Adding DFU to NCS example on nRF52832
I want to add DFU to the peripheral_hids_keyboard example from the nRF Connect SDK. I added CONFIG_BOOTLOADER_MCUBOOT=y to the prj.conf and specified a key file.
When building in SES, the build fails:
Checking project status
Building ‘/opt/nordic/ncs/v1.5.0/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/misc/generated/syscalls_links/include’
Building ‘zephyr/misc/generated/syscalls_links/include_app_memory’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_audio’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_bluetooth’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_canbus’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_cmsis_rtos_v1’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_cmsis_rtos_v2’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_console’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_crypto’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_data’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_debug’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_devicetree’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dfu’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_disk’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_display’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_fs’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_ipc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_kernel’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_linker’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_logging’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_lorawan’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_mgmt’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_net’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_posix’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_power’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_random’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_settings’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_shell’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_stats’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_storage’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_sys’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_timing’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_toolchain’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_tracing’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_usb’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_zephyr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_common’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_nios2’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_posix’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_riscv’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_sparc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_x86’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_xtensa’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arc_v2’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arc_v2_mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arc_v2_secureshield’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch64’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_a_r’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_r’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_a_r_scripts’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_m_mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_m_scripts’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch32_cortex_r_scripts’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_arm_aarch64_scripts’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_riscv_common’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_riscv_riscv-privilege’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_x86_ia32’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_arch_x86_intel64’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_bluetooth_mesh’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_bluetooth_services’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_adc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_bluetooth’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_clock_control’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_console’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_dma’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_ec_host_cmd_periph’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_gpio’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_i2c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_ieee802154’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_interrupt_controller’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_led’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_modem’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_pcie’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_rtc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_sensor’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_timer’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_uart’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_usb’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_virtualization’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_i2c_slave’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_drivers_pcie_endpoint’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_clock’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_dac’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_display’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_dma’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_espi’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_gpio’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_i2c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_interrupt-controller’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_led’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