In our current project we are using NRF9160 with NRF52811 as BT device over HCI. Firmware on NRF52811 is just Bluetooth: HCI UART example with pinmux changed to match our hardware.
I want to perform firmware upgrade of NRF9160 over BT. I have added to `prj.con` file configs based on mcumgr/smp_svr example `overlay-bt.conf`. The only difference is
that I used `CONFIG_MCUMGR_SMP_UART` instead of `CONFIG_MCUMGR_SMP_SHELL` for smaller footprint.
This is my prj.con file.
With this configuration I'm able to connect to the device using NRF connect android app. The DFU button is visible. I'm able to choose what firmware sent to the device, but right after
starting DFU it is immediately stoped. BLE is not disconnected after that. For firmware update i'm using `app_update.bin` from `build/zephyr/` directory.
This is a log from NRF connect app:
nRF Connect, 2021-02-23
Test device (44:57:0A:cd:F3:66)
11:53:46.711 Connecting to 44:57:0A:cd:F3:66...
11:53:46.711 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
11:53:47.197 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
11:53:47.217 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
11:53:47.217 Connected to 44:57:0A:cd:F3:66
11:53:47.238 Discovering services...
11:53:47.238 gatt.discoverServices()
11:53:47.731 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
11:53:48.636 [Callback] Services discovered with status: 0
11:53:48.637 Services discovered
11:53:48.694 Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Battery Service (0x180F)
- Battery Level [N R] (0x2A19)
Unknown Service (00000020-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [WNR] (00000021-0000-1000-8000-00805f9b34fb)
Device Information (0x180A)
- Model Number String [R] (0x2A24)
- Manufacturer Name String [R] (0x2A29)
- Firmware Revision String [R] (0x2A26)
Unknown Service (00000030-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R W] (00000030-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000031-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000032-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000033-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000034-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000035-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000036-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000037-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000038-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [N R] (00000039-0000-1000-8000-00805f9b34fb)
Unknown Service (00000040-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [WNR] (00000041-0000-1000-8000-00805f9b34fb)
Unknown Service (00000050-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000051-0000-1000-8000-00805f9b34fb)
Unknown Service (00000010-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000011-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000012-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000013-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000014-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [R] (00000015-0000-1000-8000-00805f9b34fb)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
11:53:48.694 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
11:53:48.697 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true)
11:53:48.699 gatt.setCharacteristicNotification(00000031-0000-1000-8000-00805f9b34fb, true)
11:53:48.701 gatt.setCharacteristicNotification(00000032-0000-1000-8000-00805f9b34fb, true)
11:53:48.703 gatt.setCharacteristicNotification(00000033-0000-1000-8000-00805f9b34fb, true)
11:53:48.705 gatt.setCharacteristicNotification(00000034-0000-1000-8000-00805f9b34fb, true)
11:53:48.707 gatt.setCharacteristicNotification(00000035-0000-1000-8000-00805f9b34fb, true)
11:53:48.708 gatt.setCharacteristicNotification(00000036-0000-1000-8000-00805f9b34fb, true)
11:53:48.710 gatt.setCharacteristicNotification(00000037-0000-1000-8000-00805f9b34fb, true)
11:53:48.711 gatt.setCharacteristicNotification(00000038-0000-1000-8000-00805f9b34fb, true)
11:53:48.713 gatt.setCharacteristicNotification(00000039-0000-1000-8000-00805f9b34fb, true)
11:53:48.726 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
11:53:53.804 [McuMgr] Connecting...
11:53:53.811 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
11:53:53.829 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
11:53:53.835 [McuMgr] Connected to 44:57:0A:cd:F3:66
11:53:53.843 [McuMgr] wait(300)
11:53:54.151 [McuMgr] Discovering services...
11:53:54.158 [McuMgr] gatt.discoverServices()
11:53:54.173 [McuMgr] Services discovered
11:53:54.177 [McuMgr] Primary service found
11:53:54.181 [McuMgr] Requesting new MTU...
11:53:54.185 [McuMgr] gatt.requestMtu(515)
11:53:54.668 [McuMgr] MTU changed to: 65
11:53:54.676 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
11:53:54.684 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
11:53:54.689 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
11:53:55.473 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
11:53:55.482 [McuMgr] Notifications enabled
11:53:55.486 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
11:53:55.490 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
11:53:55.495 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
11:53:55.499 [McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Command Id: 0 (STATE)
Message: {}" sent
11:53:55.923 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-31-2E-30-64-68-61-73-68-58-20-6C-02-0C-DB-50-22-02-AC-6D-D5-2D-9D-03-64-A7-DD-5E
11:53:55.929 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 70-E4-A5-A4-63-6D-6B-CF-F8-E2-45-EE-23-D9-42-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
11:53:55.935 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
11:53:55.946 [McuMgr] "{"images":[{"slot":0,"version":"0.1.0","hash":"bAIM21AiAqxt1S2dA2Sn3V5w5KWkY21rz/jiRe4j2UI=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
11:53:55.955 [McuMgr] Uploading firmware...
Is it even possible to perform FOTA over SMP BT on NRF9160?
