SDK V1.5.0 west build -b nrf9160_nrf52840 fails
In my quest to gain access to the nor memory on the nrf9160-dk I have found what happened to the WP and HOLD signals and now external_flash_pins_routing configuration setting. To me since the nrf52840 controls the external_flash_pins_routing signal that means I need to build nrf9160_nfr52840, taking baby steps I tried the example at nRF9160 DK - nRF52840 — Zephyr Project Documentation (nordicsemi.com)  hello world with -> west build -b nrf9160dk_nrf52840  worked but west build -b [email protected] fails
D:\ncs\v1.5.0\zephyr\samples\hello_world>west build -b nrf9160dk_nrf52840
Including boilerplate (Zephyr base): D:/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
-- Application: D:/ncs/v1.5.0/zephyr/samples/hello_world
-- Using NCS Toolchain 1.5.0 for building. (D:/ncs/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (D:/ncs/v1.5.0/zephyr)
-- Found Python3: D:/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf52840, Revision: 0.7.0
-- Cache files will be written to: D:/ncs/v1.5.0/zephyr/.cache
-- Found dtc: D:/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (D:/ncs/v1.5.0/toolchain/opt)
-- Found BOARD.dts: D:/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840.dts
-- Generated zephyr.dts: D:/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/device_extern.h
Parsing D:/ncs/v1.5.0/zephyr/Kconfig
Loaded configuration 'D:/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_defconfig'
Merged configuration 'D:/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_7_0.conf'
Merged configuration 'D:/ncs/v1.5.0/zephyr/samples/hello_world/prj.conf'
Configuration saved to 'D:/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/.config'
Kconfig header saved to 'D:/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: D:/ncs/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/v1.5.0/zephyr/samples/hello_world/build
[138/143] Linking C executable zephyr\zephyr_prebuilt.elf
           FLASH:       19968 B         1 MB      1.90%
            SRAM:        5824 B       256 KB      2.22%
        IDT_LIST:          72 B         2 KB      3.52%
[143/143] Linking C executable zephyr\zephyr.elf
D:\ncs\v1.5.0\zephyr\samples\hello_world>west build -b [email protected] --pristine
-- west build: making build dir D:\ncs\v1.5.0\zephyr\samples\hello_world\build pristine
-- Board: nrf9160dk_nrf52840, Revision: 0.15.0 (Active: 0.14.0)
-- Found devicetree overlay: D:/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay
Error: nrf9160dk_nrf52840.dts.pre.tmp:544.9-10 syntax error
FATAL ERROR: Unable to parse input tree
CMake Error at D:/ncs/v1.5.0/zephyr/cmake/dts.cmake:205 (message):
  command failed with return code: 1
  D:/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake:533 (include)
  D:/ncs/v1.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  D:/ncs/v1.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
FATAL ERROR: command exited with status 1: 'D:\ncs\v1.5.0\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=D:\ncs\v1.5.0\toolchain\opt\bin\python.exe' '-BD:\ncs\v1.5.0\zephyr\samples\hello_world\build' '-SD:\ncs\v1.5.0\zephyr\samples\hello_world' -GNinja [email protected]
Next was blinky, complete failure with or without version.
At any rate, since I can't use version I can't get nrf9160dk_nrf52840_0_14_0.overlay to be used and I can't get
        external_flash_pins_routing: switch-ext-mem-ctrl {
            compatible = "nordic,nrf9160dk-optional-routing";
            control-gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
            status = "ok";
I would love to use nrf9160dk_nrf52840_defconfig to set external_flash_pins_routing but I've no idea what it is called in deconfig
  • I'm not able to reproduce your error. I did the following:
    • Installed NCS v1.5.0 through the Toolchain Manager
    • Set the external_flash_pins_routing status to "ok" (I also tried with "okay", which is the correct way of setting it)
    • I built it successfully (it worked both when using "ok" as well as "okay"):
    C:\Users\Simon\ncs\v1.5.0\zephyr\samples\hello_world>west build -b [email protected] --pristine
    Including boilerplate (Zephyr base): C:/Users/Simon/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world
    -- Using NCS Toolchain 1.5.0 for building. (C:/Users/Simon/ncs/v1.5.0/toolchain/cmake)
    -- Zephyr version: 2.4.99 (C:/Users/Simon/ncs/v1.5.0/zephyr)
    -- Found Python3: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/Users/Simon/ncs/v1.5.0/zephyr/.cache
    -- Found dtc: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Users/Simon/ncs/v1.5.0/toolchain/opt)
    -- Found BOARD.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840.dts
    -- Found devicetree overlay: C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay
    -- Generated zephyr.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/device_extern.h
    Parsing C:/Users/Simon/ncs/v1.5.0/zephyr/Kconfig
    Loaded configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_defconfig'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/prj.conf'
    Configuration saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build/zephyr/include/generated/autoconf.h'
    -- Found assembler: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/hello_world/build
               FLASH:       20016 B         1 MB      1.91%
    Could you provide some steps on how to reproduce this?
    Could you do the following:
    • cd ..\ncs\v1.5.0\zephyr
    • git checkout -b modify_nrf9160dk_nrf52840
    • git add .