_lora’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_memory-controller’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_pcie’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_pinctrl’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_pwm’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_rdc’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_dt-bindings_usb’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_mgmt_mcumgr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_posix_arpa’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_posix_net’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_posix_netinet’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_posix_sys’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_links/include_usb_class’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls_subdirs.trigger’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/misc/generated/syscalls_subdirs.trigger’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘offsets.c’
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/offsets.h’
Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__drivers__mpsl__clock_control’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__lib__dk_buttons_and_leds’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__lib__multithreading_lock’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__subsys__bluetooth__controller’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__subsys__mpsl’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_isr_tables’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__entropy’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__flash’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__libc__minimal’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_modules__hal_nordic’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_soc__arm__nordic_nrf__nrf52’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__bluetooth__common’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__bluetooth__host’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__net’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__random’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/linker.cmd’
Building ‘zephyr/CMakeFiles/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘main.c’
  Archiving ‘libapp.a’
Building ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘cbprintf.c’
  Compiling ‘crc32_sw.c’
  Compiling ‘crc8_sw.c’
  Compiling ‘crc7_sw.c’
  Compiling ‘crc16_sw.c’
  Compiling ‘fdtable.c’
  Compiling ‘notify.c’
  Compiling ‘hex.c’
  Compiling ‘dec.c’
  Compiling ‘onoff.c’
  Compiling ‘sem.c’
  Compiling ‘timeutil.c’
  Compiling ‘thread_entry.c’
  Compiling ‘rb.c’
  Compiling ‘printk.c’
  Compiling ‘heap-validate.c’
  Compiling ‘heap.c’
  Compiling ‘assert.c’
  Compiling ‘validate_base_addresses.c’
  Compiling ‘validate_enabled_instances.c’
  Compiling ‘configs.c’
  Compiling ‘cbprintf_complete.c’
  Compiling ‘work_q.c’
  Compiling ‘dis.c’
  Compiling ‘addr_utils.c’
  Compiling ‘nvs.c’
  Compiling ‘bas.c’
  Compiling ‘settings_store.c’
  Compiling ‘settings_line.c’
  Compiling ‘settings_init.c’
  Compiling ‘settings.c’
  Compiling ‘flash_map_default.c’
  Compiling ‘settings_nvs.c’
  Compiling ‘flash_map.c’
  Compiling ‘log_minimal.c’
  Compiling ‘reboot.c’
  Compiling ‘policy_residency.c’
  Compiling ‘clock_control_nrf.c’
  Compiling ‘rtt_console.c’
  Compiling ‘gatt_pool.c’
  Compiling ‘nrf_rtc_timer.c’
  Compiling ‘sys_clock_init.c’
  Compiling ‘SEGGER_RTT.c’
  Compiling ‘SEGGER_RTT_zephyr.c’
  Compiling ‘hids.c’
  Compiling ‘ecc.c’
  Compiling ‘aes_decrypt.c’
  Compiling ‘ecc_dh.c’
  Compiling ‘utils.c’
  Compiling ‘cmac_mode.c’
  Compiling ‘aes_encrypt.c’
  Compiling ‘conn_ctx.c’
  Compiling ‘power.c’
  Archiving ‘libzephyr.a’
Building ‘zephyr/arch/common/libisr_tables.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘isr_tables.c’
  Archiving ‘libisr_tables.a’
Building ‘zephyr/arch/common/libarch__common.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘sw_isr_common.c’
  Archiving ‘libarch__common.a’
Building ‘zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘swap.c’
  Compiling ‘irq_manage.c’
  Compiling ‘fatal.c’
  Compiling ‘nmi.c’
  Compiling ‘thread.c’
  Assembling ‘cpu_idle.S’
  Assembling ‘nmi_on_reset.S’
  Assembling ‘swap_helper.S’
  Compiling ‘prep_c.c’
  Assembling ‘isr_wrapper.S’
  Archiving ‘libarch__arm__core__aarch32.a’
Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
  Assembling ‘vector_table.S’
  Assembling ‘reset.S’
  Assembling ‘exc_exit.S’
  Compiling ‘fault.c’
  Assembling ‘fault_s.S’
  Compiling ‘irq_init.c’
  Compiling ‘thread_abort.c’
  Compiling ‘scb.c’
  Archiving ‘libarch__arm__core__aarch32__cortex_m.a’
Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘arm_core_mpu.c’
  Compiling ‘arm_mpu.c’
  Archiving ‘libarch__arm__core__aarch32__cortex_m__mpu.a’
Building ‘zephyr/lib/libc/minimal/liblib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘abort.c’
  Compiling ‘atoi.c’
  Compiling ‘strtoul.c’
  Compiling ‘malloc.c’
  Compiling ‘strtol.c’
  Compiling ‘exit.c’
  Compiling ‘string.c’
  Compiling ‘strstr.c’
  Compiling ‘strncasecmp.c’
  Compiling ‘bsearch.c’
  Compiling ‘sprintf.c’
  Compiling ‘fprintf.c’
  Compiling ‘gmtime.c’
  Compiling ‘stdout_console.c’
  Compiling ‘strspn.c’
  Archiving ‘liblib__libc__minimal.a’
Building ‘zephyr/lib/posix/liblib__posix.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘pthread_common.c’
  Compiling ‘nanosleep.c’
  Archiving ‘liblib__posix.a’
Building ‘zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘arm_mpu_regions.c’
  Archiving ‘libsoc__arm__common__cortex_m.a’
Building ‘zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘soc.c’
  Compiling ‘power.c’
  Archiving ‘libsoc__arm__nordic_nrf__nrf52.a’
Building ‘zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘dummy.c’
  Compiling ‘log.c’
  Compiling ‘rpa.c’
  Archiving ‘libsubsys__bluetooth__common.a’
