HI
We have a running product that we want to improve by moving from ESB to Gazell.
it should be an easy task, because it is only a simple main file that needs to be replaced, so I have taken as my starting point a Gazell example.
But I've run into a little problem that I hope you can help with.
I get this error:
. \ _ build \ nrf52840_xxaa.axf: Error: L6200E: Symbol TIMER0_IRQHandler multiply defined (by nrf_flywheel.o and nrfx_timer.o).
I understand what the error means and what to do normally, but I'm a little skeptical here, because I do not use nrf_flywheel. *.
so I hope you have a suggestion ..
best regards...