    • git commit -m "set the external_flash_pins_routing status to 'ok'"
    • git diff v2.4.99-ncs1...modify_nrf9160dk_nrf52840
    If you have anything different than this, please tell me:
    diff --git a/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay b/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay
    index ddd73df4c1..97e84e94f7 100644
    --- a/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay
    +++ b/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.overlay
    @@ -21,7 +21,7 @@
    -                       status = "disabled";
    +                       status = "ok";
    diff --git a/share/zephyr-package/cmake/current_path.txt b/share/zephyr-package/cmake/current_path.txt
    new file mode 100644
    index 0000000000..da7f3c6cac
    --- /dev/null
    +++ b/share/zephyr-package/cmake/current_path.txt
    @@ -0,0 +1 @@
    +C:/Users/Simon/ncs/v1.5.0/zephyr/share/zephyr-package/cmake
    \ No newline at end of file
    Simon
  • I followed your directions but when I tired to 'MARK' the text I hit close... Did the Diff:  but the status 'ok' was not applied.
    My environment: is Windows 10 Build 21322
    Python3_ROOT=D:\ncs\v1.5.0\toolchain\opt\bin
    PYTHONPATH=D:\ncs\v1.5.0\toolchain\opt\bin;D:\ncs\v1.5.0\toolchain\opt\bin\Lib;D:\ncs\v1.5.0\toolchain\opt\bin\Lib\site-packages
    tcdir=D:\ncs\v1.5.0\toolchain
    ZEPHYR_BASE=D:\ncs\v1.5.0\zephyr
    ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    D:\ncs\v1.5.0\zephyr>git diff v2.4.99-ncs1...modify_nrf9160dk_nrf52840
    index ddd73df4c1..9ce5255e25 100644
    @@ -22,7 +22,7 @@
    diff --git a/samples/drivers/spi_flash/boards/nrf9160dk_nrf9160.conf b/samples/drivers/spi_flash/boards/nrf9160dk_nrf9160.conf
    index 0000000000..c483efdb82
    --- /dev/null
    +++ b/samples/drivers/spi_flash/boards/nrf9160dk_nrf9160.conf
    @@ -0,0 +1,8 @@
  • Based on the diff, it seems like you have removed a "};" and replaced it with a ");", which leads to a dts syntax error. If you correct that, it should work fine.
    Simon
  • "Could you provide some steps on how to reproduce this?"
    I could if I hadn't screwed up the v1.5.0 SDK last night trying to build nrf5340dk_nrf5340 - for some reason the build system could not find the 'board' and failed. I shut down for the night. I just tried to "Could you provide some steps on how to reproduce this?" and the build system can not find any 'board' for nrf9160dk_nrf52840. I rm -r the v1.5.0 sdk and found rm could not remove it since it could not delete: Deleted file - D:\ncs\v1.5.0\modules\lib\civetweb\test\nonlatin\这是一个示例文本.html
    After fixing that I am reinstalling v1.5.0 using nRF Connect and selecting the zip file in ncs\downloads\ncs-toolchain-v1.5.0-20210225-607a0e0.zip  THANK YOU Nordic for adding the install local file! Cellular gigabyte downloads are a pain sometimes.
    Once the files were unziped I did the hello_world with board version, it built. Next was the:
    D:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash>west build -b [email protected] --pristine
    -- Application: D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash
    -- Generated zephyr.dts: D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/build/zephyr/include/generated/device_extern.h
    Merged configuration 'D:/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_0_14_0.conf'
    Merged configuration 'D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/prj.conf'
    Configuration saved to 'D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/build/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v1.5.0/zephyr/samples/drivers/spi_flash/build/zephyr/include/generated/autoconf.h'
    -- Configuring done
    CMake Error at ../../../cmake/extensions.cmake:416 (add_library):
      No SOURCES given to target: drivers__spi
      ../../../cmake/extensions.cmake:393 (zephyr_library_named)
      ../../../drivers/spi/CMakeLists.txt:3 (zephyr_library)
    CMake Generate step failed.  Build files cannot be regenerated correctly.
    FATAL ERROR: command exited with status 1: 'D:\ncs\v1.5.0\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=D:\ncs\v1.5.0\toolchain\opt\bin\python.exe' '-BD:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash\build' '-SD:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash' -GNinja [email protected]
    and then:
    D:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash>west build -b nrf5340dk_nrf5340 --pristine
    -- west build: making build dir D:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash\build pristine
    -- Board: nrf5340dk_nrf5340
    No board named 'nrf5340dk_nrf5340' found.
    Please choose one of the following boards:
    CMake Error at D:/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake:383 (message):
      Invalid BOARD; see above.
      CMakeLists.txt:4 (find_package)
    FATAL ERROR: command exited with status 1: 'D:\ncs\v1.5.0\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=D:\ncs\v1.5.0\toolchain\opt\bin\python.exe' '-BD:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash\build' '-SD:\ncs\v1.5.0\zephyr\samples\drivers\spi_flash' -GNinja -DBOARD=nrf5340dk_nrf5340
  • There is no board named nrf5340dk_nrf5340, you should choose one of these (ns means that you're building a non-secure application):
    nrf5340dk_nrf5340_cpuapp
    nrf5340dk_nrf5340_cpuappns
    nrf5340dk_nrf5340_cpunet
    nrf5340pdk_nrf5340_cpuapp
    nrf5340pdk_nrf5340_cpuappns
    nrf5340pdk_nrf5340_cpunet
    Simon
