Hello Everyone,
I am developing a Zigbee-based device using nRF52840.
So far all functionalities are working without any problem. Now for device load detection, we are developing an initial sequence that reads ADC and depending on that procced for the next action.
Below are the steps which should be carried out for the initial sequence.
- Initial Sequence
An initial sequence is required at the start of the program (power-up or reset).
This is to determine the maximum duty cycle under the various operating conditions.
The reason for this is the power supply of the control circuit is no longer guaranteed with an increasing duty cycle in the 2 wire configuration.
The dimmer would toggle between a power down and the subsequent program start. To avoid this, the following steps are carried out:
_ Reset
_Gradually increase the duty cycle in small steps
_Voltage measurement after every increase
_ Shutdown of the load when a voltage at the input capacitor of
<100V with 2-wire operation
or 100% control of the load in 3-wire operation.
_Save this determined duty cycle value and declare it as 100%
_Turn off the bulb.
_ Turn ON the bulb till 30% brightness of the measured 100% and continue with normal program sequence.
Attached is the schematic for reference.
Attached is my main.c file where incorporated the above initial sequence steps.
The problem here is if I do the power-on sequence of Dev-kit and Custom hardware with custom code then I am not able to execute the initial sequence steps. For Dev-kit (USB power down power-up) and custom hardware (mains supply power down power-up). To execute the steps I have to press the RESET button present on Dev-kit as well as Custom hardware. But it should work first instant with power down power up steps.
I tried to check but in debug mode, it works but flashing the code doesn't work well.
One more method I tried to execute for the initial sequence, below is the attached code. Here I am able to do the power-on sequence without any problem but not able to read ADC values so I tried to add delay_ms() (ex 50msc) but after adding delay my other functionality got affected means LED while brightness incrementing or turning ON it starts flickering. Which not acceptable it should be the smooth end-user point. But without delay not able to read ADC. Let me know what is the problem. Attached is the code.
* Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup zigbee_examples_light_bulb main.c
* @ingroup zigbee_examples
* @brief Dimmable light sample (HA profile)
#include "sdk_config.h"
#include "zboss_api.h"
#include "zb_mem_config_med.h"
#include "zb_ha_dimmable_light.h"
#include "zb_error_handler.h"
#include "zb_nrf52840_internal.h"
#include "zigbee_helpers.h"
#include "bsp.h"
#include "boards.h"
#include "app_pwm.h"
#include "app_timer.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_gpiote.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_saadc.h"
#include "nrf_delay.h"
#define MAX_CHILDREN 10 /**< The maximum amount of connected devices. Setting this value to 0 disables association to this device. */
// /**< Scan only one, predefined channel to find the coordinator. */
#define IEEE_CHANNEL_MASK (ZB_TRANSCEIVER_ALL_CHANNELS_MASK)
#define HA_DIMMABLE_LIGHT_ENDPOINT 10 /**< Device endpoint, used to receive light controlling commands. */
#define ERASE_PERSISTENT_CONFIG ZB_FALSE /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
/* Basic cluster attributes initial values. */
#define BULB_INIT_BASIC_APP_VERSION 01 /**< Version of the application software (1 byte). */
#define BULB_INIT_BASIC_STACK_VERSION 10 /**< Version of the implementation of the ZigBee stack (1 byte). */
#define BULB_INIT_BASIC_HW_VERSION 11 /**< Version of the hardware of the device (1 byte). */
#define BULB_INIT_BASIC_MANUF_NAME "Nordic" /**< Manufacturer name (32 bytes). */
#define BULB_INIT_BASIC_MODEL_ID "Dimable_Light_v0.1" /**< Model number assigned by manufacturer (32-bytes long string). */
#define BULB_INIT_BASIC_DATE_CODE "20180416" /**< First 8 bytes specify the date of manufacturer of the device in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific. */
#define BULB_INIT_BASIC_POWER_SOURCE ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE /**< Type of power sources available for the device. For possible values see section 3.2.2.2.8 of ZCL specification. */
