Changes to the application for DFU
I am using SDK17, nRF52840 based custom board and SoftDevice 7.2.0 with SES.
I want to use SDK's secure bootloader (pca10056_s140_ble) with my own keys.
To enter to the bootloader I need to perform these functions and I have added them to my code.
err_code = sd_power_gpregret_clr(0, 0xffffffff);
err_code = sd_power_gpregret_set(0, 0xB1);
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
On bootup, the device shows up as DfuTarg, I can connect to it, upload the ZIP and the device runs perfectly. But to perform another OTA, when I connect to my own service and perform the above-given code portion, the device hangs. It does not enter DFU(I verified it by toggling an LED at the start of the bootloader ).
What else do I need to change in my application? As far as I know, I can not debug my application as there is a bootloader.
    Are you sure the gpregret register is actually set after the reset?  Try adding a check before you shut down, because these writes may take some time. Even after returning, it may not be complete.
    uint32_t gpregret_read_value = 0x00000000;
    while (gpregret_read_value != 0xB1)
        err_code = sd_power_gpregret_get(0, &gpregret_read_value);
    After trying this, then test out the _debug bootloader project (pca10056_s140_ble_debug), and monitor the RTT log. What does the log say in dfu_enter_check():
    static bool dfu_enter_check(void)
        if (!app_is_valid(crc_on_valid_app_required()))
            NRF_LOG_DEBUG("DFU mode because app is not valid.");
            return true;
        if (NRF_BL_DFU_ENTER_METHOD_BUTTON &&
           (nrf_gpio_pin_read(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN) == 0))
            NRF_LOG_DEBUG("DFU mode requested via button.");
            return true;
        if (NRF_BL_DFU_ENTER_METHOD_PINRESET &&
           (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk))
            NRF_LOG_DEBUG("DFU mode requested via pin-reset.");
            return true;
        if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
            NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
            return true;
        if (NRF_BL_DFU_ENTER_METHOD_BUTTONLESS &&
           (s_dfu_settings.enter_buttonless_dfu == 1))
            NRF_LOG_DEBUG("DFU mode requested via bootloader settings.");
            return true;
        return false;
    You can also set a breakpoint in:
            return true;
    And check what the gpregret is set to.
    BR,
    Edvin
  • Hello Edvin,
    Thanks for replying.
    Pardon me as I had an altogether different problem. I had NRF_LOG_ENABLED set to 1 which caused the problem when NRF_LOG_FINAL_FLUSH() was being called.
    Yet, your suggestion is useful (implemented as well) as shutting down the system before the GPREGRET register have been set can cause problem sometimes.
    Vishwas
