Continuous periodic nRF52840 ADC sampling with Zephyr
Hello, guys.
We are using Zephyr RTOS (NCS v1.4.2) with nRF52840 development kit.
The idea is to have continuous ADC sampling on two ADC channels. So far, I was able to properly initialize the ADC device, and get one single ADC read with the following piece of code:
const struct adc_sequence sequence = {
	.channels = BIT(ADC_1ST_CHANNEL_ID),
	.buffer = m_sample_buffer,
	.buffer_size = sizeof(m_sample_buffer),
	.resolution = ADC_RESOLUTION,
ret = adc_read(adc_dev, &sequence);
if (ret) {
    printk("adc_read() failed with code %d\n", ret);
There is an issue even with this piece of code because, when I call adc_read(adc_dev, &sequence) function, only the first value of m_sample_buffer is updated, the rest of the m_sample_buffer values remain 0. What I am missing here?
Other than that, is there any way that we configure ADC device to do periodic sampling in the background without our intervention?
Thanks in advance for your time and efforts.
Sincerely,
Bojan.
  • Thank YOU for the great support!
    By the way, I am using an official version of nrfx_saadc drivers that can be found under:
    ncs/v1.4.2/modules/hal/nordic/nfrx/drivers/include
    You are playing with version 2 of the nrfx_saadc drivers in your repo (link). I noticed that nrfx_saadc_v2 is already included in nRF SDK 17.2 under:
    SDK_ROOT/modules/nrfx/drivers/include
    What is the difference between version 1 and version 2 of nrfx_saadc drivers? Is this version 2 already included in version 1.5.0 of nRF Connect SDK? Finally, do you recommend using version 2 for production code?
    Cheers,
    Bojan.
  • Hi Bojan,
    The SAADC driver was completely rewritten, so there are a number of differences. Generally, the version 2 SAADC driver includes more workarounds for HW limitations.,
    Yes. nRF Connect SDK includes nrfx 2.4.0.
    For NCS, you should use the one that tis part of the NCS vision you are using (which will be version 2.x.x these days). For the nRF5 SDK 17.x.x you can choose, but I recommend using the V2 API for the SAADC.
    Einar
  • Hello, Einar.
    I hope you are doing well. There is one strange thing I noticed recently while playing with ADC.
    It can happen that the ADC samples in buffer swap the position:
    As you can see above, I am sampling only two ADC channels. My configuration is similar like I found in your unofficial SAADC example:
    - There are two sampling buffers, both of size 2 (to store one ADC sample of each channel).
    In my particular use case, I am playing with ADC limits (both HIGH and LOW). This is working fine. For both ADC channels, I was able to set the limits and to get appropriate feedback through NRFX_SAADC_EVT_LIMIT in event_handler() function.
    The trouble sometimes comes when I want to read and process ADC samples. As you can see from the image above, the order of ADC samples in sampling buffer swaps only once, at the very beginning, and remains wrong for the rest of the application runtime.
    ADC sampling frequency when sample swapping occurs is equal to 1KHz. The time my application needs to read and process ADC samples is in order of 10-20us so I would not say this is an issue. The swapping occurs even when I just want to read ADC samples without any further data processing.
    When I slow down ADC sampling rate to 200Hz, let's say, the swapping of ADC samples does not happen.
    Do you have any idea what I am doing wrong?
    Thanks in advance for your time and efforts!
    Cheers!
    Bojan
    P.S. I did not find nrfx_saadc_v2.h in latest NCS v1.5.0
  • Hi Bojan,
    I did not get a chance to look at this today unfortunately, and I am out of office the whole next week. I can look more at this in one and a half week, but if that is not early enough I suggest you open a new case with this specific issue.
    Regarding not finding nrfx_saadc_v2.h in latest NCS v1.5.0 that is because the V2 API is the only API that is available there, so that is what you have in nrfx_saadc.h.
    Happy Easter!
    Einar
  • Hey, Einar.
    No worries. I dug deeper today and found a solution. This thread helped a lot. An additional PPI channel is needed to trigger the START task on END event! All is good for now!
    Thank you very much for your readiness to jump in and help!
    Happy Easter! Have a great holiday!
    Cheers,
    Bojan.