#define BULB_INIT_BASIC_LOCATION_DESC "Office desk" /**< Describes the physical location of the device (16 bytes). May be modified during commisioning process. */
#define BULB_INIT_BASIC_PH_ENV ZB_ZCL_BASIC_ENV_UNSPECIFIED /**< Describes the type of physical environment. For possible values see section 3.2.2.2.10 of ZCL specification. */
#define IDENTIFY_MODE_ENTER_BUTTON BSP_BOARD_BUTTON_0 /**< Enter the Bulb into the Identify mode. */
#ifdef BOARD_PCA10059 /**< If it is Dongle */
#define ZIGBEE_NETWORK_STATE_LED BSP_BOARD_LED_0 /**< LED indicating that light switch successfully joind ZigBee network. */
#else
#define ZIGBEE_NETWORK_STATE_LED BSP_BOARD_LED_3 /**< LED indicating that light switch successfully joind ZigBee network. */
/* Declare endpoint for Dimmable Light device with scenes. */
#define ZB_HA_DECLARE_LIGHT_EP(ep_name, ep_id, cluster_list) \
ZB_ZCL_DECLARE_HA_DIMMABLE_LIGHT_SIMPLE_DESC(ep_name, ep_id, \
ZB_HA_DIMMABLE_LIGHT_IN_CLUSTER_NUM, ZB_HA_DIMMABLE_LIGHT_OUT_CLUSTER_NUM); \
ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info## device_ctx_name, \
ZB_HA_DIMMABLE_LIGHT_REPORT_ATTR_COUNT); \
ZBOSS_DEVICE_DECLARE_LEVEL_CONTROL_CTX(cvc_alarm_info## device_ctx_name, \
ZB_HA_DIMMABLE_LIGHT_CVC_ATTR_COUNT); \
ZB_AF_DECLARE_ENDPOINT_DESC(ep_name, ep_id, ZB_AF_HA_PROFILE_ID, \
0, \
NULL, \
ZB_ZCL_ARRAY_SIZE(cluster_list, zb_zcl_cluster_desc_t),\
cluster_list, \
(zb_af_simple_desc_1_1_t*)&simple_desc_##ep_name, \
ZB_HA_DIMMABLE_LIGHT_REPORT_ATTR_COUNT, \
ZB_HA_DIMMABLE_LIGHT_CVC_ATTR_COUNT, \
cvc_alarm_info## device_ctx_name)
#if !defined ZB_ROUTER_ROLE
#error Define ZB_ROUTER_ROLE to compile light bulb (Router) source code.
/********************Custom MACRO Pin Mapping*******************************/
#define ZERO_CROSS_DETECTION NRF_GPIO_PIN_MAP(0,6) //ZCD pin
#define DIMMER_TRIGGER NRF_GPIO_PIN_MAP(0,8) //Trigger pin
#define EXTSW1_CONTROL BSP_BUTTON_1 //ExtSW1 pin
//#define EXTSW2_CONTROL NRF_GPIO_PIN_MAP(0,26) //EXtSW2 pin
#define KEY_UP NRF_GPIO_PIN_MAP(1,10) //Up pin
#define KEY_DOWN NRF_GPIO_PIN_MAP(1,13) //Down pin
//#define KEY_LEARN NRF_GPIO_PIN_MAP(0,24) //Learn pin
//#define OPTIONAL1_KEY NRF_GPIO_PIN_MAP(1,15) //Optional1 pin
//#define OPTIONAL2_KEY NRF_GPIO_PIN_MAP(0,2) //Optional2 pin
#define HALFCYCLE_10MSTIME 10000 //10msec for half cycle time
#define MAX_DUTYCYCLE 9000 //max duty cycle 9msec
#define MIN_ADC_VAL 78 //minimum adc value with repsective capacitor minimum voltage
void timer2_Configuration (void); //timer 2 configured as duty cycle timer
void timer2_DimmingControlling_tme(uint32_t ui32Timer2Dutycycle);
void timer1_Configuration (void); //timer 1 configured as fixed timer for negative cycle
void timer1_fixedtimeOperation (uint32_t ui32fixedtime);
/* Basic cluster attributes. */
typedef struct
zb_uint8_t zcl_version;
zb_uint8_t app_version;
zb_uint8_t stack_version;
zb_uint8_t hw_version;
zb_char_t mf_name[32];
zb_char_t model_id[32];
zb_char_t date_code[16];
zb_uint8_t power_source;
zb_char_t location_id[17];
zb_uint8_t ph_env;
zb_char_t sw_ver[17];
} bulb_device_basic_attr_t;
/* Identify cluster attributes. */
typedef struct
zb_uint16_t identify_time;
} bulb_device_identify_attr_t;
/* ON/Off cluster attributes. */
typedef struct
zb_bool_t on_off;
zb_bool_t global_scene_ctrl;
zb_uint16_t on_time;
zb_uint16_t off_wait_time;
} bulb_device_on_off_attr_t;
/* Level Control cluster attributes. */
typedef struct
zb_uint8_t current_level;
zb_uint16_t remaining_time;
} bulb_device_level_control_attr_t;
/* Scenes cluster attributes. */
typedef struct
zb_uint8_t scene_count;
zb_uint8_t current_scene;
zb_uint8_t scene_valid;
zb_uint8_t name_support;
zb_uint16_t current_group;
} bulb_device_scenes_attr_t;
/* Groups cluster attributes. */
typedef struct
} bulb_device_groups_attr_t;
/* Main application customizable context. Stores all settings and static values. */
typedef struct
bulb_device_basic_attr_t basic_attr;
bulb_device_identify_attr_t identify_attr;
bulb_device_scenes_attr_t scenes_attr;
bulb_device_groups_attr_t groups_attr;
bulb_device_on_off_attr_t on_off_attr;
bulb_device_level_control_attr_t level_control_attr;
} bulb_device_ctx_t;
/* constant declaration -----------------------------------------------*/
