Resets to dfutarg
Hi
Im using nrf51822 board from RedbearLab. SDK6.1and SD7.1.0.
I added DFU to my application and iam able to update the firmware OTA.
My issue is after adding dfu to my application, whenever i resets/power reset the board it starts advertising as dfu targ
Did anyone come across this situation ? How can i solve this issue?
Parents Reply
  • In the sample code.It goes to DFU in only two ways.Button 7 LOW or APP location is invaild.After DFU couled you goes to your APP ZONE?If yes,when you do reset does the button pull high?maybe you can try after DFU you connect the button 7 to VCC .Ensure that when you reset the pin is high. By the way,how do you go into DFU MODE?the button way?
