Unable to run Target->Erase All using Segger IDE
I am using a BL632 DK from Laird, trying to erase the onboard 52832 device.  I can connect to the target, but it fails when try erase all.
Results from connect target:
Device "NRF52832_XXAA" selected.
InitTarget() start
InitTarget() end
Found SW-DP with ID 0x2BA01477
DPIDR: 0x2BA01477
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
FPUnit: 0 code (BP) slots and 0 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
Error received from Erase all:
Preparing target for download
Executing Reset script TargetInterface.resetAndStop()
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Reset: SYSRESETREQ has confused core.
DPIDR: 0x2BA01477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
Reset: Using fallback: VECTRESET.
Reset: Reset device via AIRCR.VECTRESET.
Reset: VECTRESET has confused core.
Reset: Using fallback: Reset pin.
Reset: Reset device via reset pin
Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
Reset: Reconnecting and manually halting CPU.
DPIDR: 0x2BA01477
AP[0]: Core found
CPU could not be halted
Reset: Core did not halt after reset, trying to disable WDT.
DPIDR: 0x2BA01477
AP[0]: Core found
Reset: Failed. Toggling reset pin and trying reset strategy again.
DPIDR: 0x2BA01477
AP[0]: Core found
DPIDR: 0x2BA01477
AP[0]: Core found
DPIDR: 0x2BA01477
AP[0]: Skipped. No ROM table (AHB-AP ROM base: 0x00000000)
DPIDR: 0x2BA01477
AP[0]: Core found
Could not find core in Coresight setup
Failed to halt CPU.
Cannot read register 0 (R0) while CPU is running
Cannot read register 1 (R1) while CPU is running
Cannot read register 2 (R2) while CPU is running
Cannot read register 3 (R3) while CPU is running
Cannot read register 4 (R4) while CPU is running
Cannot read register 5 (R5) while CPU is running
Cannot read register 6 (R6) while CPU is running
Cannot read register 7 (R7) while CPU is running
Cannot read register 8 (R8) while CPU is running
Cannot read register 9 (R9) while CPU is running
Cannot read register 10 (R10) while CPU is running
Cannot read register 11 (R11) while CPU is running
Cannot read register 12 (R12) while CPU is running
Cannot read register 13 (R13) while CPU is running
Cannot read register 14 (R14) while CPU is running
Cannot read register 15 (R15) while CPU is running
Cannot read register 16 (XPSR) while CPU is running
Cannot read register 17 (MSP) while CPU is running
Cannot read register 18 (PSP) while CPU is running
Cannot read register 20 (CFBP) while CPU is running
Erasing Chip
Failed to download RAMCode.
Failed to prepare for programming.
Failed to download RAMCode!
I am able to erase and program an external module, just not the on board device.  It had been working fine until I tried programming the Mesh Light sample from the nRF Connect SDK 1.5.0 rc1.  The LEDs are flashing as though it is trying to run then resetting.
