Setting IO Capabilities with NCS
I've tried searching for some documentation on pairing IO capabilities with NCS/Zephyr but can't find any. I'm trying to modify the peripheral_hids_keyboard example to use "just works" pairing (no input no output device). Looking at the docs for bt_conn_auth_cb I thought simply removing the passkey_* and pairing_confirm callbacks would be sufficient, but pairing fails and I get "Security failed: <addr> (public) level 1 err 4" in the console output. The only reference I can see to IO capabilities is the "CONFIG_BT_SMP_ENFORCE_MITM" option (which is enabled in the example):
"With this option enabled, the Security Manager will set MITM option in the Authentication Requirements Flags whenever local IO Capabilities allow the generated key to be authenticated."
But I can't find any docs that detail how to specify those local IO capabilities.
What else do I need to do? Where is the documentation for this?
Parents Reply
  • I managed to get it working.
    # this can be left enabled
    CONFIG_BT_HIDS_DEFAULT_PERM_RW_ENCRYPT=y
    # we are using unauthenticated pairing
    CONFIG_BT_HIDS_DEFAULT_PERM_RW_AUTHEN=n
    # we do not want to enforce MITM as this requires authenticated pairing
    CONFIG_BT_SMP_ENFORCE_MITM=n
    # we want to overwrite old bonds from the same device (optional, security risk)
    CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
