NRF_EVT_POWER_FAILURE_WARNING event issue
I am using the Sys Events to monitor the POFWARN but it appear that I get a POFWARN event repeatedly when the voltage is below the threshold is this normal or do I need to clear the POFWARN system event?
static uint8_t counter = 0;
static void sys_evt_dispatch(uint32_t sys_evt)
    if (sys_evt == NRF_EVT_POWER_FAILURE_WARNING)
			switch (counter)
				case 0:
					LEDS_ON(BSP_LED_0_MASK);
					LEDS_OFF(BSP_LED_1_MASK|BSP_LED_2_MASK|BSP_LED_3_MASK);
					counter++;
				case 1:
					LEDS_ON(BSP_LED_1_MASK);
					LEDS_OFF(BSP_LED_0_MASK|BSP_LED_2_MASK|BSP_LED_3_MASK);
					counter++;
				case 2:
					LEDS_ON(BSP_LED_0_MASK|BSP_LED_1_MASK);
					LEDS_OFF(BSP_LED_2_MASK|BSP_LED_3_MASK);
					counter++;
				case 3:
					LEDS_ON(BSP_LED_2_MASK);
					LEDS_OFF(BSP_LED_0_MASK|BSP_LED_1_MASK|BSP_LED_3_MASK);
					counter++;
				case 4:
					LEDS_ON(BSP_LED_0_MASK|BSP_LED_2_MASK);
					LEDS_OFF(BSP_LED_1_MASK|BSP_LED_3_MASK);
					counter++;
				case 5:
					LEDS_ON(BSP_LED_1_MASK|BSP_LED_2_MASK);
					LEDS_OFF(BSP_LED_0_MASK|BSP_LED_3_MASK);
					counter++;
				case 6:
					counter++;
				case 7:
					LEDS_ON( BSP_LED_3_MASK);
					LEDS_OFF(BSP_LED_0_MASK|BSP_LED_1_MASK|BSP_LED_2_MASK);
					counter= 0;
					counter = 0;
ERRRTN gBatteryInit(void)
uint32_t   err_code;
err_code = sd_power_pof_enable(POWER_POFCON_POF_Enabled);
err_code = sd_power_pof_threshold_set(POWER_POFCON_THRESHOLD_V25);
// Subscribe for Sys events.
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
	LEDS_CONFIGURE(LEDS_MASK);
	counter = 0;
					LEDS_OFF(LEDS_MASK);
	return ERR_OK;
