Hi.
I'm having issues setting the instant on high threshold on the ADXL372 on the Thingy:91. I'm new to this, so I might be missing something obvious. I've updated the thingy firmware as specified on the getting started page. I'm setting the bit like this with the zephyr driver provided:
adxl372_reg_write_mask(dev_372,
ADXL372_POWER_CTL,
ADXL372_POWER_CTL_INSTANT_ON_TH_MSK,
ADXL372_POWER_CTL_INSTANT_ON_TH_MODE(ADXL372_INSTANT_ON_HIGH_TH));
And have ensured that the 5th bit in the power control register (0x3F) is set before putting it into instant on mode, and that it stays that way.
ADXL372_POWER_CTL,
ADXL372_POWER_CTL_MODE_MSK,
ADXL372_POWER_CTL_MODE(ADXL372_INSTANT_ON));
From what i understand this is in accordance with the data sheet. Nevertheless the trigger seems to be just as sensitive when this bit is set, although the threshold should be 10-15g for low and 30-40g for high.
I've also tried to modify the driver in order so set the the accelerometer into high threshold from the start, but that doesn't seem to make a difference. Any insight to what could cause the issue, or what I am missing would be much appreciated. Im on NCS 1.4.0, but also tested briefly with a newer version.
-Sigurd