const nrf_drv_timer_t TIMER_1 = NRF_DRV_TIMER_INSTANCE(2); // Created instance as timer 1
const nrf_drv_timer_t TIMER_2 = NRF_DRV_TIMER_INSTANCE(4); // Created instance as timer 2
/*************GLOBAL VATIABLES***************************************/
uint32_t time2_ticks;
uint32_t ui32DimmerONTime = 0;
uint32_t CurrentDutyCycle = 0;
uint32_t ui32fixedtime = 0;
uint32_t ui32Brightness = 0;
uint32_t ui32PrevDutyCycle = 0;
bool boolIgnorelongpress = false;
//push button config variables
uint16_t ui8PushbuttonStatusCount = 0;
uint8_t ui8Pushbuttonstatus = 0;
bool boolpushbuttonStatus = false;
bool boolpushbuttonContinue = false;
bool boolBrightnesslevelcontrol = false;
bool boolNextZCDProcess = false;
//button_2 global variables
uint16_t ui16PushButton2Count = 0;
uint8_t ui8PushButton2status = 0;
bool boolPushButton2Status = false;
bool boolPushButton2Continue = false;
bool boolPushButton2BrightnessControl = false;
//button_3 global variables
uint16_t ui16PushButton3Count = 0;
uint8_t ui8PushButton3status = 0;
bool boolPushButton3Status = false;
bool boolPushButton3Continue = false;
bool boolPushButton3BrightnessControl = false;
//SAADC/ADC variables
uint16_t ui16CurrentADCValue = 255;
uint32_t ui32DutyCycle100 = MAX_DUTYCYCLE;
////Flag to monitor ADC value comparision with w. r. t. 0.7V while initial sequence implmentation
//bool boolADCComparisonComplete = true;
////Monitors ADC Reading while initial sequence implmentation
//bool boolADCReadingComplete = false;
////Flag indicating initial sequence operation or normal operation
bool boolInitialSequenceMeasurement = false;
bool boolSetInit30 = false;
float Val = 0, Val2=0;
uint32_t Result =0;
static nrf_saadc_value_t adc_buf[1];
/*************************END****************************************/
static bulb_device_ctx_t m_dev_ctx;
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &m_dev_ctx.identify_attr.identify_time);
ZB_ZCL_DECLARE_GROUPS_ATTRIB_LIST(groups_attr_list, &m_dev_ctx.groups_attr.name_support);
ZB_ZCL_DECLARE_SCENES_ATTRIB_LIST(scenes_attr_list,
&m_dev_ctx.scenes_attr.scene_count,
&m_dev_ctx.scenes_attr.current_scene,
&m_dev_ctx.scenes_attr.current_group,
&m_dev_ctx.scenes_attr.scene_valid,
&m_dev_ctx.scenes_attr.name_support);
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
&m_dev_ctx.basic_attr.zcl_version,
&m_dev_ctx.basic_attr.app_version,
&m_dev_ctx.basic_attr.stack_version,
&m_dev_ctx.basic_attr.hw_version,
m_dev_ctx.basic_attr.mf_name,
m_dev_ctx.basic_attr.model_id,
m_dev_ctx.basic_attr.date_code,
&m_dev_ctx.basic_attr.power_source,
m_dev_ctx.basic_attr.location_id,
&m_dev_ctx.basic_attr.ph_env,
m_dev_ctx.basic_attr.sw_ver);
/* On/Off cluster attributes additions data */
ZB_ZCL_DECLARE_ON_OFF_ATTRIB_LIST_EXT(on_off_attr_list,
&m_dev_ctx.on_off_attr.on_off,
&m_dev_ctx.on_off_attr.global_scene_ctrl,
&m_dev_ctx.on_off_attr.on_time,
&m_dev_ctx.on_off_attr.off_wait_time);
ZB_ZCL_DECLARE_LEVEL_CONTROL_ATTRIB_LIST(level_control_attr_list,
&m_dev_ctx.level_control_attr.current_level,
&m_dev_ctx.level_control_attr.remaining_time);
ZB_HA_DECLARE_DIMMABLE_LIGHT_CLUSTER_LIST(dimmable_light_clusters,
basic_attr_list,
identify_attr_list,
groups_attr_list,
scenes_attr_list,
on_off_attr_list,
level_control_attr_list);
ZB_HA_DECLARE_LIGHT_EP(dimmable_light_ep,
HA_DIMMABLE_LIGHT_ENDPOINT,
dimmable_light_clusters);
ZB_HA_DECLARE_DIMMABLE_LIGHT_CTX(dimmable_light_ctx,
dimmable_light_ep);
static void log_init(void)
/*********Brightness set command from Alexa or App*******************************************/
/**@brief Sets brightness of LED
* @param[in] brightness_level Brightness level, allowed values 0 ... 255, 0 - turn off, 255 - full brightness
static void light_bulb_onboard_set_brightness(zb_uint8_t brightness_level)
/* ZigBee level control cluster uses values from 0 up to 255. */
//Convert brigthness level values as per 0 to 100 range
ui32DimmerONTime = ((brightness_level * 100)/ 255);
//set brightness level to 100% Max
// CurrentDutyCycle = (((ui32DimmerONTime * 0.75) + 25) * 100);
CurrentDutyCycle = (ui32DimmerONTime * ui32DutyCycle100)/100;
/**@brief Sets brightness of bulb luminous executive element
static void light_bulb_set_brightness(zb_uint8_t brightness_level)
light_bulb_onboard_set_brightness(brightness_level);
/**@brief Function for setting the light bulb brightness.
