I'm developing for nRF52 DK
using SDK 17.02
Segger 5.10b
I'm developing a service to read pin 12 where I'll have a square wave signal of about 60Hz. When I tested my code using steady ground it worked fine. I could connect the ble and it was notifying the changes when i changed the signal on the pin.
When I went to do bench testing with real circuit and the signal it only works if i connect the ble before the signal starts. I'll have a steady high on the pin and then connect. After I connect all works well, but if I have the oscilating signal on my pin and try to load the firmware into the DK it crashes causing errors that most of the time wont even advertise. Sometime it advertises, but crash on connection attempt.
Here is the part of the code I think is causing the error.
static void tstat_timer_handler(void * p_context) {
ret_code_t err_code;
reading = nrf_gpio_pin_read(INPUT_PIN);
NRF_LOG_INFO("reading %d", reading);
if(reading) {
pin12Reading = (pin12Reading << 1) | 0x00;
}else {
pin12Reading = (pin12Reading << 1) | 0x01;
if(pin12Reading == 0) {
heatSignal = 0;
}else {
heatSignal = 1;
if((previousSignal != heatSignal)) {
previousSignal = heatSignal;
err_code = ble_tstat_on_heat_signal_change(m_conn_handle, &m_tstat, heatSignal);
NRF_LOG_INFO("pin12Reading %d", pin12Reading);
NRF_LOG_INFO("m_conn_handle %d", m_conn_handle);
heatsignal and previousSignal are set to 0 in the beginning of the code.
I've tried conditioning the execution of the hvx function to m_conn == 0 (I observed that initially this value is 16 bit on and after connection it changes to 0), but it didn't work
I've tried creating a variable so it would generate a delay, giving me time to connect before any notification function is called, but it didn't work also.
I wonder if the oscilating signal on pin 12 will cause problems during the initialization of other functions for BLE.
Is there a way to make this work perfectly?
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_template_main main.c
* @ingroup ble_sdk_app_template
* @brief Template project main file.
* This file contains a template for creating a new application. It has the code necessary to wakeup
* from button, advertise, get a connection restart advertising on disconnect and if no new
* connection created go back to system-off mode.
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "tstat.h"
#define DEVICE_NAME "TSTAT" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 0 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define INPUT_PIN 12
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_tstat_timer);
BLE_TSTAT_DEF(m_tstat);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
volatile uint8_t heatSignal = 0;
volatile uint8_t pin12Reading = 0;
volatile uint8_t previousSignal = 0;
volatile uint8_t reading = 0;
volatile uint8_t connected = 0;
/* YOUR_JOB: Declare all services structure your application is using
* BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
{TZC_SERVICE_UUID, BLE_UUID_TYPE_BLE}
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
if(reading) {
}else {
heatSignal = 0;
}else {
heatSignal = 1;
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
err_code = app_timer_create(&m_tstat_timer, APP_TIMER_MODE_REPEATED, tstat_timer_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
/* YOUR_JOB: Use an appearance value matching the application's use case.
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
APP_ERROR_CHECK(err_code); */
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
* YOUR_JOB implement a service handler function depending on the event the service you are using can generate
* @details This function will be called for all YY Service events which are passed to
* the application.
* @param[in] p_yy_service YY Service structure.
* @param[in] p_evt Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t * p_yy_service,
ble_yy_service_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_YY_NAME_EVT_WRITE:
APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
// No implementation needed.
ble_tstat_init_t tstat_init = {0};
err_code = ble_tstat_init(&m_tstat, &tstat_init);
/* YOUR_JOB: Add code to initialize the services used by the application.
ble_xxs_init_t xxs_init;
ble_yys_init_t yys_init;
// Initialize XXX Service.
memset(&xxs_init, 0, sizeof(xxs_init));
xxs_init.evt_handler = NULL;
xxs_init.is_xxx_notify_supported = true;
xxs_init.ble_xx_initial_value.level = 100;
err_code = ble_bas_init(&m_xxs, &xxs_init);
// Initialize YYY Service.
memset(&yys_init, 0, sizeof(yys_init));
yys_init.evt_handler = on_yys_evt;
yys_init.ble_yy_initial_value.counter = 0;
err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
/* YOUR_JOB: Start your timers. below is an example of how to start a timer.
err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
ret_code_t err_code = app_timer_start(m_tstat_timer, APP_TIMER_TICKS(10), NULL);
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, 4);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
uint32_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 4);
nrf_gpio_cfg_input(INPUT_PIN , NRF_GPIO_PIN_NOPULL);
// Enter main loop.
for (;;)
idle_state_handle();
#include <string.h>
#include "tstat.h"
static const uint8_t TSTATCharName[] = "TSTAT";
/**@brief Function for handling the Connect event.
