Hello
I am using nrf52832 and ble_app_uart of SDK v17.0.
I am sending data to the app every second through the notify function. If I try to disconnect and reconnect Bluetooth while sending data like this, the connection will fail and stop working.
I tested sending data using the ble_app_uart example. Similarly, enabling notify will cause an error when reconnecting Bluetooth. (If notify is disabled, there is no problem reconnecting.)
I couldn't find any problems with debugging.
This is the code I used to send the data. Could there be a problem here?
// Enter main loop.
for (;;)
uint32_t err_code;
idle_state_handle();
//Send to app 1 and 2 test
int test1 = 1;
char test1_value[20];
sprintf(test1_value, "%d", test1);
uint16_t length_test1 = strlen(test1_value);
err_code = ble_nus_data_send(&m_nus, &test1_value, &length_test1, m_conn_handle);
int test2 = 2;
char test2_value[20];
sprintf(test2_value, "%d", test2);
uint16_t length_test2 = strlen(test2_value);
err_code = ble_nus_data_send(&m_nus, &test2_value, &length_test2, m_conn_handle);
nrf_delay_ms(500);
Is there anything known about this problem?
Thank you.
