The project destroys the value of the conf file.
When I save the conf file with the following contents and select the corresponding project from `nRF Connect Options`, an error occurs and the project cannot be opened. Please tell me what to do.
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_LOG=y
CONFIG_LOG_IMMEDIATE=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_POWER_OPTIMIZATION_ENABLE=n
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_NBIOT=n
CONFIG_LTE_LEGACY_PCO_MODE=n
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
CONFIG_LTE_PSM_REQ_RAT="00000010"
CONFIG_LTE_LOCK_BANDS=y
# Enable band 2, 3, 4, 8, 12, 13 ,20 and 28
CONFIG_LTE_LOCK_BAND_MASK="1000000010000001100010001110"
# Modem info
CONFIG_MODEM_INFO=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# nRF Cloud
CONFIG_CLOUD_API=y
CONFIG_NRF_CLOUD=y
CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=y
CONFIG_NRF_CLOUD_AGPS=y
CONFIG_NRF_CLOUD_CONNECTION_POLL_THREAD=y
CONFIG_NRF_CLOUD_SEND_TIMEOUT=y
CONFIG_NRF_CLOUD_SEND_TIMEOUT_SEC=60
# Needed for the cloud codec
CONFIG_CJSON_LIB=y
# Shorter to prevent NAT timeouts
CONFIG_MQTT_KEEPALIVE=120
# Don't resubscribe to topics if broker remembers them
CONFIG_MQTT_CLEAN_SESSION=n
# Sensors
CONFIG_SENSOR=y
CONFIG_ACCEL_USE_EXTERNAL=y
CONFIG_ACCEL_DEV_NAME="ADXL362"
CONFIG_ADXL362=y
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
CONFIG_ADXL362_ABS_REF_MODE=1
CONFIG_ADXL362_ACTIVITY_THRESHOLD=200
CONFIG_ADXL362_INACTIVITY_THRESHOLD=200
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_TEMP_USE_EXTERNAL=y
CONFIG_TEMP_DEV_NAME="BME680"
# Deselect CONFIG_BME680 if CONFIG_USE_BME680_BSEC is selected
CONFIG_BME680=y
CONFIG_USE_BME680_BSEC=n
# GPS
CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
CONFIG_NRF9160_GPS=y
CONFIG_GPS_USE_EXTERNAL=y
CONFIG_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=30
CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n
CONFIG_GPS_START_ON_MOTION=y
CONFIG_AGPS=y
# Library for buttons and LEDs
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_INVERT_LEDS=n
# Library that maintains the current date time UTC.
CONFIG_DATE_TIME=y
# Console
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_HANDLER=y
CONFIG_CONSOLE_GETCHAR=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
# Settings
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_FCB=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# AWS FOTA
CONFIG_AWS_FOTA=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y
CONFIG_AWS_JOBS_LOG_LEVEL_DBG=y
CONFIG_DFU_TARGET=y
# Download client (needed by AWS FOTA)
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# Fatal error
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_WATCHDOG=y
# add for debug 20210119
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=y
# AES256
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_AES_C=y
# timer?
CONFIG_LEGACY_TIMEOUT_API=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
# Appliaction
CONFIG_MQTT_PUB_TOPIC="myPubTopic"
CONFIG_MQTT_SUB_TOPIC="mySubTopic"
CONFIG_MQTT_CLIENT_ID="myClientID"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxxxxxx.com"
CONFIG_MQTT_BROKER_PORT=8883
CONFIG_MQTT_KEEPALIVE=300
CONFIG_MQTT_TLS_SEC_TAG=16842753