* @param[in] new_level Light bulb brightness value.
static void level_control_set_value(zb_uint16_t new_level)
NRF_LOG_INFO("Set level value: %i", new_level);
ZB_ZCL_SET_ATTRIBUTE(HA_DIMMABLE_LIGHT_ENDPOINT,
ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL,
ZB_ZCL_CLUSTER_SERVER_ROLE,
ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID,
(zb_uint8_t *)&new_level,
ZB_FALSE);
/* According to the table 7.3 of Home Automation Profile Specification v 1.2 rev 29, chapter 7.1.3. */
if (new_level == 0)
zb_uint8_t value = ZB_FALSE;
ZB_ZCL_CLUSTER_ID_ON_OFF,
ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID,
&value,
ZB_FALSE);
zb_uint8_t value = ZB_TRUE;
&value,
ZB_FALSE);
light_bulb_set_brightness(new_level);
/**@brief Function for turning ON/OFF the light bulb.
* @param[in] on Boolean light bulb state.
static void on_off_set_value(zb_bool_t on)
NRF_LOG_INFO("Set ON/OFF value: %i", on);
(zb_uint8_t *)&on,
ZB_FALSE);
if (on)
level_control_set_value(m_dev_ctx.level_control_attr.current_level);
light_bulb_set_brightness(0U);
boolIgnorelongpress = true;
/**@brief Function for initializing LEDs and a single PWM channel.
static void leds_buttons_init(void)
/* Initialize all LEDs*/
/* Configure board. */
/**@brief Function for initializing all clusters attributes.
static void bulb_clusters_attr_init(void)
/* Basic cluster attributes data */
m_dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION;
m_dev_ctx.basic_attr.app_version = BULB_INIT_BASIC_APP_VERSION;
m_dev_ctx.basic_attr.stack_version = BULB_INIT_BASIC_STACK_VERSION;
m_dev_ctx.basic_attr.hw_version = BULB_INIT_BASIC_HW_VERSION;
/* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
* contain string length without trailing zero.
* For example "test" string wil be encoded as:
* [(0x4), 't', 'e', 's', 't']
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.mf_name,
BULB_INIT_BASIC_MANUF_NAME,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MANUF_NAME));
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.model_id,
BULB_INIT_BASIC_MODEL_ID,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MODEL_ID));
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.date_code,
BULB_INIT_BASIC_DATE_CODE,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_DATE_CODE));
m_dev_ctx.basic_attr.power_source = BULB_INIT_BASIC_POWER_SOURCE;
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.location_id,
BULB_INIT_BASIC_LOCATION_DESC,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_LOCATION_DESC));
m_dev_ctx.basic_attr.ph_env = BULB_INIT_BASIC_PH_ENV;
/* Identify cluster attributes data */
m_dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
/* On/Off cluster attributes data */
m_dev_ctx.on_off_attr.on_off = (zb_bool_t)ZB_ZCL_ON_OFF_IS_ON;
m_dev_ctx.level_control_attr.current_level = ZB_ZCL_LEVEL_CONTROL_LEVEL_MAX_VALUE;
m_dev_ctx.level_control_attr.remaining_time = ZB_ZCL_LEVEL_CONTROL_REMAINING_TIME_DEFAULT_VALUE;
(zb_uint8_t *)&m_dev_ctx.on_off_attr.on_off,
ZB_FALSE);
(zb_uint8_t *)&m_dev_ctx.level_control_attr.current_level,
ZB_FALSE);
/**@brief Function which tries to sleep down the MCU
* Function which sleeps the MCU on the non-sleepy End Devices to optimize the power saving.