Building ‘zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘hci_ecc.c’
  Compiling ‘addr.c’
  Compiling ‘uuid.c’
  Compiling ‘hci_common.c’
  Compiling ‘hci_core.c’
  Compiling ‘buf.c’
  Compiling ‘att.c’
  Compiling ‘l2cap.c’
  Compiling ‘gatt.c’
  Compiling ‘conn.c’
  Compiling ‘keys.c’
  Compiling ‘smp.c’
  Archiving ‘libsubsys__bluetooth__host.a’
Building ‘zephyr/subsys/net/libsubsys__net.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘buf.c’
  Archiving ‘libsubsys__net.a’
Building ‘zephyr/subsys/random/libsubsys__random.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘rand32_entropy_device.c’
  Archiving ‘libsubsys__random.a’
Building ‘zephyr/drivers/gpio/libdrivers__gpio.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘gpio_nrfx.c’
  Archiving ‘libdrivers__gpio.a’
Building ‘zephyr/drivers/flash/libdrivers__flash.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘flash_page_layout.c’
  Compiling ‘flash_ll_softdevice.c’
  Archiving ‘libdrivers__flash.a’
Building ‘zephyr/drivers/serial/libdrivers__serial.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘uart_nrfx_uarte.c’
  Archiving ‘libdrivers__serial.a’
Building ‘zephyr/drivers/entropy/libdrivers__entropy.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘entropy_ll_softdevice.c’
  Archiving ‘libdrivers__entropy.a’
Building ‘modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘dk_buttons_and_leds.c’
  Archiving ‘lib..__nrf__lib__dk_buttons_and_leds.a’
Building ‘modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘multithreading_lock.c’
  Archiving ‘lib..__nrf__lib__multithreading_lock.a’
Building ‘modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘fatal_error.c’
  Archiving ‘lib..__nrf__lib__fatal_error.a’
Building ‘modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘hci_driver.c’
  Compiling ‘hci_internal.c’
  Compiling ‘crypto.c’
  Archiving ‘lib..__nrf__subsys__bluetooth__controller.a’
Building ‘modules/nrf/subsys/mpsl/lib..__nrf__subsys__mpsl.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘mpsl_init.c’
  Archiving ‘lib..__nrf__subsys__mpsl.a’
Building ‘modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘nrfx_clock_mpsl.c’
  Archiving ‘lib..__nrf__drivers__mpsl__clock_control.a’
Building ‘modules/hal_nordic/libmodules__hal_nordic.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘system_nrf52.c’
  Compiling ‘nrfx_glue.c’
  Compiling ‘nrfx_nvmc.c’
  Compiling ‘nrfx_gpiote.c’
  Compiling ‘nrfx_ppi.c’
  Archiving ‘libmodules__hal_nordic.a’
Building ‘zephyr/kernel/libkernel.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘device.c’
  Compiling ‘errno.c’
  Compiling ‘idle.c’
  Compiling ‘init.c’
  Compiling ‘fatal.c’
  Compiling ‘mem_slab.c’
  Compiling ‘msg_q.c’
  Compiling ‘mailbox.c’
  Compiling ‘kheap.c’
  Compiling ‘pipes.c’
  Compiling ‘sched.c’
  Compiling ‘sem.c’
  Compiling ‘queue.c’
  Compiling ‘mutex.c’
  Compiling ‘system_work_q.c’
  Compiling ‘version.c’
  Compiling ‘smp.c’
  Compiling ‘banner.c’
  Compiling ‘condvar.c’
  Compiling ‘stack.c’
  Compiling ‘timeout.c’
  Compiling ‘poll.c’
  Compiling ‘timer.c’
  Compiling ‘mempool.c’
  Compiling ‘xip.c’
  Archiving ‘libkernel.a’
Building ‘zephyr/zephyr_prebuilt.elf’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘empty_file.c’
  Linking ‘zephyr_prebuilt.elf’
    B     232960 B     84.56%
    B        64 KB     47.02%
    B         2 KB      7.42%
Building ‘zephyr/linker_pass_final.cmd’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/linker_pass_final.cmd’
Building ‘zephyr/CMakeFiles/linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/isr_tables.c’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/isr_tables.c’
Building ‘cmake_object_order_depends_target_zephyr_final’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
  Linking ‘zephyr.elf’
  Post-link command
Building ‘zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/mcuboot_primary_app.hex’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/mcuboot_primary_app.hex’
Building ‘CMakeFiles/mcuboot_primary_app_hex’ from solution ‘build’ in configuration ‘Common’
Building ‘mcuboot_primary_app_hex’ from solution ‘build’ in configuration ‘Common’
Building ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-mkdir’ from solution ‘build’ in configuration ‘Common’
  Combining ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-mkdir’
Building ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-download’ from solution ‘build’ in configuration ‘Common’
  Combining ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-download’
Building ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-update’ from solution ‘build’ in configuration ‘Common’
  Combining ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-update’
Building ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-patch’ from solution ‘build’ in configuration ‘Common’
  Combining ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-patch’
Building ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-configure’ from solution ‘build’ in configuration ‘Common’
  Combining ‘modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-configure’
Building ‘mcuboot/zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
  Combining ‘mcuboot/zephyr/zephyr.hex’
    B        48 KB     68.38%
    B        64 KB     36.33%
            IDT_LIST:          72 B         2 KB      3.52/opt/nordic/ncs/v1.5.0/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: app/libapp.a(keys.c.obj):(.rodata.bootutil_keys+0x0): undefined reference to `rsa_pub_key'
    /opt/nordic/ncs/v1.5.0/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: app/libapp.a(keys.c.obj):(.rodata.bootutil_keys+0x4): undefined reference to `rsa_pub_key_len'
    ld returned 1 exit status
    build stopped: subcommand failed.
Build failed
When building with cmake directly it builds ok. But after flashing, the example does not run. Is there an example of BLE DFU with NCS on nRF52832 or other boards?
