Failed to start PPK
I have nrF52840 DK rev 2.0.1
switch to VDD, Default, SB40 is cut (confirmed by multimeter)
I have the PPK rev 1.1.1
switch DUT to DK
switch Power to DK
I can run the program with segger IDE (and only with PPK as i cut SB40)
nrfConnect is 3.6.1
OS : Windows 10
When i run Power Profiler (3.1.0) i can't connect the device.
Here is the log file :
2021-02-16T15:43:10.666Z INFO Application data folder: C:\Users\XXXXXX\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
2021-02-16T15:43:10.756Z DEBUG App pc-nrfconnect-ppk v3.1.0 official
2021-02-16T15:43:10.756Z DEBUG App path: C:\Users\XXXXXX\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk
2021-02-16T15:43:10.756Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.1)
2021-02-16T15:43:10.756Z DEBUG nRFConnect path: C:\Users\XXXXXX\AppData\Local\Programs\nrfconnect\resources\app.asar
2021-02-16T15:43:10.756Z DEBUG HomeDir: C:\Users\XXXXXX
2021-02-16T15:43:10.756Z DEBUG TmpDir: C:\Users\XXXXXX\AppData\Local\Temp
2021-02-16T15:43:11.669Z VERBOSE Could not fetch serial number for serial port at COM1
2021-02-16T15:43:13.929Z INFO Validating firmware for device with s/n 000683XXXXXX
2021-02-16T15:43:14.472Z INFO Opening device with s/n 000683XXXXXX
2021-02-16T15:43:14.565Z INFO Initializing the PPK
2021-02-16T15:43:14.979Z INFO SEGGER serial number: 683XXXXXX
2021-02-16T15:43:14.979Z INFO SEGGER speed: 2000 kHz
2021-02-16T15:43:14.979Z INFO SEGGER version: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 17 2020 14:43:00
2021-02-16T15:43:20.982Z ERROR Failed to start PPK
2021-02-16T15:43:20.983Z DEBUG Timed out in 6000 ms.
2021-02-16T15:43:21.065Z INFO PPK opened
2021-02-16T15:43:25.476Z ERROR Error while probing devices: Error occured when get serial numbers. Errorcode: Could not execute the function due to too many calls in line (0xe)
