connect to. In the Nordic documentation I found the 'EF68xxxx-9B35-4933-9B10-52FFA9740042' UUID, so I used it, replacing the xxxx by (f.i.) 0201. Any idea about the cause?
    What changes did you do, and where? Did you do any changes to the firmware code that is running on the nRF52?
     When and where do you see this message?
  • After receiving the nRF52, I activated the firmware update using the Nordic Thingy app, to v2.2.0). Message was 'completed'. So, except for updating the firmware, I didn't change anything of the device.
    I use some Javascript (appstore content, so not created by me) in a dev-tool Mendix for connecting to the device, and the connection with the device is successfull. But in retrieving the notifications the message 'characteristic is not defined' is generated. I presume that's a message from the device itself?
    The javascript uses the
    window.gattServer
    getPrimaryService(optionalServiceUUID)
    'ef680200-9b35-4933-9b10-52ffa9740042'
    getCharacteristic(characteristicUUID)
    'ef680201-9b35-4933-9b10-52ffa9740042'
    In the Nordic documentation I see:
    "To turn on sensor reading, enable notifications from the desired characteristic by writing 0x0001 to the Client Characteristic Configuration Descriptor (CCCD) for that characteristic."
    Is this what causes this behaviour?
    I used a demo on the Mendix website, where they used the Thingy without problems.
    (https://www.youtube.com/watch?v=_83HFXKeRSw , start about 7 minutes in the video)
  • I apologize, the issue is caused by a coding error in the javascript I used. That javacode was not correct for the Mendix version I used.