* The weak definition inside the OSIF layer provides some minimal working template
zb_void_t zb_osif_go_idle(zb_void_t)
//TODO: implement your own logic if needed
zb_osif_wait_for_event();
/**@brief Callback function for handling ZCL commands.
* @param[in] param Reference to ZigBee stack buffer used to pass received data.
static zb_void_t zcl_device_cb(zb_uint8_t param)
zb_uint8_t cluster_id;
zb_uint8_t attr_id;
zb_buf_t * p_buffer = ZB_BUF_FROM_REF(param);
zb_zcl_device_callback_param_t * p_device_cb_param =
ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
/* Set default response value. */
p_device_cb_param->status = RET_OK;
switch (p_device_cb_param->device_cb_id)
case ZB_ZCL_LEVEL_CONTROL_SET_VALUE_CB_ID:
NRF_LOG_INFO("Level control setting to %d", p_device_cb_param->cb_param.level_control_set_value_param.new_value);
level_control_set_value(p_device_cb_param->cb_param.level_control_set_value_param.new_value);
case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
attr_id = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
if (cluster_id == ZB_ZCL_CLUSTER_ID_ON_OFF)
uint8_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data8;
NRF_LOG_INFO("on/off attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID)
on_off_set_value((zb_bool_t) value);
else if (cluster_id == ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL)
uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
NRF_LOG_INFO("level control attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID)
level_control_set_value(value);
/* Other clusters can be processed here */
NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
p_device_cb_param->status = RET_ERROR;
NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
/**@brief ZigBee stack event handler.
* @param[in] param Reference to ZigBee stack buffer used to pass arguments (signal).
void zboss_signal_handler(zb_uint8_t param)
zb_zdo_app_signal_hdr_t * p_sg_p = NULL;
zb_zdo_app_signal_type_t sig = zb_get_app_signal(param, &p_sg_p);
zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(param);
zb_bool_t comm_status;
switch (sig)
case ZB_BDB_SIGNAL_DEVICE_FIRST_START:
case ZB_BDB_SIGNAL_DEVICE_REBOOT:
if (status == RET_OK)
NRF_LOG_INFO("Joined network successfully");
bsp_board_led_on(ZIGBEE_NETWORK_STATE_LED);
NRF_LOG_ERROR("Failed to join network. Status: %d", status);
bsp_board_led_off(ZIGBEE_NETWORK_STATE_LED);
comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
ZB_COMM_STATUS_CHECK(comm_status);
case ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY:
if (status != RET_OK)
NRF_LOG_WARNING("Production config is not present or invalid");
case ZB_ZDO_SIGNAL_LEAVE:
zb_zdo_signal_leave_params_t * p_leave_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_leave_params_t);
NRF_LOG_INFO("Network left. Leave type: %d", p_leave_params->leave_type);
NRF_LOG_ERROR("Unable to leave network. Status: %d", status);
/* Unhandled signal. For more information see: zb_zdo_app_signal_type_e and zb_ret_e */
NRF_LOG_INFO("Unhandled signal %d. Status: %d", sig, status);
if (param)
ZB_FREE_BUF_BY_REF(param);
/* This Initial sequence to carried out to measure the intensity level for light controlling
* with respect to voltage level at input capacitor.
static void InitialSequence(void)
ret_code_t err_code;
boolInitialSequenceMeasurement = true;
ui32Brightness = 0;
//read ADC value of capacitor
err_code = nrf_drv_saadc_sample();
while((ui16CurrentADCValue >= MIN_ADC_VAL) && (ui32Brightness <= ui32DutyCycle100))
ui32PrevDutyCycle = ui32Brightness;
ui32Brightness += 100;
nrf_drv_gpiote_in_event_enable(ZERO_CROSS_DETECTION,true); //enable ZCD
err_code = nrf_drv_saadc_sample();//trigger ADC
nrf_delay_ms(50); //adding delay able to read adc values
ui32DutyCycle100 = ui32PrevDutyCycle;
on_off_set_value(0U);
boolSetInit30 = true;
/***************************SAADC Configuration Start*********************************************/
/**@brief Function for handling the ADC interrupt.
* @details This function will fetch the conversion result from the ADC, convert the value into
* percentage and send it to peer.
