CONFIG_HEAP_MEM_POOL_SIZE > 8192 creates system reset
I am using ncs 1.5.0 and modem firmware version 1.2.3.
if I keep CONFIG_HEAP_MEM_POOL_SIZE=8192 then my application runs without any issue but
If I set CONFIG_HEAP_MEM_POOL_SIZE > 8192 (e.g. 16384 ) then systems keeps resetting while I try to allocate memory using k_malloc.
Earlier I was using 1.4.1 ncs.
With that I was not facing any issue even with CONFIG_HEAP_MEM_POOL_SIZE=32768 heap size setting.
Can you help me in resolving this issue ?
Smitesh Mali
    This sounds like a stack overflow or similar.
    Could you try to enable logging, and disabling auto-resetting on faults?
    To do that, you can add the following lines to your prj.conf file (if you build with SES, you must run 'Project -> Run CMake...' for changes to prj.conf to take effect)
    CONFIG_LOG=y
    CONFIG_RESET_ON_FATAL_ERROR=n
    Could you describe your application?
    What libraries/subsystems is it using? What stack sizes are you using for the different threads? etc.
    Do you see the same resets if you use a different application, e.g. Zephyr's hello_world sample (modified so that it allocates some heap memory)?
    Didrik
  • Could you try to enable logging, and disabling auto-resetting on faults?
    I have done this. Following is the log.
    *** Booting Zephyr OS build v2.4.99-ncs1  ***<CR><LF>
    <LF>
    I: 4 Sectors of 4096 bytes<CR><LF>
    I: alloc wra: 0, 828<CR><LF>
    I: data wra: 0, 7ec<CR><LF>
    E: ***** HARD FAULT *****<CR><LF>
    E:   Fault escalation (see below)<CR><LF>
    E: ***** BUS FAULT *****<CR><LF>
    E:   Precise data bus error<CR><LF>
    E:   BFAR Address: 0x2109aa8c<CR><LF>
    E: r0/a1:  0x2001aa48  r1/a2:  0x00000029  r2/a3:  0x0000000c<CR><LF>
    E: r3/a4:  0x00210008 r12/ip:  0x00000000 r14/lr:  0x00035ad9<CR><LF>
    E:  xpsr:  0x81000200<CR><LF>
    E: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000<CR><LF>
    E: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000<CR><LF>
    E: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000<CR><LF>
    E: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000<CR><LF>
    E: fpscr:  0x20014898<CR><LF>
    E: Faulting instruction address (r15/pc): 0x00035940<CR><LF>
    E: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0<CR><LF>
    E: Current thread: 0x200165e0 (unknown)<CR><LF>
    E: Halting system<CR><LF>
    Following are the settings in prj.conf file
    # Copyright (c) 2019 Nordic Semiconductor ASA
    # General config
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_REBOOT=y
    #CONFIG_HW_STACK_PROTECTION=y
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    # Trusted execution
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    #CONFIG_TEST_RANDOM_GENERATOR=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    #CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_NATIVE=n
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # Requested Periodic TAU
    CONFIG_LTE_PSM_REQ_RPTAU="10111110"
    # Requested Active Time
    CONFIG_LTE_PSM_REQ_RAT="00000000"
    CONFIG_MQTT_KEEPALIVE=1200
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    CONFIG_NRF_MODEM_LIB_SYS_INIT=n
    CONFIG_MODEM_KEY_MGMT=y
    # Library for buttons and LEDs
    CONFIG_DK_LIBRARY=y
    CONFIG_DK_LIBRARY_INVERT_LEDS=n
    # Console
    CONFIG_CONSOLE_SUBSYS=y
    CONFIG_CONSOLE_HANDLER=y
    CONFIG_CONSOLE_GETCHAR=y
    # Main thread
    CONFIG_MAIN_THREAD_PRIORITY=7
    # Heap and stacks
    CONFIG_MAIN_STACK_SIZE=16384
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # GPIO
    CONFIG_GPIO=y
    # FOTA library
    CONFIG_FOTA_DOWNLOAD=y
    # Download client
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    # DFU Target
    CONFIG_DFU_TARGET=y
    # Modem key management
    # Application Upgrade support
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Sample configuration
    CONFIG_DOWNLOAD_HOST="nrfconnectsdk.s3.eu-central-1.amazonaws.com"
    CONFIG_DOWNLOAD_FILE="app_update.bin"
    CONFIG_APPLICATION_VERSION=1
    CONFIG_CJSON_LIB=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y
    #CONFIG_LEGACY_TIMEOUT_API=y
    # MQTT
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LIB_TLS=y
    #Modem_Info
    CONFIG_MODEM_INFO=y
    CONFIG_UART_NRFX=y
    CONFIG_SERIAL=y
    CONFIG_DEBUG=y
    CONFIG_LOG=y
    #Flash Storage
    CONFIG_NVS=y
    CONFIG_NVS_LOG_LEVEL_DBG=y
    CONFIG_NVS_LOG_LEVEL_INF=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    #Watchdog
    CONFIG_WATCHDOG=y
    CONFIG_WDT_NRFX=y
    CONFIG_NRFX_WDT=y
    I checked with CONFIG_HEAP_MEM_POOL_SIZE=32768 in "MQTT_Simple" example firmware.
