How to use of RTC to wake up from sleep
I am after an example for nRF5340 showing how to use RTC to wake up from sleep.
I have a couple of timers running few tasks at regular intervals in a forever loop then I send the chip to sleep. At this point everything stops including the timers.
I need an interrupt source to wake the chip up and the RTC seems like a good way but I am not sure how to set it up and configure it to use.
Note, I am using SES V5.34a as a development environment and Zephyr V1.5.0-rc1.
Thank you.
Kind regards
Mohamed
  • Hi Mohamed,
    The Zephyr RTOS handles this for you. In the idle thread it will essentially call WFE, to enter system on low power mode. If you want to wake up after some time to do some work, you can use k_sleep() or similar. You can refer to the basic thread example to see how this is done.
    You are free to use an RTC peripheral directly and do it that way, but there are few good reasons for not using the build in thread and work queues support in Zephyr as suggested above.
    Einar
  • Thank you Einar for the quick response.
    I am not using threads for now. I may be using threads at some point in the near future.
    Could you please provide an example where the RTC is used to come out of sleep?
    Are you saying there are few good reasons for NOT using the built-in thread and work queues?
    In other ways you are discouraging me from using threads. Is this what you meant to say?
    Kind regards
    Mohamed
  • Hi Mohamed,
    If you are using Zephyr you are using threads, even if you may not be aware of it. Your main function is a thread (see system threads documentation for more). So using k_sleep is still the most appropriate.
    There are no official simple RTC sample in the NCS, but you can refer to this unofficial sample (it is for the nRF9160 but the code is equally relevant for the nRF53).
    Yes.
    No, I am discouraging you from using the RTC driver and handling this yourself as the appropriate way to do this is to use what Zephyr provides for you. To expand on this: Using an RTC directly will work, and it is not complicated. But it is just not clean to use a special approach in place of a core feature of the RTOS you are using which does exactly the same thing.
    Einar
  • Thank you.
    I get it that my main() function is an implicit thread running under Zephyr.
    I tried to get to the source code of the basic thread example but I could not. All I could see was the README.html file.
    How can I view and download the project?
    Kind regards
    Mohamed
  • Hi Mohamed,
    The sample is located under <ncs>/zephyr/samples/basic/threads/
    Einar
