The project destroys the value of the conf file.
When I save the conf file with the following contents and select the corresponding project from `nRF Connect Options`, an error occurs and the project cannot be opened. Please tell me what to do.
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_LOG=y
CONFIG_LOG_IMMEDIATE=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_POWER_OPTIMIZATION_ENABLE=n
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_NBIOT=n
CONFIG_LTE_LEGACY_PCO_MODE=n
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
CONFIG_LTE_PSM_REQ_RAT="00000010"
CONFIG_LTE_LOCK_BANDS=y
# Enable band 2, 3, 4, 8, 12, 13 ,20 and 28
CONFIG_LTE_LOCK_BAND_MASK="1000000010000001100010001110"
# Modem info
CONFIG_MODEM_INFO=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# nRF Cloud
CONFIG_CLOUD_API=y
CONFIG_NRF_CLOUD=y
CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=y
CONFIG_NRF_CLOUD_AGPS=y
CONFIG_NRF_CLOUD_CONNECTION_POLL_THREAD=y
CONFIG_NRF_CLOUD_SEND_TIMEOUT=y
CONFIG_NRF_CLOUD_SEND_TIMEOUT_SEC=60
# Needed for the cloud codec
CONFIG_CJSON_LIB=y
# Shorter to prevent NAT timeouts
CONFIG_MQTT_KEEPALIVE=120
# Don't resubscribe to topics if broker remembers them
CONFIG_MQTT_CLEAN_SESSION=n
# Sensors
CONFIG_SENSOR=y
CONFIG_ACCEL_USE_EXTERNAL=y
CONFIG_ACCEL_DEV_NAME="ADXL362"
CONFIG_ADXL362=y
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
CONFIG_ADXL362_ABS_REF_MODE=1
CONFIG_ADXL362_ACTIVITY_THRESHOLD=200
CONFIG_ADXL362_INACTIVITY_THRESHOLD=200
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_TEMP_USE_EXTERNAL=y
CONFIG_TEMP_DEV_NAME="BME680"
# Deselect CONFIG_BME680 if CONFIG_USE_BME680_BSEC is selected
CONFIG_BME680=y
CONFIG_USE_BME680_BSEC=n
# GPS
CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
CONFIG_NRF9160_GPS=y
CONFIG_GPS_USE_EXTERNAL=y
CONFIG_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=30
CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n
CONFIG_GPS_START_ON_MOTION=y
CONFIG_AGPS=y
# Library for buttons and LEDs
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_INVERT_LEDS=n
# Library that maintains the current date time UTC.
CONFIG_DATE_TIME=y
# Console
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_HANDLER=y
CONFIG_CONSOLE_GETCHAR=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
# Settings
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_FCB=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# AWS FOTA
CONFIG_AWS_FOTA=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y
CONFIG_AWS_JOBS_LOG_LEVEL_DBG=y
CONFIG_DFU_TARGET=y
# Download client (needed by AWS FOTA)
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# Fatal error
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_WATCHDOG=y
# add for debug 20210119
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=y
# AES256
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_AES_C=y
# timer?
CONFIG_LEGACY_TIMEOUT_API=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
# Appliaction
CONFIG_MQTT_PUB_TOPIC="myPubTopic"
CONFIG_MQTT_SUB_TOPIC="mySubTopic"
CONFIG_MQTT_CLIENT_ID="myClientID"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxxxxxx.com"
CONFIG_MQTT_BROKER_PORT=8883
CONFIG_MQTT_KEEPALIVE=300
CONFIG_MQTT_TLS_SEC_TAG=16842753
  • Hello Øyvind!
    > What does the output tab in SES show when this error appears?
    Have you installed NCS via the Toolchain Manager?
    Please verify that your settings in SES are correct. Go to Tools --> Options --> nRF Connect are pointing to the correct folders.
    What settings are you using in the nRF Connect Options when opening your project?
    Note, you can also edit settings in prj.conf using the menuconfig option in SES. Project --> Configure "nRF Connect SDK project" --> menuconfig
  • Hello Øyvind!
    ->No, the dialog is only displayed, not in output.
    ->Yes.
    ->The folder specification was correct.
    ->nRF Connect SDK Release    = 1.4.2
      nRF Connect Toolchain Version   = 1.4.2
     Project    = asset_tracker
    [Getting Started][Short Range][Other Nordic Projects] is checked.
    Board Name:    =  thingy91_nrf9160ns
    [Nordic Thingy][Nordic kits] is checked.
    Build Directory    =   C:/nRFconnectSDK/v1.4.2/nrf/applications/asset_tracker/build_thingy91_nrf9160ns
    ->Thanks,How do I add MQTT parameters using the menuconfig option?
     Do you mean adding MQTT parameters to the Asset Tracker? This application is a demo application which is not suitable. I would recommend looking at the Simple MQTT sample
