More Frequent BLE Scan (Specifically, RSSI change) Results
I am working on a BLE Product which connects to a remote device when detected within a certain proximity (based on the RSSI values).
After switching on the scanning, I receive Scan Results almost every 2 seconds. The thing is I want the RSSI tracking to be smoother, 300 ms at max, so that connection is almost instantaneous when the device is found in the range. I have tried fiddling with the Scan Interval and Durations, but the frequency at which the application receives the scan results is unaffected. Can someone please give me some pointers on how that parameter can be changed?
    I see that the ticket is tagged with nRF5 SDK for Mesh. Is this a Bluetooth mesh application?
    In that case, please note that if you use the SoftDevice API (or nRF5 SDK libraries) for scanning, it will compete for radio time with the mesh stack.
    If you have a clean BLE application (no Bluetooth mesh) you can have a look at the Scheduling chapter of the SoftDevice Specification, in particular Suggested intervals and windows.
    If you use Bluetooth mesh, through nRF5 SDK for Mesh, then you can have a look at the scanner role implementation there, which has a callback that is showcased in the Beaconing example. With that, all advertisements received by the mesh stack can be forwarded to the application through the registered callback function. Note however that this does not hook into the SoftDevice scanner / nRF5 SDK libraries, and so you cannot use that for establishing a connection directly.
    Terje
  • Hi Terje!
    Thanks for your response! You are right, the application does use the BLE mesh stack.
    Registering the callback with nrf_mesh_rx_cb_set(rx_cb); helps me get the payload information from raw packets, but the callback is still called after that 2s interval.
    For your reference, I am referring to then difference in these timestamps. 14564523 and 14857948.
    I need a way to minimise this difference. This might be battery intensive, but I do not expect my application to run in this state for long. I just need to discover that my device is in this vicinity and provision it afterwards.
    <t: 14546745>, main.c, 642, RX [@443930985]: RSSI: -26 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57340D18AD7B06BAFAEAD6CE83B53A00E312D9E33382
    <t: 14547851>, main.c, 642, RX [@443964735]: RSSI: -26 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57340D18AD7B06BAFAEAD6CE83B53A00E312D9E33382
    <t: 14548998>, main.c, 642, RX [@443999735]: RSSI: -27 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57340D18AD7B06BAFAEAD6CE83B53A00E312D9E33382
    <t: 14550227>, main.c, 642, RX [@444037235]: RSSI: -27 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57340D18AD7B06BAFAEAD6CE83B53A00E312D9E33382
    <t: 14551537>, main.c, 642, RX [@444077236]: RSSI: -26 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57340D18AD7B06BAFAEAD6CE83B53A00E312D9E33382
    <t: 14563868>, main.c, 642, RX [@444453486]: RSSI: -26 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172B0100766999C335A8AF62000000003E6BC8C7134C1018
    <t: 14564523>, main.c, 642, RX [@444473486]: RSSI: -26 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172B0100766999C335A8AF62000000003E6BC8C7134C1018
    <t: 14857948>, main.c, 558, Node 0x0108 alive with 0 active fault(s), RSSI: -24
    <t: 14857955>, main.c, 642, RX [@453427890]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14859250>, main.c, 642, RX [@453467890]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14860438>, main.c, 642, RX [@453504140]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14861667>, main.c, 642, RX [@453541640]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14862937>, main.c, 642, RX [@453580390]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14864043>, main.c, 642, RX [@453614140]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14865108>, main.c, 642, RX [@453646640]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    <t: 14866296>, main.c, 642, RX [@453682890]: RSSI: -24 ADV TYPE: 2 ADDR: [06:5f:71:b2:67:ac]: 172A57203D1D01FF5BAECBD8742E4B9B9082BC81E74D9DBE
    Right. So the issue is that interval specifically, while the other intervals are fine? I.e. that you sometimes get a long interval, while otherwise the interval is acceptable?
    What features are enabled on the node? I.e. what other activity, save for scanning, requires use of the radio?
    Is there any flash activity going on when you see the long interval?
    Have you confirmed that the advertising device does not have a pause in its advertising? E.g. through the advertiser also logging, or through use of a sniffer?
    Terje
  • Hi Terje!
    Yep. The example that I am using right now is the provisioner example from the nRF Mesh SDK. Where I have added a condition on the RSSI during scan before proceeding to provision it.
    So, I don't think there should be any major activity going on with the flash.
    I have verified that the advertising device does not pause in between.
    Swanav
    I am sorry for the delays. We are in contact with the mesh SDK developers in order to figure out what might be the issue.
    You should expect a response within 1-2 days.
    Terje
