Failed to start PPK
I have nrF52840 DK rev 2.0.1
switch to VDD, Default, SB40 is cut (confirmed by multimeter)
I have the PPK rev 1.1.1
switch DUT to DK
switch Power to DK
I can run the program with segger IDE (and only with PPK as i cut SB40)
nrfConnect is 3.6.1
OS : Windows 10
When i run Power Profiler (3.1.0) i can't connect the device.
Here is the log file :
2021-02-16T15:43:10.666Z INFO Application data folder: C:\Users\XXXXXX\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
2021-02-16T15:43:10.756Z DEBUG App pc-nrfconnect-ppk v3.1.0 official
2021-02-16T15:43:10.756Z DEBUG App path: C:\Users\XXXXXX\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk
2021-02-16T15:43:10.756Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.1)
2021-02-16T15:43:10.756Z DEBUG nRFConnect path: C:\Users\XXXXXX\AppData\Local\Programs\nrfconnect\resources\app.asar
2021-02-16T15:43:10.756Z DEBUG HomeDir: C:\Users\XXXXXX
2021-02-16T15:43:10.756Z DEBUG TmpDir: C:\Users\XXXXXX\AppData\Local\Temp
2021-02-16T15:43:11.669Z VERBOSE Could not fetch serial number for serial port at COM1
2021-02-16T15:43:13.929Z INFO Validating firmware for device with s/n 000683XXXXXX
2021-02-16T15:43:14.472Z INFO Opening device with s/n 000683XXXXXX
2021-02-16T15:43:14.565Z INFO Initializing the PPK
2021-02-16T15:43:14.979Z INFO SEGGER serial number: 683XXXXXX
2021-02-16T15:43:14.979Z INFO SEGGER speed: 2000 kHz
2021-02-16T15:43:14.979Z INFO SEGGER version: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 17 2020 14:43:00
2021-02-16T15:43:20.982Z ERROR Failed to start PPK
2021-02-16T15:43:20.983Z DEBUG Timed out in 6000 ms.
2021-02-16T15:43:21.065Z INFO PPK opened
2021-02-16T15:43:25.476Z ERROR Error while probing devices: Error occured when get serial numbers. Errorcode: Could not execute the function due to too many calls in line (0xe)
  • And it did the same on a mac book pro :
    2021-02-16T16:36:18.021Z INFO Application data folder: /Users/XXXXXX/Library/Application Support/nrfconnect/pc-nrfconnect-ppk
    2021-02-16T16:36:18.161Z DEBUG App pc-nrfconnect-ppk v3.1.0 official
    2021-02-16T16:36:18.161Z DEBUG App path: /Users/XXXXXX/.nrfconnect-apps/node_modules/pc-nrfconnect-ppk
    2021-02-16T16:36:18.161Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.1)
    2021-02-16T16:36:18.161Z DEBUG nRFConnect path: /Applications/nRF Connect.app/Contents/Resources/app.asar
    2021-02-16T16:36:18.161Z DEBUG HomeDir: /Users/XXXXXX
    2021-02-16T16:36:18.161Z DEBUG TmpDir: /var/folders/hl/763gb9ks7qs8_gcqnt1f2z0r0000gn/T/
    2021-02-16T16:36:18.872Z VERBOSE Could not fetch serial number for serial port at /dev/tty.Bluetooth-Incoming-Port
    2021-02-16T16:37:43.195Z INFO Validating firmware for device with s/nXXXXXX
    2021-02-16T16:37:44.196Z INFO Opening device with s/nXXXXXX
    2021-02-16T16:37:44.273Z INFO Initializing the PPK
    2021-02-16T16:37:44.859Z INFO SEGGER serial number:XXXXXX
    2021-02-16T16:37:44.859Z INFO SEGGER speed: 2000 kHz
    2021-02-16T16:37:44.859Z INFO SEGGER version: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 17 2020 14:43:00
    2021-02-16T16:37:50.860Z ERROR Failed to start PPK
    2021-02-16T16:37:50.860Z DEBUG Timed out in 6000 ms.
    2021-02-16T16:37:50.904Z INFO PPK opened
    2021-02-16T16:37:55.204Z ERROR Error while probing devices: Error occured when get serial numbers. Errorcode: Could not execute the function due to too many calls in line (0xe)
    Did you see the issue only recently after updating to v3.1.0? Could you try changing USB cable? We have seen that it has been the culprit before.
    regards
    Jared
  • I just start a new project with fresh devices and new softwares.
    I change the USB cable with no luck, and the
    USB cable seem to work as i can see debug log in the terminal and upload new code to the DK with or without PPK
    What is SW3 set to?
    Could you try to test it on another computer and see if you get the same issue?
    regards
    Jared
    SW3 is set to DK, i tested on 2 windows computer and a macos and it did the same result
