Receiver address correlation in BLE applications
Can anyone explain what the "receiver address correlation" from 2.4GHz Radio documentation means in practice?
For example, what can I do as a BLE application developer not to have a sensitivity loss?
Does the BLE stack handle the radio peripheral on it's own to avoid this?
If not, in which cases would the sensitivity loss appear?
Thanks in advance!
Ivan
  • Does the BLE stack handle the radio peripheral on it's own to avoid this?
    Yes, as long as you are using a radio library (BLE or other protocol) released by Nordic this is not something you need to consider. It is however something you should consider if you are making a bare-metal radio driver/stack.
    In short it is a hardware feature that can detect/recognize address at very low signal level (= effectively improve sensitivity by 3dB).
    Kenneth
