Timer capture 'noise' or sync/race condition on CC read?
I've a timer configured by gpiote to capture with a second 'overflow' capture should the signal stop. I'm not using an interrupt instead the CC[0] value is being used elsewhere (more on that in a second). The input signal is a square wave at ~150Hz. From oscilloscope I can see there is almost zero slew and no noise at all.
  NRF_GPIO->PIN_CNF[CFG_PIN_MOTION_NUM] = PIN_MOTION_CONF;
  NRF_GPIOTE->CONFIG[CFG_GPIOTE_CHANNEL_MOTION] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos | CFG_PIN_MOTION_NUM << GPIOTE_CONFIG_PSEL_Pos | GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos;
  CFG_TIMER_MOTION->PRESCALER = CFG_MOTION_PRESCALER << TIMER_PRESCALER_PRESCALER_Pos;
  CFG_TIMER_MOTION->BITMODE = TIMER_BITMODE_BITMODE_32Bit << TIMER_BITMODE_BITMODE_Pos;
  CFG_TIMER_MOTION->CC[1] = CFG_MOTION_ONE_SECOND >> 1;
  CFG_TIMER_MOTION->SHORTS = TIMER_SHORTS_COMPARE1_CLEAR_Enabled << TIMER_SHORTS_COMPARE1_CLEAR_Pos;
  NRF_PPI->CH[CFG_PPI_MOTION_TIMER_COMPARE].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[CFG_GPIOTE_CHANNEL_MOTION];
  NRF_PPI->CH[CFG_PPI_MOTION_TIMER_COMPARE].TEP = (uint32_t)&CFG_TIMER_MOTION->TASKS_CAPTURE[0];
  NRF_PPI->FORK[CFG_PPI_MOTION_TIMER_COMPARE].TEP = (uint32_t)&CFG_TIMER_MOTION->TASKS_CLEAR;
  NRF_PPI->CH[CFG_PPI_MOTION_TIMER_OVERFLOW].EEP = (uint32_t)&CFG_TIMER_MOTION->EVENTS_COMPARE[1];
  NRF_PPI->CH[CFG_PPI_MOTION_TIMER_OVERFLOW].TEP = (uint32_t)&CFG_TIMER_MOTION->TASKS_CAPTURE[0];
  NRF_PPI->CHENSET = 1 << CFG_PPI_MOTION_TIMER_COMPARE | 1 << CFG_PPI_MOTION_TIMER_OVERFLOW;
  CFG_TIMER_MOTION->TASKS_START = 1;
So the above runs and the timer is continuously updating the CC value.
I then have a second timer at a set frequency (currently 120Hz) which is used for PID control. It uses the CC[0] value in it's calculations however randomly the value is much lower than the real thing, as if there's noise. It's never higher from what I can tell.
The only plausible explanation I have is that while the second timer interrupt is accessing the CC[0] value the hardware may be updating it. My understanding is this is resolved normally by double buffering but I may be incorrect. Anyway, I couldn't find anything on the CC values being buffered.
Any advice much appreciated. I'd like to avoid copying the CC value in another interrupt, if that's possible.
  • The actual and noise are the raw CC[0] values.
    target 837, actual 859, pwm 2707
    target 837, actual 860, pwm 2736
    target 837, actual 847, pwm 2750
    noise 329
    target 837, actual 847, pwm 2762
    target 837, actual 834, pwm 2765
    target 837, actual 834, pwm 2770
    noise 114
    target 837, actual 840, pwm 2776
    target 837, actual 831, pwm 2775
    target 837, actual 829, pwm 2774
    target 837, actual 832, pwm 2776
    noise 118
    noise 352
    noise 228
    target 837, actual 838, pwm 2779
    noise 482
    target 837, actual 835, pwm 2778
    noise 355
    target 837, actual 838, pwm 2777
    target 837, actual 833, pwm 2759
    target 837, actual 844, pwm 2770
    noise 92
    target 837, actual 840, pwm 2773
    noise 383
    target 837, actual 840, pwm 2777
    noise 408
    noise 274
    target 837, actual 839, pwm 2780
    Could it be that this errata #155 is causing issues for you?
    https://infocenter.nordicsemi.com/topic/errata_nRF52832_Rev2/ERR/nRF52832/Rev2/latest/anomaly_832_155.html?cp=4_2_1_0_1_41
    Any GPIOTE signals that may come within 750 kHz of each other might cause this to occur.
    This can also happen if you have two separate channels that trigger within this window.
    Could you try the workaround, just to see if this is the root-cause of your issues?
    Håkon
  • I'll try it but it seems unlikely, my signal is much slower, circa 150Hz max and is an extremely clean square wave with no noise or noticeable slew (according to the oscilloscope). Besides if it were noise it wouldn't have such high period values many of which indicate 300Hz, an eternity in terms of noise.
    I do not have insight into the rest of your firmware, but if I assume that this is your only GPIOTE IN channel, then it might be a loading issue? Do you use a pull-up/down on the GPIO "CFG_PIN_MOTION_NUM" ?
    Håkon
    It's an optical reader which has it's own pull-up to 3V. No issue there.
    I'm not using softdevice, NRF52DK board, no sleep modes, crystal active.
      SystemInit();
      while (! NRF_CLOCK->EVENTS_HFCLKSTARTED) {}
      NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRCCOPY_SRC_Synth << CLOCK_LFCLKSRCCOPY_SRC_Pos;
      NRF_CLOCK->TASKS_LFCLKSTART = 1;
      while (! NRF_CLOCK->EVENTS_LFCLKSTARTED) {}
    Here are some of those defines for the GPIOTE wiring.
    // motion
    #define CFG_TIMER_MOTION NRF_TIMER0
    #define CFG_TIMER_MOTION_IRQn TIMER0_IRQn
    //#define CFG_TIMER_MOTION_IRQ_HANDLER TIMER0_IRQHandler
    #define CFG_PPI_MOTION_TIMER_COMPARE 7
    #define CFG_PPI_MOTION_TIMER_OVERFLOW 8
    #define CFG_GPIOTE_CHANNEL_MOTION 5
    #define CFG_MOTION_PRESCALER 4
    #define CFG_MOTION_ONE_SECOND 1000000U // (16000000UL/(2^CFG_MOTION_PRESCALER))
    #define CFG_MOTION_SIXTY_SECONDS (CFG_MOTION_ONE_SECOND*60U)
    #define CFG_MOTION_DISC_HOLES 32U
    #define CFG_PIN_MOTION_NUM 22
    #define PIN_MOTION_CONF ((GPIO_PIN_CNF_DRIVE_S0D1     << GPIO_PIN_CNF_DRIVE_Pos) \
      | (GPIO_PIN_CNF_SENSE_High      << GPIO_PIN_CNF_SENSE_Pos) \
      | (GPIO_PIN_CNF_INPUT_Connect  << GPIO_PIN_CNF_INPUT_Pos) \
      | (GPIO_PIN_CNF_DIR_Input      << GPIO_PIN_CNF_DIR_Pos))
    I'm using Timer0 as I'm out of timers, but aware it''s usually used by SoftDevice. With softdevice not in use, it should be free? any softdevice PPI's could still be interfering?
    I use GPIOTE for 5 buttons (channels 0-4). I don't understand how another channel other than specified can make it through PPI to the timer count trigger. Are you saying that's a bug? Anyhow, the buttons aren't pressed at all during the bad counts.