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
uint32_t err_code;
ui16CurrentADCValue = p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
/**@brief Function for configuring ADC to do capacitor voltage conversion.
static void adc_configure(void)
nrf_drv_saadc_config_t saadc_config;
saadc_config.resolution = NRF_SAADC_RESOLUTION_8BIT; //8 bit resolution
saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_event_handler);
//singale shot and channel config
//If input range is 0 to 2.26V then set reference as VDD/4 and gain as 1/3
nrf_saadc_channel_config_t channel_config;
channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
channel_config.gain = NRF_SAADC_GAIN1_4;
channel_config.acq_time = NRF_SAADC_ACQTIME_10US;
channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;
channel_config.pin_p = NRF_SAADC_INPUT_AIN2;
channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
err_code = nrf_drv_saadc_channel_init(2, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
/***************************SAADC Configuration End*********************************************/
/***************************ZCD pin handler functions Start*********************************************/
void zcd_in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) //ZCD Interrupt Handler Routine
if(CurrentDutyCycle == 0) //if the duty cycle is zero then enable ZCD do not disable it
nrf_drv_gpiote_in_event_enable(ZERO_CROSS_DETECTION, true);
//disable ZCD event
nrf_drv_gpiote_in_event_disable(ZERO_CROSS_DETECTION);
if(!boolInitialSequenceMeasurement)
//Positive cycle operation
//Computation of Ramp up and Ramp down during brightness change
if(CurrentDutyCycle != ui32Brightness)
if(ui32Brightness < CurrentDutyCycle) //ui32Brightness is the current brightness value that is compared with user set value
ui32Brightness += 50; //increment brightness
if(ui32Brightness >= ui32DutyCycle100) //the maximum duty cycle is 10msec
ui32Brightness = ui32DutyCycle100;
if(ui32Brightness > CurrentDutyCycle)
ui32Brightness -= 50; //decrement brightness
if(ui32Brightness <= 0)
ui32Brightness = 0;
//start timer1 for 10msec timer to estimate negative cycle start
timer1_fixedtimeOperation(HALFCYCLE_10MSTIME); //timer 1 start for 10msec
if(ui32Brightness != 0) //User has turned off the light
if(ui32Brightness >= MAX_DUTYCYCLE) //duty cycle is more than 9ms
timer2_DimmingControlling_tme(MAX_DUTYCYCLE); //timer 2 started for brightness control
nrf_gpio_pin_write(DIMMER_TRIGGER,1); //when duty cycle is greater than 0 set trigger pin HIGH
timer2_DimmingControlling_tme(ui32Brightness); //timer 2 started for brightness control
nrf_gpio_pin_write(DIMMER_TRIGGER,0); //when duty cycle is 0 set trigger pin LOW
if(boolSetInit30)
Val = (ui32DutyCycle100*100)/MAX_DUTYCYCLE;
Val2 = ((Val*255)/100);
Result = (uint32_t)((Val2*30)/100);
m_dev_ctx.level_control_attr.current_level = Result;
/***************************ZCD pin handler functions End*********************************************/
/***************************Button1 pin handler functions Start*********************************************/
void button_in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//controlling logic using button press interrupt
boolpushbuttonStatus = true; // if the push button press detect then set flag true
boolBrightnesslevelcontrol = !boolBrightnesslevelcontrol; //toggle brightness control flag to increment/decrement level accordingly.
/***************************Button1 pin handler functions End*********************************************/
/***************************Button2 pin handler functions Start*********************************************/
void button2_in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//button_2 pressed turn ON the LED and Increment the brightness
boolPushButton2Status = true; //if the push button_2 press detect then set flag
boolPushButton2BrightnessControl = true;
/***************************Button2 pin handler functions End*********************************************/
/***************************Button3 pin handler functions Start*********************************************/
void button3_in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//button_3 pressed turn OFF the LED and Decrement the brightness
boolPushButton3Status = true; //if the push button_2 press detect then set flag
boolPushButton3BrightnessControl = true;
/***************************Button3 pin handler functions End*********************************************/
/********** timer 1 Configuration Start *************************************************/
* @brief Handler for timer events.
