GPIO Pin output not working as same as LEDs on Board.
I m using nrf52840-DK Board.
For CTL example i got the perfect output on board LEDs 1 to 4.
Then i cut the solder bridge (SB5-SB8)and then used GPIO pinout for external LED light.
When i use GPIO pinout P0.13 to P0.16 as output and Connected the External dimmable driver led light.
I didn't get the same output as i got on Borad LEDs.
Problem:
On CTL example (nrf52 5.0 SDK) at whatever point the slider is left with. It will dim the light which has lower intensity.
For example: IF Warm is at high intensity 80% and cool is at 20%, the dimming will be of cool light only.
The Dimming of The warm and cool light does not go together.
The only time external light dimmes both cold and Warm light is when both are on 50% percent.
what is that i m missing. i have gone through the Diagram also with detail in documentation.
please help me on my regarding problem.
Parents Reply
    What region are you located at?
    A video call wouldn't solve the issue any faster.  As it says in the example:
    The photometrically accurate implementation of the tunable white light is out of scope of this example.
    What I wrote in my previous reply still stands, you have to test and adjust with the specific LED that you're using.
    regards
    Jared