    Did you follow some guide to get to this point? If so, what guide did you follow. Let me know, and I can see if I can reproduce the issue you are seeing. If you didn't have a guide, did you do anything other than just adding the config CONFIG_BOOTLOADER_MCUBOOT=y in your prj.conf file? I see that you are using NCS v1.5.0. Did it work in a previous NCS version, or is this your first attempt?
    Edvin
  • Hi Edvin, no I haven't got this working in any previous version.
    I set the key as in my solution here: https://devzone.nordicsemi.com/f/nordic-q-a/71892/cmake-warning-using-default-mcuboot-key-it-should-not-be-used-for-production/295833#295833
    I am following these steps: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_bootloader.html#adding-a-bootloader-chain-to-your-application
    I tried adding both immutable bootloader and MCUBoot but it seems there is not enough flash to do that on nRF52832 (or the bootloader configuration for the board is incorrect) as I got a flash overflow error at build time, so I switched to just using MCUBoot.
    Sorry for the slow response. I have spent about a day trying to add a bootloader to another project, and I almost made it. I failed due to some flash conflicts in the projects.
    Have you tested the smp_svr example description found here?
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_nrf52.html#fota-upgrades
    I didn't see the same error as you did when I tried to follow the guide. It claims that there are some missing references to the key. Where is this key located? And is that file included in your project? Usually, you need to include both the header files, and add some definitions in the prj.conf file to add a module.
    Where are these used, and where are they defined? Is that .h/.c file included in your project properly? A quick search shows me that it is found in bootloader\mcuboot\boot\cypress\MCUBootApp\keys.c. Is that intentional? I don't think the bootloader for nRF52 should use the cypress files by default. Did it work before you tried to set your own key? By using the default key in NCS? I am not saying you should use that specific key in the end, but just to see that things are working before you start modifying too much.
    BR,
    Edvin
  • Hi Edvin,
    Thanks I've got a bit further.
    1. Using the built in key works. I don't know why specifying my own key is failing. As per my linked solution, I'm doing this in CMakeLists.txt:
      set(mcuboot_key_file ${CMAKE_CURRENT_LIST_DIR}/priv.pem)
      set(mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE "\"${mcuboot_key_file}\"")
      Any idea?
    2. That guide helped, but it would be great to have a more visible and generic (for all boards) guide covering the whole process like the Getting started with Nordic's Secure Bootloader guide
    3. The guide is missing "CONFIG_MCUMGR=y" from the project config
    4. The guide is missing what files need to be included:
      #ifdef CONFIG_MCUMGR_CMD_OS_MGMT
      #include "os_mgmt/os_mgmt.h"
      #ifdef CONFIG_MCUMGR_CMD_IMG_MGMT
      #include "img_mgmt/img_mgmt.h"
      #include <mgmt/mcumgr/smp_bt.h>
    5. It doesn't seem to advertise the SMP UUID, In nRF Connect Device Manager I have to disable "Only devices advertising SMP UUID". Then I can connect and perform echo.
    6. When I try to upload app_update.bin I get "Remote error: Unrecognized (7)"
    7. How do you specify what the firmware version is? Or will it just blindly perform the update with any app_update.bin?
    8. Is bootloader update planned for the future on nRF52?
    1. Have you tried just replacing the actual priv.pem file in the SDK? I know it isn't ideal, but for now it may be easier just to get things up and running. I don't have anything to point to, but I remember a colleague saying it was quite the hazzle to make it point to another key. Sorry. I don't have the details.
    2. I agree. Unfortunately, NCS is still quite new, so we have not gotten all the nice to have guides up and running at this point in time. Zephyr is a 3rd party product, so we need to get familiar ourselves as well.
    3. Thanks for the input. If you find other things that are missing, feel free to say it here, and I can take it onward to the person who will eventually write the guide.
    4. (same as 3.).
    5. Do you strictly need it to advertise the SMP UUID? Typically, you would choose a more prominent UUID, that is more descriptive of your device so that the central knows what to connect to.
    6. Did you get this before you started changing the private key as well?
    7. I think this config can be used the firmware version that you are looking for: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/kconfig/CONFIG_FW_INFO_FIRMWARE_VERSION.html?highlight=firmware%20version#cmdoption-arg-CONFIG_FW_INFO_FIRMWARE_VERSION
    8. That would be my guess, but for roadmap questions like this, you need to check with our RSM (Regional Sales Manager) for your area. Since this is a public ticket, please send me a PM with the link to this ticket if you want the contact information for our RSM for your area.
    BR,
    Edvin