* timer1_event_handler function to turn OFF the bulb and disable the timer
void timer1_event_handler(nrf_timer_event_t event_type, void* p_context)
nrf_drv_timer_disable(&TIMER_1); //disable timer 1
//Negative cycle operation
boolNextZCDProcess = true; //set this flag for next zcd detection
//pushutton status check, below statements are executed when button_1 pressed
if(boolpushbuttonStatus) //check push button ststus flag is set or not
ui8Pushbuttonstatus = nrf_gpio_pin_read(EXTSW1_CONTROL); // if the button flag is set then read the push button pin status
if(ui8Pushbuttonstatus == 1) //if the push button pin is high then enter to check button press count
ui8PushbuttonStatusCount+=2; // increment the button press count
if(ui8PushbuttonStatusCount > 100) // if the button the press count is 100(1sec) then it is long press action
/*function to brightness control
* on long press, increment and decrement the light intensity with the level of 10%
if(boolBrightnesslevelcontrol) // if the brightness level flag flase then start incrementing till maximun brightness 100%
if(m_dev_ctx.level_control_attr.current_level < 230)
m_dev_ctx.level_control_attr.current_level = m_dev_ctx.level_control_attr.current_level + 13;
m_dev_ctx.level_control_attr.current_level = 230;
if(m_dev_ctx.level_control_attr.current_level >= 13)
m_dev_ctx.level_control_attr.current_level = m_dev_ctx.level_control_attr.current_level - 13;
m_dev_ctx.level_control_attr.current_level = 3;
boolpushbuttonContinue = true;
else if(ui8Pushbuttonstatus == 0) // if the push button oinb status is not set the enter loop to toggle the light status
if((ui8PushbuttonStatusCount >=15) && (ui8PushbuttonStatusCount <= 100) && (boolpushbuttonContinue == false)) // if the button press is single (between 400msec to 1sec) then toggle the light
//function to toggle the LED current state
//Off the LED
boolpushbuttonContinue = false; //set long press button flag false
ui8PushbuttonStatusCount = 0; //button press count zero
/***************Below statements are executed when button_2 pressed*****************************************/
if(boolPushButton2Status)
ui8PushButton2status = nrf_gpio_pin_read(KEY_UP);
if(ui8PushButton2status == 0)
ui16PushButton2Count +=2;
if(!boolIgnorelongpress) //ignore long press from up/down key when OFF
if(ui16PushButton2Count > 100) //Increment brightness when button_2 long press
if(boolPushButton2BrightnessControl)
boolPushButton2Continue = true;
else if(ui8PushButton2status == 1)
if((ui16PushButton2Count >=15) && (ui16PushButton2Count <= 100) && (boolPushButton2Continue == false))
level_control_set_value(m_dev_ctx.level_control_attr.current_level); //Turn On when button_2 short press
/***************Above statements are executed when button_2 pressed*****************************************/
/***************Below statements are executed when button_3 pressed*****************************************/
if(boolPushButton3Status)
ui8PushButton3status = nrf_gpio_pin_read(KEY_DOWN);
if(ui8PushButton3status == 0)
ui16PushButton3Count +=2;
if(ui16PushButton3Count > 100) //Decrement brightness when button_3 long press
if(boolPushButton3BrightnessControl)
boolPushButton3Continue = true;
else if(ui8PushButton3status == 1)
if((ui16PushButton3Count >=15) && (ui16PushButton3Count <= 100) && (boolPushButton3Continue == false))
//Turn Off when button_3 short press
/***************Above statements are executed when button_3 pressed*****************************************/
* @brief function for timer1 configurarion
* configure timer 1 with the frequency parameter set 1MHz
* Intialise the timer event handler and enable 10msec timer for Negative cycle
uint32_t err_code = NRF_SUCCESS;
//Configure TIMER_1 as 10msec timer
timer_cfg.frequency = 4; //set frequency 1MHz
err_code = nrf_drv_timer_init(&TIMER_1, &timer_cfg, timer1_event_handler);
if (err_code != NRF_SUCCESS)
// handle error condition
//fixed timer 1
uint32_t time1_ticks;
time1_ticks = nrf_drv_timer_us_to_ticks(&TIMER_1, ui32fixedtime);
nrf_drv_timer_extended_compare(
&TIMER_1, NRF_TIMER_CC_CHANNEL0, time1_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); //timer 1 configured as continous timer
nrf_drv_timer_clear(&TIMER_1);
nrf_drv_timer_enable(&TIMER_1);
/**********Negative Cycle timer Configuration End *************************************************/
/**********************Duty Cycle timer Configuration Start ********************************************/
* timer2_event_handler function to turn OFF the bulb and disable the timer
void timer2_event_handler(nrf_timer_event_t event_type, void* p_context) //Timer 2 interrupt handler
nrf_drv_timer_disable(&TIMER_2); //disable timer 2
nrf_gpio_pin_write(DIMMER_TRIGGER,0); //set trigger pin LOW
if(boolNextZCDProcess) //if negative cycle complete enable the ZCD event again for next interrupt
// enable ZCD event
* @brief function for timer2 configurarion
* configure timer 2 with the frequency parameter set 1MHz
* Intialise the timer event handler and enable 10msec to control the dimming effect
