I am using NRFSDK 1702. I have one NRF52840 as central and multiple peripherals. The central receives data from the peripherals and then transmit the received data via hardware UART interface to the computer. The UART baud rate is set at 115,200. The UART initialization function at the NRF52840 (central) is as follows:
static void uart_init(void)
ret_code_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
Previously, the data length from the NRF52840 to the computer is less than 20 bytes each time and the UART is working well. Recently, I found one issue with the hardware UART: when the data length is at 240 a packet, then the UART transfer speed can not catch up and will cause the NRF52840 reset. If I lower the data rate from the peripheral to the central, then the NRF52840 central is working well.
The UART data transfer function is very simple (taken from the SDK examples):
static void uart_send(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
for (uint16_t i = 0; i < data_len; i++)
do{
ret_val=app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
APP_ERROR_CHECK(ret_val);
}while (ret_val == NRF_ERROR_BUSY);
The above function will error out when there are multiple data coming in. Is there a way to improve the UART speed? For example, how to transfer multiple bytes a time instead of just one byte a time via the UART function.
