How to use of RTC to wake up from sleep
I am after an example for nRF5340 showing how to use RTC to wake up from sleep.
I have a couple of timers running few tasks at regular intervals in a forever loop then I send the chip to sleep. At this point everything stops including the timers.
I need an interrupt source to wake the chip up and the RTC seems like a good way but I am not sure how to set it up and configure it to use.
Note, I am using SES V5.34a as a development environment and Zephyr V1.5.0-rc1.
Thank you.
Kind regards
Mohamed
  • Hi Mohamed,
    Are you using the nrfx_saadc API? If so you can call nrfx_saadc_uninit() after finishing the conversion. If current consumption is still high after uninitializing then you can use the following as well:
        *(volatile uint32_t *)0x40007FFC = 0;
        *(volatile uint32_t *)0x40007FFC = 1;
    The above snippet uses an undocumented register to reset the SAADC peripheral.
    Einar
  • Hi Einar,
    Thank you for the tips.
    I am not sure. How do I know for sure if I am using nrfx_saadc API?
    I looked in the build.emProject file and I can see the following which suggests I am using nrfx_saadc API. An extract from build.emProject is included below. The file nrfx_saadc_uninit() is declared in the header file C:\Zypher\v1.5.0-rc1\modules\hal\nordic\nrfx\drivers\include\nrfx_saadc.h which is included in the project file below. However, I cannot build the project because it returns the error undefined reference to nrfx_saadc_uninit().
    </project>
    <project Name="app/libapp.a">
    <configuration
    Name="Common"
    build_output_file_name="app\libapp.a"
    project_dependencies="cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;cmake_object_order_depends_target_app;zephyr/driver_validation_h_target;zephyr/kobj_types_h_target;zephyr/syscall_list_h_target;zephyr/zephyr_generated_headers"
    project_directory=""
    project_type="Externally Built Library" />
    <folder Name="C_COMPILER__app_">
    <file file_name="../src/adc/pid4_adc.c">
    <configuration
    Name="Common"
    build_dependency_file_name="$(ProjectDir)/CMakeFiles\app.dir\src\adc\pid4_adc.c.obj.d"
    build_object_file_name="CMakeFiles/app.dir/src/adc/pid4_adc.c.obj"
    c_only_additional_options="-DBUILD_VERSION=v2.4.99-ncs1-rc1;-DKERNEL;-DNRF5340_XXAA_APPLICATION;-DUSE_PARTITION_MANAGER=0;-D_FORTIFY_SOURCE=2;-D__LINUX_ERRNO_EXTENSIONS__;-D__PROGRAM_START;-D__ZEPHYR__=1;
    -IC:/Zypher/v1.5.0-rc1/modules/hal/nordic/nrfx/drivers/include
    -IC:/Zypher/v1.5.0-rc1/zephyr/include;-Izephyr/include/generated;
    -IC:/Zypher/v1.5.0-rc1/zephyr/soc/arm/nordic_nrf/nrf53;
    -IC:/Zypher/v1.5.0-rc1/zephyr/lib/libc/newlib/include;
    -IC:/Zypher/v1.5.0-rc1/nrf/include;
    -IC:/Zypher/v1.5.0-rc1/modules/hal/cmsis/CMSIS/Core/Include;
    -IC:/Zypher/v1.5.0-rc1/modules/hal/nordic/nrfx;
    -IC:/Zypher/v1.5.0-rc1/modules/hal/nordic/nrfx/drivers/include;
    -IC:/Zypher/v1.5.0-rc1/modules/hal/nordic/nrfx/mdk;
    -IC:/Zypher/v1.5.0-rc1/zephyr/modules/hal_nordic/nrfx/.;
    -IC:/Zypher/v1.5.0-rc1/modules/debug/segger/rtt;
    -isystem;C:/Zypher/v1.5.0-rc1/nrfxlib/crypto/nrf_cc312_platform/include;
    -Og;-imacros;
    I have this config line in my prj.conf file
    CONFIG_ADC=y
    Which header file should I be including?
    Kind regards
    Mohamed
  • Hi Mohamed,
    You can know by looking at the functions you call to use the SAADC. Do you for instance call functions that look like nrfx_saadc_() or do they look like adc_*()? I assume the latter as you get undefined reference to nrfx_saadc_uninit().
    If you want to use the nrfx API instead then you should include the nrfx_saadc.h file. This may be useful if you are not able to get the ADC current consumption down without disabling it, as the Zephyr ADC API does not have any API for that.
    Br,
    Einar
  • Hello Einar,
    Thank you.
    You are right, I am using functions adc_read() to read adc results. So, I am using Zephyr ADC NOT nrfx_saadc API. These are the header files I am currently including in my adc.c file.
    #include <zephyr.h>
    #include <kernel.h>
    #include <sys/printk.h>
    #include <drivers/adc.h>
    #include <hal/nrf_saadc.h> /*ADC definitions and includes*/
    #include <device.h>
    #include <drivers/gpio.h>
    Which header files should I be including for nrfx_saadc APIs and which one ones should I remove from the ones currently included above or can they co-exist?
    Also, do I have to change the prj.conf file?
    it currently contains this line CONFIG_ADC=y.
    Finally, do you an example you can share with me that uses nrfx_saadc APIs
    Kind regards
    Mohamed
  • Hi Mohamed,
    To you use nrfx_saadc API directly you need to include nrfx_saadc.h. You can see a few examples of its usage here:
    You need to have CONFIG_ADC_NRFX_SAADC=y for this. That should be implicitly set, though as you allready have CONFIG_ADC=y.
    Einar