    It is not getting reset.
    My application reads some data from flash (host name etc) and stores it in a buffer allocated through "k_malloc".
    After this it connects with two brokers after power on through MQTT.
    Important thing is My application hasn't changed between 1.4.1 and 1.5.0.
    But still I am getting this error in 1.5.0 while in 1.4.0 application runs without error.
    Smitesh Mali
  • I found one more thing.
    Before "k_malloc" is called to create buffer to store data from flash "k_calloc" is called in my application.
    It is inside "at_params_list_init" function. This function is called from "modem_info_init" function.
    Smitesh Mali
  • I seem to have a similar problem when using v1.5
    AWS connection (connected: 0, in progress: 0)
    Not connected to AWS, trying to connect
    Received: T60BADA7AD5D3/60BADA7AD5D3/B929E82A85F4/02475F00FF662890
    Woo hoo, listener has heard something:
    Received: T60BADA7AD5D3/60BADA7AD5D3/6A78B6E6F5F6/51792B00FF733609
    [00:01:04.637,939] [1;31m<err> os: ***** HARD FAULT *****[0m
    [00:01:04.643,859] [1;31m<err> os: Fault escalation (see below)[0m
    [00:01:04.650,512] [1;31m<err> os: ***** BUS FAULT *****[0m
    [00:01:04.656,372] [1;31m<err> os: Precise data bus error[0m
    [00:01:04.662,475] [1;31m<err> os: BFAR Address: 0x20040af6[0m
    [00:01:04.668,823] [1;31m<err> os: r0/a1: 0x2001aed0 r1/a2: 0x00004b84 r2/a3: 0x20040af0[0m
    [00:01:04.678,131] [1;31m<err> os: r3/a4: 0x00002001 r12/ip: 0x00000000 r14/lr: 0x00029f59[0m
    [00:01:04.687,408] [1;31m<err> os: xpsr: 0x8100001a[0m
    [00:01:04.692,993] [1;31m<err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000[0m
    [00:01:04.704,162] [1;31m<err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000[0m
    [00:01:04.715,332] [1;31m<err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000[0m
    [00:01:04.726,501] [1;31m<err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000[0m
    [00:01:04.737,640] [1;31m<err> os: fpscr: 0x20022208[0m
    [00:01:04.743,255] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00029d8c[0m
    [00:01:04.751,678] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m
    [00:01:04.760,009] [1;31m<err> os: Fault during interrupt handling
    [0m
    [00:01:04.766,845] [1;31m<err> os: Current thread: 0x20016920 (unknown)[0m
    [00:01:04.779,174] [1;31m<err> os: Halting system[0m
  • Hi ,
    As your prj.conf looks like the one from the http_application_update sample, I have tried to compile it with your prj.conf file in both NCS 1.4.1 and 1.5.0. However, I have not been able to find any significant change in stack sizes alone.
    Could you share your code, so that I could try to reproduce your issue, and debug it myself? If you don't want to share your code in a public ticket, you can create a private one where you tag me.
    @John coud you make a new ticket for your error?
    Just because it is a bus fault doesn't mean it is caused by the same problem.
    Didrik