//Configure TIMER_2 as 0 to 10msec duty cycle timer
err_code = nrf_drv_timer_init(&TIMER_2, &timer_cfg, timer2_event_handler);
//timer2 dimming control time function
time2_ticks = nrf_drv_timer_us_to_ticks(&TIMER_2, ui32Timer2Dutycycle); //ui32Timer2Dutycycle is passed as duty cycle value 0 to 100%
&TIMER_2, NRF_TIMER_CC_CHANNEL0, time2_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); //timer 2 configured as continous timer
nrf_drv_timer_clear(&TIMER_2);
nrf_drv_timer_enable(&TIMER_2);
/**********************Duty Cycle timer Configuration End *************************************************/
/*************GPIO Configuration*******************************/
*function to configure ZCD, Tigger and Button pin
* Configure ZCD as Digital input pin (P0_6)
* Configure Trigger as Digital output pin (P0_8)
* Configure Button as Digital input pin (P1_9)
* Function : GPIO_pin_configuration(void);
static void GPIO_pin_configuration (void)
uint32_t err_code;
//Set ZCD pin as input pin and Configure ZCD handler
if(!nrf_drv_gpiote_is_init())
/**********Trigger pin Configuration Start *************************************************/
//Set Trigger pin as output pin
nrf_gpio_cfg_output(DIMMER_TRIGGER);
/**********Trigger pin Configuration End *************************************************/
/**********ZCD pin Configuration Start *************************************************/
nrf_drv_gpiote_in_config_t zcd_in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true); //raising edge detection
zcd_in_config.pull = NRF_GPIO_PIN_PULLUP; //configure ZCD pin as pull_up
err_code = nrf_drv_gpiote_in_init(ZERO_CROSS_DETECTION, &zcd_in_config, zcd_in_pin_handler);
/**********ZCD pin Configuration End *************************************************/
/**********Button1 pin Configuration Start *************************************************/
//Set Button1 pin as input pin and Configure Button handler
nrf_drv_gpiote_in_config_t button_in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
button_in_config.pull = NRF_GPIO_PIN_PULLDOWN; //configure button pin as pull_down
err_code = nrf_drv_gpiote_in_init(EXTSW1_CONTROL, &button_in_config, button_in_pin_handler);
nrf_drv_gpiote_in_event_enable(EXTSW1_CONTROL, true);
/**********Button1 pin Configuration End *************************************************/
/**********Button2 pin Configuration Start *************************************************/
//Set Button2 pin as input pin and Configure Button handler
nrf_drv_gpiote_in_config_t button2_in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
button2_in_config.pull = NRF_GPIO_PIN_PULLUP; //configure button pin as pull_up
err_code = nrf_drv_gpiote_in_init(KEY_UP, &button2_in_config, button2_in_pin_handler);
nrf_drv_gpiote_in_event_enable(KEY_UP, true);
/**********Button2 pin Configuration End *************************************************/
/**********Button3 pin Configuration Start *************************************************/
//Set Button3 pin as input pin and Configure Button handler
nrf_drv_gpiote_in_config_t button3_in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
button3_in_config.pull = NRF_GPIO_PIN_PULLUP; //configure button pin as pull_up
err_code = nrf_drv_gpiote_in_init(KEY_DOWN, &button3_in_config, button3_in_pin_handler);
nrf_drv_gpiote_in_event_enable(KEY_DOWN, true);
/**********Button3 pin Configuration End *************************************************/
/**@brief Function for application main entry.
zb_ret_t zb_err_code;
zb_ieee_addr_t ieee_addr;
/* Initialize timer, logging system and GPIOs. */
log_init();
leds_buttons_init();
GPIO_pin_configuration(); //GPIO initialization and configuration
timer2_Configuration(); //Timer 2 as duty cycle time configured
timer1_Configuration(); //Timer 1 as negative cycle timer
adc_configure(); //ADC intialization and configuration as channal 2, 8 bit resolution
/* Set ZigBee stack logging level and traffic dump subsystem. */
ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
ZB_SET_TRAF_DUMP_OFF();
/* Initialize ZigBee stack. */
ZB_INIT("led_bulb");
/* Set device address to the value read from FICR registers. */
zb_osif_get_ieee_eui64(ieee_addr);
zb_set_long_address(ieee_addr);
/* Set static long IEEE address. */
zb_set_network_router_role(IEEE_CHANNEL_MASK);
zb_set_max_children(MAX_CHILDREN);
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
/* Initialize application context structure. */
UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
/* Register callback for handling ZCL commands. */
ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
/* Register dimmer switch device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&dimmable_light_ctx);
bulb_clusters_attr_init();
// m_dev_ctx.level_control_attr.current_level = 77;
InitialSequence();
/** Start Zigbee Stack. */
zb_err_code = zboss_start();
ZB_ERROR_CHECK(zb_err_code);
while(1)
zboss_main_loop_iteration();
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
Can anyone help me where I am doing wrong.
Thanks in advance.
Rohit R