* @param[in] p_led_service LED service structure.
* @param[in] p_ble_evt Event received from the BLE stack.
static void on_connect(ble_tstat_t * p_tstat, ble_evt_t const * p_ble_evt)
p_tstat->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
/**@brief Function for handling the Disconnect event.
* @param[in] p_bas LED service structure.
static void on_disconnect(ble_tstat_t * p_tstat, ble_evt_t const * p_ble_evt)
UNUSED_PARAMETER(p_ble_evt);
p_tstat->conn_handle = BLE_CONN_HANDLE_INVALID;
/**@brief Function for handling the Write event.
* @param[in] p_led_service LED Service structure.
static void on_write(ble_tstat_t * p_tstat, ble_evt_t const * p_ble_evt)
/**@brief Function for adding the LED 2 characteristic.
static uint32_t tstat_char_add(ble_tstat_t * p_tstat)
ble_gatts_char_md_t char_md;
ble_gatts_attr_t attr_char_value;
ble_gatts_attr_md_t attr_md;
ble_uuid_t ble_uuid;
memset(&char_md, 0, sizeof(char_md));
memset(&attr_md, 0, sizeof(attr_md));
memset(&attr_char_value, 0, sizeof(attr_char_value));
char_md.char_props.read = 1;
char_md.char_props.notify = 1;
char_md.p_char_user_desc = TSTATCharName;
char_md.char_user_desc_size = sizeof(TSTATCharName);
char_md.char_user_desc_max_size = sizeof(TSTATCharName);
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = NULL;
char_md.p_sccd_md = NULL;
// Define the LED 2 Characteristic UUID
ble_uuid.type = p_tstat->uuid_type;
ble_uuid.uuid = TZC_TSTAT_CHAR_UUID;
// Set permissions on the Characteristic value
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
// Attribute Metadata settings
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
// Attribute Value settings
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
attr_char_value.p_value = NULL;
return sd_ble_gatts_characteristic_add(p_tstat->service_handle, &char_md,
&attr_char_value,
&p_tstat->tstat_char_handles);
uint32_t ble_tstat_init(ble_tstat_t * p_tstat, const ble_tstat_init_t * p_tstat_init)
uint32_t err_code;
// Initialize service structure
// Add service UUID
ble_uuid128_t base_uuid = {TZC_SERVICE_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_tstat->uuid_type);
if (err_code != NRF_SUCCESS)
return err_code;
// Set up the UUID for the service (base + service-specific)
ble_uuid.uuid = TZC_SERVICE_UUID;
// Set up and add the service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_tstat->service_handle);
return err_code;
// Add the different characteristics in the service:
// Button press characteristic: E54B0002-67F5-479E-8711-B3B99198CE6C
err_code = tstat_char_add(p_tstat);
return err_code;
return NRF_SUCCESS;
void ble_tstat_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
ble_tstat_t * p_tstat = (ble_tstat_t *)p_context;
on_connect(p_tstat, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_tstat, p_ble_evt);
on_disconnect(p_tstat, p_ble_evt);
uint32_t ble_tstat_on_heat_signal_change(uint16_t conn_handle, ble_tstat_t * p_tstat, uint8_t heatSignal)
ble_gatts_hvx_params_t params;
uint16_t len = sizeof(heatSignal);
memset(¶ms, 0, sizeof(params));
params.type = BLE_GATT_HVX_NOTIFICATION;
params.handle = p_tstat->tstat_char_handles.value_handle;
params.p_data = &heatSignal;
params.p_len = &len;
return sd_ble_gatts_hvx(conn_handle, ¶ms);
